Go Back   Corvette Forum > C7 Corvette > C7 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C7 Corvette Discussion not covered in Tech Sponsored by
Kerbeck Corvettes
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-06-2013, 02:38 PM   #1
C7envy
CF Senior Member
Default Did anyone notice this about the c7 or am I blind?
When I took a closer look at the pictures of the red stingray at NAIAS it looked like the manual doesn't have an e brake handle?
Did they get rid of the e brake on the manual and put an electronic one or am I just blind?
C7envy is offline   Reply With Quote
Old 02-06-2013, 02:40 PM   #2
slief
CF Senior Member
Support Corvetteforum!
slief's Avatar
You must not be here often. Yea, it's an electronic e-brake. The button is located on the center console.
Here is a discussion on it.
http://forums.corvetteforum.com/c7-g...g-brake-2.html
Here is a photo of the e-brake control button.
Click the image to open in full size.
slief is offline   Reply With Quote
Old 02-06-2013, 02:45 PM   #3
texvette2
CF Senior Member
texvette2's Avatar
Just more tech stuff to go wrong and make the car un-affordable to future owners.
Which could be a boom to older vettes without all the tech. Tech is neat so long
as it works.
texvette2 is offline   Reply With Quote
Old 02-06-2013, 02:46 PM   #4
mdiiulio
CF Senior Member
mdiiulio's Avatar
Quote:
Originally Posted by C7envy View Post
Did they get rid of the e brake on the manual and put an electronic one ...?
yes
mdiiulio is offline   Reply With Quote
Old 02-06-2013, 02:55 PM   #5
BlueOx
CF Senior Member
BlueOx's Avatar
as it works.
I guess you've never had a manual e-brake cable break or fail on you...
BlueOx is offline   Reply With Quote
Old 02-06-2013, 02:58 PM   #6
JoesC5
CF Senior Member
What happens when you're cruising down the highway at 75 MPH and your 4 year old grandson has his hand resting on the center console and pulls up the E-brake button?
JoesC5 is offline   Reply With Quote
Old 02-06-2013, 02:59 PM   #7
JerriVette
CF Senior Member
JerriVette's Avatar
An emergency brake that actually works and probably saves a few pounds as well.
I believe it works on all four brakes rather than just the rear two.
JerriVette is offline   Reply With Quote
Old 02-06-2013, 03:00 PM   #8
MikeG37
CF Senior Member
MikeG37's Avatar
Quote:
Nothing.. well a warning light maybe.
MikeG37 is offline   Reply With Quote
Old 02-06-2013, 03:01 PM   #9
JoesC5
CF Senior Member
Quote:
Can't say I have and I've had a drivers license since 1956. A lot of cars under the bridge since then.
Old 02-06-2013, 03:05 PM   #10
alanhang
CF Senior Member
as it works.
we have it in our z4. its great and works like a charm
alanhang is offline   Reply With Quote
Old 02-06-2013, 03:06 PM   #11
alanhang
CF Senior Member
nothing. first of all you have to lift it up to activate. Second it doesnt operate once you start moving.
Old 02-06-2013, 03:06 PM   #12
89L98
CF Senior Member
89L98's Avatar
Good Question. Maybe some type of override, i.e., no E brake can be applied when the Car is moving?
89L98 is offline   Reply With Quote
Old 02-06-2013, 03:07 PM   #13
JoesC5
CF Senior Member
Quote:
In other words, you're saying it is locked out if you're driving down the highway.
In years past, once in 1963(1957 Ford) and again in 1982(1969 Corvette), I've had two hydraulic brake failures occur and had to use the manual E-brake to stop my car before running a red light in both cases. Sorry, but a waning light would have gotten me killed, whereas the manually operated E-brake(at any speed) got me stopped in time.
Old 02-06-2013, 03:07 PM   #14
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Hopefully it works really well - seems like there were a lot of threads over the years about the C5 parking brake.
Vetteman Jack is online now   Reply With Quote
Old 02-06-2013, 03:08 PM   #15
JoesC5
CF Senior Member
Quote:
"pulls up" is the same thing as 'lift it up".
If I need to make an emergency stop while the car is in motion, because of hydraulic brake failure, does the floor pan have openings where I can drag my feet to stop the car(like Fred Flintstone)?
Old 02-06-2013, 03:10 PM   #16
Tommy D
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
St. Jude donor in memory of jpee '14
Look at the up side, being electric it probably saves weight too I would imagine that there would be no cables, parking brake handle or extra brake shoes in the rear.
Tommy D is offline   Reply With Quote
Old 02-06-2013, 03:11 PM   #17
jvp
jvp's Avatar
Send a message via AIM to jvp
Heh, no, that's not what happens. You stop. Fast. And violently. That is unless GM's reprogrammed their electronic brake since the CTS-V's.
jas
__________________
"It's not a car, it's a Superman suit. You don't drive your Corvette, you wear it. And when you're wearing your Corvette, nothing can hurt you." All Corvettes are Red
jvp is offline   Reply With Quote
Old 02-06-2013, 03:14 PM   #18
jvp
jvp's Avatar
That may be the case in your Z4, but it isn't in the 2009 Cadillac CTS-V I had. All four calipers were locked up. I tested it on an open back road with no traffic around me to verify it. And sure enough: the car slowed, violently.
We'll have to see if GM's since reprogrammed the controller to disallow activation while the car is in motion.
jas
__________________
Old 02-06-2013, 03:18 PM   #19
geezerman
CF Senior Member
read the same thing,..and, as a total "manual" kinda guy,..i'm just thankin' my lucky stars that corvette still makes a manny! period!,...it's now down to a precious handful that even make em in a sportscar?,..what is it?,..porsche still has em,..the vette,..the new viper,..beemer m3's,..i think your stangs,..lancer evo's and subbies,..what else comes as a manual nowadays?,..SO!,..i'm so glad the new vette comes as a manual!....
geezerman is offline   Reply With Quote
Old 02-06-2013, 03:24 PM   #20
JoesC5
CF Senior Member
jas
That's what I expected would happen. As we all know, young children like to touch and feel things. Seems like having that button on the center console is inviting a youngster to see "what will happen if I lift up on this button?". At least with the old style hand brake handle, it is noticeable if they grasp the handle and start pulling up on the handle. Plus it would be in slow motion and they probably wouldn't have the arm strength to lock up the brakes in a violent fashion vs the few ounces and the few milliseconds it would take for a 4 year old to operate an electrical button.
Seems that locating the button on the dashboard to the left of the steering column would be better.
If they lock it out when the car is in motion, then what happens if you do need to make an emergence application of the parking brake? While the parking brake might not be called an emergency brake, it sure is nice to have it if there is an emergency need to top the car.
Reload this Page Did anyone notice this about the c7 or am I blind?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
