Orange Peel & the new C-7
#101
Yes, you are confused. You can have the worst paint job in the world with big chunks of dirt and orange peel in the base. If you put enough clear on it and sand that clear flat and polish it, you are going to see a PERFECTLY FLAT paint job.
#102
Well, ONE of us was a head painter at a GM shop for 13 years and custom painted street rods, street machines etc for 25 years. Plus won "best paint" at World of wheels as well as numerous "best of show" awards.................and one did not.
I am not saying a base cannot have Orange peel.
But the base coat/clear coat systems of today, the base lays flat. What I am saying is, if you sand the clear coat flat and polish it, the paint will be flat and shiny in laymans terms, so for easy to understanding the orange peel problem is the clear.
So - are you trying to tell me that there is no orange peel in the base coat paint on my LMB '06? If you were talking about the finish on my after market spoiler you'd be right, 'cuz I know how that was prepped. If you're talking about the factory paint job you are just flat wrong. (pun intended)
PS - don't dislocate your shoulder patting yourself on the back.....
#103
Clear coat covers up big chunks of dirt..................??????????????????
BTW - the car looks great from 10 feet away, and I love the color. Reread my first post in this thread - #17. In case you were wondering, I don't "hate" it!
#104
Well, maybe that's the problem on my car then - there just isn't enough clear on it to cover up the orange peel in the base coat. I'm looking for some middle ground here, but you make it tough when you try to tell me I can't see orange peel in the base coat on my car............
But I have seen guys paint three coats of Acrylic urethane (very orange peely) and then put two coats of clear on it and they were screwed, not enough clear to overcome their butchery of the art of painting.
#106
#107
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Also what Talon 90 said about the factory has to meet government regulations for the paints. The Corvette uses waterbase paint instead of paint thinned by paint thinners.
Racer's post about a bad paint job with dirt and orange peel is correct. If you have enough of clear you can sand and buff and make it look good.
#108
Wow - well, you are right in one sense in that I don't have your hands on experience with painting. What's interesting tho is how you seem to think that makes you an expert on the conditions on my car from your location about 1500+ miles away. You must have really good vision!
Maybe your definition of "orange peel" is where you are getting tangled in the tall grass.
Orange peel is a "texture". If you have orange peel on your car, it is in the clear or both, but sanding and polishing the clear, makes the base OP disappear. If it doesn't go away by wet sanding and buffing/polishing, then I think it could be something else you're seeing.
This...
That being said, I would tolerate orange peel a LOT more if I knew there was sufficient clear coat on the car that I could cut it down and polish it out.
#109
For those starting down the road of wet sanding, wetsanding can make a difference. Make sure the shop doing it is competent. It is true that the clear coat on the Corvette is very hard, it is also fairly thin. If someone isn't sure that they are doing they can break through the clear easily. I've made a little sketch below to illustrate what you are dealing with.
^^^^^^ clear
^^^^^^ base color
The orange peel that you see likely originated in the color coat. The clear coat, while it may have some orange peel of its own, is equally highlighting the OP in the base color. You won't get all of the OP with a wetsand of the clear. You will cover it up or smooth some of the appearance of it. What is likely left will look like this:
__________ clear
^^^^^^^^ base color
If they are not careful, it can end up like this:
__ __ __ ___ clear
^^^^^^^ base color
Which will lead to oxidation of the color coat once exposed to the elements. You need to be particularly careful on edges and sharp angles.
Keep in mind also that your clear coat is your UV protection against fading. At an approximate max coat weight of about 2.2 mils (.0022"), you don't have a lot of room to work with. For reference a sheet of lined office paper is approximately .003".
#110
It can be either or both.
^^^^^^ clear
^^^^^^ base color
__________ clear
^^^^^^^^ base color
__ __ __ ___ clear
^^^^^^^ base color
^^^^^^ clear
^^^^^^ base color
__________ clear
^^^^^^^^ base color
__ __ __ ___ clear
^^^^^^^ base color
Got to explain one thing you said that might be misleading
If you have this
___________ Clear
^^^^^^^^ Base coat
your paint job is going to look like this.
__________________ There are NO maybe's about it.
Also, if there is enough clear, you WILL remove all the Orange peel.
#111
If you have this
___________ Clear
^^^^^^^^ Base coat
If you have this
___________ Clear
^^^^^^^^ Base coat
No, actually you won't. You will hide it. If Orange peel is in the color coat you can't remove it by only sanding the clear coat. You can improve by lowering the highest of high spots which will take away its ability to reflect and refract light which accents the imperfection. It however will still be under the smooth clear with the peaks sanded off and the valleys filled in with clear which will make it less likely to be seen.
#112
My 2013 white 427 has very good paint on it! I mentioned this in the other thread regarding the C7 that the paint at 1:27 in the video looks horrible. Of course no one responded for we can't criticize the C7 w/out getting lambasted on here! Check it out, looks like lots of orange peel to me!
http://www.youtube.com/watch?v=rKrQrAn_hNA
Id say I went from 4/10 to 7/10 !
#113
Dry spray can be mistaken for Orange peel by some uneducated people.
Bottom line, these two finishes (dry spray/orange peel) are what you see on the surface.
That, in the automotive refinishing business are how the terms are used. If you can't see or feel Orange peel, you don't have Orange peel.
#114
The irregular surface of a sprayed paint film resembling the skin of an orange. The defect is due to the failure of the film to flow out to a level surface. This can be caused by improper gun setup, lack of air pressure, incorrect solvent selection, or poor painter techniques.
ORANGE PEEL: A surface flaw in which the paint goes on with too much texture. Usually caused by improper reducing or air pressure.
Sure it followed the contours of the base that might of had orange peel, plus added to it when the clear did not flow out properly, but there is only one place Orange peel is and that is on the surface.
#115
And just to throw another twist into this, with the OEM I work for, and I will not say who, we find the orange peel issue originates in the primer. Sand the primer flat and no orange peel the rest of the way thru the process.
There are just too many variables to say fix this or fix that and orange peel will go away. All comes down to what plant has what application equipment, paint, skilled labor and the spray booth environment on that particular day. Tomorrow could all be different. Now I am talking about a production line paint shop and not a custom body shop that has time to tweak the process as they go.
So many people have this idea that because robots paint cars these days that it is no more involved than a robot putting a bolt in a hole or applying a spot weld. One simple thing people don't realize is that when paint leaves the applicaor, flies thru the air and then lands on the body part, that brief moment in time of the paint particles flying thru the air you have ZERO control over what happens to the paint. Now certainly after you know the result, you can make changes and hope the next application is better, but you are reacting to what just happened. The next time the paint flies thru the air something different can happen and then you react to that and on and on.
This is why you sand between coats and do a final wet sand and buff for a perfect paint job. You just can not control the application with the perfection that will give no defects or orange peel. Just can not be done. Period.
Now one last thing I find a bit funny - A new Lexus that is going to Europe will have the primer coat sanded and have one of the best final finshes in the industry, but, those that are coming to the USA do not get this treatment as they think most Americans DO NOT CARE about orange peel. Honestly, most people out there buying cars today, don't care. (And no, I don't work for Toyota!)
And Paul, keep fighting the good fight, your doing an awesome job!
(You too Racer. I know your a talanted guy with some great experience and I have alot of respect for that.)
#116
to some degree the idea behind the primer being the major culprit makes sense. i'm not a painter by any means but from what i remember, the primary is largely a filler, and could be susceptible to clumping... ie basis of orange peel?
#117
#118
Sounds good, but I'm not sure I understand how that's gonna work on a base/clear finish. Most of the orange peel on my C6 appears to be in the base coat; the clear is pretty good after a clay bar cleaning. I don't see how mine could have been any better unless the base coat was wet sanded before the clear went on - and that's not gonna happen in a production line operation!
What it comes down to though is, if you want a hand finished...ESPECIALLY wet sanded primer, base and clear coats...you're talkin Aston Martin, Koenigsegg, Lamborghini type finishes....you gotta pay.
#119
The paint is excellent on my 2013, no OP, no flaws.
FWIW, I went to a large car show this past summer, a 2010 Corvette in factory CRM won "Best Paint." Great news for Corvettes I thought, but there is more to the story. We learned later that one show sponsor was a local custom painter who was displeased with the choice of a factory paint job for "Best Paint.". Before the awards were announced we saw the judges & the custom painter return to the CRM Corvette and re-scored it (the C6 won even with the extra scrutiny). Asking why they returned a second time is how we ultimately learned that the judges were trying to find more faults and keep the C6 from winning the trophy.
I would expect the C7 to have equal or better paint to the C6.
Cheers,
JB
Cheers,
JB
#120
I like the finish on my '08 JSB, especially when I compared it to my neighbor's '08 Ferrari F430 'vert. The Ferrari's finish was inferior to my Corvette. Perhaps his was painted on a "bad environmental" day and mine wasn't. I'm sure humidity plays a huge part in the paint application affect. Maybe even barometric pressure?!?
