1LT with the visible carbon fiber
Just a question maybe someone can answer
I want a C7 Z51 with the 1LT ( I really dont need any of the extras that come with the 2LT )
Now if you get the 1LT you can not get this option
Roof panel, visible carbon fiber with body-color surround, removable
Now let say after I get the C7 can I order the Roof panel, with visible carbon fiber just by its self and have it shipped the the dealer or my house?
if not lets say you have that option and someone some how steals it or you drop it and crack it, do you have to prove you had the 2LT to reorder it.
Thanks for your time
Hence, I would really think about getting it when you order NOT after and by the way, the CF roof will probably be $2000. or more in the aftermarket place once the car comes out....
The expensive part of the exposed carbon fiber roof is the coating that they use so the carbon fiber isn't harmed by elements (UV).
The coating used on the ZR-1 roof is $2000 a gallon.
You should be able to order it later, but only GM knows the answer as to when and how much.
Thank you for the responses, wow I did not know the coating was that expensive. I agree it is a marketing thing to get you to the next step, I just dont know if it will be a step or a leap since no prices are out. That would be great I someone on here did sell theres but of corse it would have to be the color of my car for the body surround part of it.
again thanks for the responses
How much is the step up to 2LT ? If that is required to get the carbon fiber roof with painted spears?
How much extra is the Exposed carbon fiber roof with painted spears....
We should know by the end of this month the pricing details etc and then you ll be better able to decide what works for you..
Good question and I look forward to the answer as well.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
it IS a good question, but I'm sure there'll be more like this. there's a lot of combos that some would probably like to "mix and match."
