Go Back   Corvette Forum > C7 Corvette > C7 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C7 Corvette Discussion not covered in Tech Sponsored by
Kerbeck Corvettes
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-16-2013, 01:19 PM   #1
1analguy
CF Senior Member
1analguy's Avatar
Default Rev Match?
A lot is being made of the "rev match" feature included with the manual transmission. How do you folks feel about it?
Personally, I don't understand the need...I've owned exclusively stick-shift cars for decades, and they have all had rev match. It's called blipping the throttle. Most folks buy a manual transmission in a car like this because they value the added driver involvement. Now we're supposed to be thrilled that they've figured out a way to remove some of the driver involvement? Gee, if only they could get rid of those annoying clutch pedals and shift levers, too...
The philosophy behind this feature is the same as the philosophy behind Launch Control: Lets bring manual transmission competence to those with lesser skill levels. You know...like a player piano, or laser sights, or...
Rev match falls into that huge category of things that you know, intellectually, to be "improvements", but that just somehow don't seem to be "better" because, in doing their job, they actually remove something desirable from your experience.
Of course, the other side will say that the same argument could easily have been made when syncronizers were first introduced in manual transmissions to eliminate the need for "double clutching", and that rev match is just another step in the evolution of the stick. And they're right, but the next step is the loss of "those annoying clutch pedals and shift levers"...and the result is the "manumatic" transmission, along with its pinky shifters. Yes, it's marginally faster, and if you honestly spend a lot of your time on a track, scratching around for a few hundredths of a second here and there, it may be a just what you want. But, does it really make the car more enjoyable to drive the other 99% of the time?
I just hope that the feature is like Launch Control, in that it needs to be actively engaged...or at least can be turned off.
1analguy is offline   Reply With Quote
Old 01-16-2013, 01:25 PM   #2
Reciprocal
CF Senior Member
Reciprocal is offline   Reply With Quote
Old 01-16-2013, 01:26 PM   #3
jbomx363
CF Senior Member
jbomx363's Avatar
http://forums.corvetteforum.com/c6-corvette-general-discussion/2836586-rev-matching.html
http://forums.corvetteforum.com/c7-g...hing-what.html
jbomx363 is offline   Reply With Quote
Old 01-16-2013, 01:28 PM   #4
Corgidog1
CF Senior Member
I agree with where you are going with this. I also hope this "feature" is able to be turned off. In fact I wish GM had put the dollars spent on this into something more upscale in the interior-maybe 1 less piece of plastic.
Corgidog1 is offline   Reply With Quote
Old 01-16-2013, 01:29 PM   #5
cclive
CF Senior Member
cclive's Avatar
I agree that it should be able to be turned off by the driver, but this is a feature that I really like. With an already electronically controlled throttle, this feature is very easy to implement and will save lots of wear on the clutch and the synchronizers. A blip on the throttle can't match the speed exactly but only get closer than no blip...this will be spot-on. Good call by GM...this is a useful feature that is very low cost to implement.
cclive is offline   Reply With Quote
Old 01-16-2013, 01:32 PM   #6
LEAVINU
CF Senior Member
LEAVINU's Avatar
Lamarwaldenautomotive
Maybe in a few years the Vettes and Vipers will be 99% computer controlled like the GTR's are today.
LEAVINU is offline   Reply With Quote
Old 01-16-2013, 01:38 PM   #7
nickTsandman
CF Senior Member
nickTsandman's Avatar
For drivers who will track there C7's on a road course the ARM will be a great addition - especially if they have difficulties performing a perfect heel - toe down shift.
nickTsandman is online now   Reply With Quote
Old 01-16-2013, 01:57 PM   #8
K-Spaz
CF Senior Member
K-Spaz's Avatar
The heel toe thing is where I'd need practice if I was to do it in a *****-to-the-wall track situation. I can do it, but if you are really driving on the edge, small issues with your timing might mean you're in the weeds. I do not brake well with my heel, I just never did that very well and my driving time (experience) with it is limited. As to double clutching, I've done that my entire driving life, and I can rev match well enough to do so without using the clutch, and not making any odd noises either. Not quickly of course, but can do it.
I certainly don't need help with the throttle. But having adjustable pedals to keep my right foot angle more comfortable so I CAN heel brake would be a nice touch (imo).
K-Spaz is offline   Reply With Quote
Old 01-16-2013, 02:02 PM   #9
puckshaw
Junior Member
Heel-toe is done with the ball of your foot on the brake and the heel blipping the throttle. Not the other way around.
puckshaw is offline   Reply With Quote
Old 01-16-2013, 02:03 PM   #10
SaberD
CF Senior Member
SaberD's Avatar
Send a message via AIM to SaberD
i heel toe every time i bring my car to a stop, and if i was no longer able to do that with a manual transmission, I would feel that I am losing out on a lot of the driving experience. I actually don't even use my heel on the gas. i put my foot at an angle and kind of roll it over to blip the gas.
SaberD is offline   Reply With Quote
Old 01-16-2013, 02:06 PM   #11
SUPERCRUZ
CF Senior Member
SUPERCRUZ's Avatar
Nissan 370Z has this feature and I believe the driver can turn it off. Hope GM does the same; otherwise this will take some of the fun out of the car for those of us used to blipping the throttle on down shifts.
SUPERCRUZ is offline   Reply With Quote
Old 01-16-2013, 02:28 PM   #12
K-Spaz
CF Senior Member
K-Spaz's Avatar
Quote:
That would explain why it lacks feel then! Lol
Old 01-16-2013, 03:01 PM   #13
BigRedPig
CF Member
BigRedPig's Avatar
Motor trend says that it can be deactivated. Just look at their "first look."
BigRedPig is offline   Reply With Quote
Old 01-16-2013, 03:18 PM   #14
JerriVette
CF Senior Member
JerriVette's Avatar
The deactivation device is a paddle on behind the steering I believe
JerriVette is online now   Reply With Quote
Old 01-16-2013, 03:33 PM   #15
Subw00er
CF Senior Member
Subw00er's Avatar
I totally agree.
For real sports car enthusiasts this is a ridiculous feature. I also instinctively blip the car myself when downshifting and I do heel and toe on the road during spirited driving. On the track I exclusively heel-toe.
So wait, this is not permanently defeatable? Ok, so now every time I enter the car I have to hit two buttons? One for comp mode, and one for removing auto blip? Thats a VERY poor user experience considering the real goal of the car is to be a serious sports car.
Why are car engineers so focused on removing the driver from the driving experience? Its a fascinating and mind boggling trend. I think the real problem is that people buy these cars with no clue how to really drive them (not really their fault, they're just ignorant) and manufacturers add these helpers so that anyone can drive the cars fast.
Ok, that makes sense. But what they're doing in the process is ruining the essence of really what sports car driving is all about.... the connection and syncing of a human to a machine. Its about nailing that apex, making a perfect down shift, and testing limits. If the car is doing it for me, what is the fun in that? Real enthusiasts shouldn't be punished for wanting to drive a car fast ALL BY THEMSELVES
Subw00er is offline   Reply With Quote
Old 01-16-2013, 03:38 PM   #16
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Quote:
Click the image to open in full size.
for those not understanding rev matching (sometimes called Adaptive Shifting)... it matters to a particular driving type. For those particular drivers, it is a welcomed addition.
When in fourth gear - and blazing into a tight corner and downshifting into second - breaking traction (due to the downshift) will send you into the barrier. Up to the present time, one would need to try to rev match engine RPM's right before the downshift. Having to do this manually - keeps the driver very busy behind the wheel.
If it's not beneficial for ones driving type; then instead of saying "it's wrong"... just say it's "not for me".
Everything I've read so far says that Adaptive Rev Matching will be driver enabled/disabled.
Mike Mercury is offline   Reply With Quote
Old 01-16-2013, 03:38 PM   #17
Suns_PSD
CF Senior Member
It's an unbelievably sweet option and I don't want to own another car w/o it.
Suns_PSD is offline   Reply With Quote
Old 01-16-2013, 03:39 PM   #18
keeks2915
CF Senior Member
Nothing to get all worked up about.
Just turn it off.
Take no offense but when my wife drives she is a little off on the downshifts.... I think this will be best of both worlds.
A) all us shift experts won't use it and if lesser family members drive then the tranny won't take the beating.
B) if you are really getting on it vs someone in an auto it will be quicker and more than likely save your tranny if you somehow miss one of those gates at 7,000 rpm........
C) I am not a pro racer although I have hammered on vettes for 30 years.
I will honestly admit I am not always 100% jerk free when shifting.
The new girlfriend will really be impressed how smoothly you shift.......
keeks2915 is offline   Reply With Quote
Old 01-16-2013, 03:42 PM   #19
Daekwan06
CF Senior Member
Daekwan06's Avatar
Daekwan Daekwan Daekwan Daekwan
Dont like it. Then turn it off. Yes, it is defeatable.
While I agree the main reasonable for buying a manual transmission is to be more involved in the driving process, how can you not like a feature thats designed to make you operate the car better & faster. And is a feature you can turn off if you dont like. Same would go for traction control, vehicle stability, performance driving modes, etc. They are all designed to make you go FASTER and SAFER in your vehicle.
One of the things I love most about the C7, is that the technology has been stepped up tremendously. I wont being going for a 2014 model. But if they announce a real DCT transmission in the 2015 or later models.. then its pretty much a guarantee I'll be in a C7 sooner or later.
Daekwan06 is offline   Reply With Quote
Old 01-16-2013, 03:49 PM   #20
LS3_E85_Corvette
CF Senior Member
LS3_E85_Corvette's Avatar
How does this feature compare to NLS (No Lift Shift) which was announced on multiple GM models?
LS3_E85_Corvette is offline   Reply With Quote
Reload this Page Rev Match?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Interesting and very useful cruise control feature... Rad22 C7 General Discussion 17 11-27-2013 09:29 PM
rev matching question for owners Sin City C7 General Discussion 17 09-28-2013 02:11 AM
I unintentionally brought up a controversial topic 2 Ag R8Cs Off Topic 26 09-11-2013 06:25 AM
Down shifting debate with father Red_Demon C5 Z06 Discussion 62 08-22-2013 01:53 AM
Rev-matching / Synchronizer Question (mostly for the old timers) Slynky C7 General Discussion 48 06-13-2013 10:02 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
