View Poll Results: how many plan to have TSB NA-18-355 done?
I had the (TSB NA-18-355) flush done
21
17.50%
I plan to have the flush done as a preventative measure
35
29.17%
I don’t plan to have it done until I either get the shudder or it’s time to have the fluid replaced.
64
53.33%
Voters: 120. You may not vote on this poll
TSB NA-18-355: how many A8 owners plan to have latest fluid exchange procedure done?
Old 03-17-2019, 01:30 PM
Maxie2U
Maxie2U's Avatar
Received 4,171 Likes on 2,250 Posts
Default TSB NA-18-355: how many A8 owners plan to have latest fluid exchange procedure done?
How many A8 owners plan to have fluid exchange procedure done regardless whether you have the shudder or as a preventative measure?
Many if not all have read GM released a TSB (TSB NA-18-355) in conjunction with a new ATF fluid (Quart P/N 19417577 with the blue banner across the label and license #J-62120 on the back) to address the torque converter clutch (TCC) shudder conditions on the 8L90 8-speed automatic transmissions.
My question is how many plan to have TSB NA-18-355 done regardless whether it’s covered under warranty or you have to pay out of pocket.
Old 03-17-2019, 01:53 PM
Flame Red
Flame Red's Avatar
Received 1,086 Likes on 657 Posts
I did the "black label" fluid exchange myself back in November of last year before this new Wonder Fluid was announced. I just ordered a 6 pack of the magic blue label stuff from Summit and it should come this week. I'll use the same procedure as last time https://www.corvetteforum.com/forums/c7-tech-performance/4204078-how-to-tranny-flush-with-mobil-1-synthetic-lv-atf-hp-without-dropping-the-pan.html
I figure I need to get-r-done before the Florida Inferno starts again. Seems like it is selling out quickly - one day it was available from Summit and the next it was 6 week back order
Old 03-17-2019, 03:41 PM
STiRob
STiRob's Avatar
Does anyone know when the new fluid started being used at the factory?
thompstl1 (03-18-2019)
Old 03-17-2019, 03:46 PM
orca1946
orca1946's Avatar
I will have this done at my next free oil change.
Old 03-17-2019, 10:30 PM
paki
paki's Avatar
I got the “could not replicate customer concern” when I took it in.
Old 03-18-2019, 09:58 AM
Keefer07
Keefer07's Avatar
I had it done on my 2015. They covered it under my powertrain warranty. I wasn't expecting to notice any difference since mine had not started shuddering yet. It shifts much smoother now and I cannot feel it switch between V4 and V8 mode even when I watch it switch on the gauge.
Old 03-18-2019, 12:23 PM
Formula52
Formula52's Avatar
If I have to pay for this fluid change, how much $ do you think it will cost?
Old 03-18-2019, 09:24 PM
DSPC7
Support Corvetteforum!
DSPC7's Avatar
On another forum under title Had New TSB #18-NA-355 (A8 Shudder) Done - the Cost was $625 not as a warranty service
The following 3 users liked this post by DSPC7:
dfkruger (03-19-2019), Formula52 (03-19-2019), Maxie2U (03-20-2019)
Old 03-18-2019, 09:36 PM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,718 Likes on 5,599 Posts
Does anyone have a copy of TSB NA-18-355 they could post?
Old 03-18-2019, 10:03 PM
DSPC7
DSPC7's Avatar
Found on another thread
Srevice part 1
https://www.corvetteforum.com/forums...355-part-1.pdf
Srevice part 2
https://www.corvetteforum.com/forums...355-part-2.pdf
Maxie2U (03-20-2019), SilverGhost (03-18-2019), Vegas1500 (03-21-2019)
Old 03-19-2019, 03:34 AM
SgtMajUSMC(Ret)
SgtMajUSMC(Ret)'s Avatar
I also posted it on this forum with invoice, here:
https://www.corvetteforum.com/forums...post1598909413
Keep in mind that does not include total tax and hazmat disposal fee of $110 split between the TSB and diff fluid change I had done at the same time.
Old 03-19-2019, 07:39 AM
MA ZO6
MA ZO6's Avatar
St. Jude Donor '13
Here is some information (see attachment below) about the new fluid.I had it done to my car and it solved the shudder problem. It was covered under warranty as the need to hook up a device and make sure your car has the problem BEFORE they will cover it. If the device does NOT detect the shudder the fluid change will not be covered under warranty.
John
File Type: pdf
Old 03-19-2019, 07:44 AM
Patman
Patman's Avatar
Received 1,920 Likes on 1,192 Posts
I have a late production 2018 (built the first week of Dec 2017) and have 9700 shudder free miles on my car, so I don't plan on messing with a good thing so I won't be changing the fluid until it's first regular service (maybe around 50 to 60k?).
Old 03-20-2019, 01:49 PM
thompstl1
thompstl1's Avatar
It would appear my 2018 does NOT have the latest transmission fluid, is that your understanding from reading the information as well?
If so, I'd have no problem paying for the fluid change, finding a dealer that knows what they're doing and how to do it is the real challenge.
Old 03-20-2019, 02:10 PM
bankers1
bankers1's Avatar
16,000 Miles '17 GSCE # 663 A8 No problems so far. Produced 1/2017 It is really babied...
Jorge Camacho (01-25-2021)
Old 03-20-2019, 02:16 PM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
You might.... The actual severity of the shudder must be logged and a snap shot taken to submit to GM. They know that everyone reads the forums and will be flocking to dealers for free fluid changes so there is a level of shudder that's considered normal and anything above that threshold can have the bulletin performed. Out of the 15 or so cars we've had come in over the last month, less than half were above the limit.
Old 03-20-2019, 03:51 PM
05XLRtoC7_San Diego
05XLRtoC7_San Diego's Avatar
Hmmm....I have Range, so no shudder.
However, might be a good idea to have the fluid change performed at 50k instead of the usual 100k interval.
Interesting to hear this was covered under the 5 year transmission warranty on some cases even without shuddering?
To TSB NA-18-355: how many A8 owners plan to have latest fluid exchange procedure done?
Old 03-20-2019, 08:04 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
The stipulation for us confirming the shudder is above a certain level and recording that measurement is what changed. We've done dozens and dozens of them where we could confirm there was shudder, but there was no threshold that had to be exceeded so the fluid was changed.
Old 03-21-2019, 04:29 PM
LanceVette
LanceVette's Avatar
Just got back from the dealer and they said my Corvette is not affected by this TSB. It's an early 2015 with the A8. I have not had any problems as of yet. Should I investigate further?
Old 03-21-2019, 04:49 PM
Keefer07
Keefer07's Avatar
Dealer did mine under the powertrain warranty for peace of mind. I had no issues yet.
Quick Reply: TSB NA-18-355: how many A8 owners plan to have latest fluid exchange procedure done?
