Is the battery going to be in the rear?
Old 12-30-2012, 02:43 AM
blackcorvette06
blackcorvette06's Avatar
Default Is the battery going to be in the rear?
Or is it that black box labeled 3?
Old 12-30-2012, 02:57 AM
glhs386
glhs386's Avatar
I'm going to go with ECU or fuse box.
Old 12-30-2012, 03:05 AM
blackcorvette06
Yeah your right. It will probably be in the trunk somewhere. I think the c6 z06 has it back there..
Old 12-30-2012, 04:10 AM
LS1LT1
LS1LT1's Avatar
I too think that there is a good chance that the battery will be mounted in a compartment in the back of the cargo area.
Yes, it does.
Old 12-30-2012, 06:30 AM
SCM_Crash
SCM_Crash's Avatar
Is #2 the coolant or something? It's so far back in the engine bay it'd be hard to imagine.
I definitely don't think that #4 is the battery because I see no other location that looks like the fuse cover. Considering how many more computers and electronics are going into the C7, a fuse box that size would make a lot of sense.
Edit:
Never mind. I see that there is a line going from #2 to the radiator. It's definitely the coolant reservoir. Interesting putting it that far back.
Old 12-30-2012, 06:43 AM
LS1LT1
LS1LT1's Avatar
Originally Posted by SCM_Crash
Edit:
Hmm, are you sure that #9 isn't the coolant reservoir (as the C5s and C6s have it on the driver's side as well) and that #2 might actually be the filler cap for the dry sump oiling system (on models so equipped at least)?
Not sure.
Old 12-30-2012, 06:46 AM
SCM_Crash
SCM_Crash's Avatar
#9 is the brake fluid reservoir. You can see it's attached to the brake booster and it's also where all the brake fluid reservoirs have always been. The coolant reservoir on my C5 is on the passenger side, not the driver's side. #9 would be too small for the coolant anyway.
Old 12-30-2012, 07:25 AM
toxin440
toxin440's Avatar
The fact that I see no dipstick on or around the intake manifold tells me that #9 is going to be dry sump related. It's in the exact same spot as the dry sump tank on Z06's
Weird that it looks so "wide" - I thought the taller and more narrow you could get your sump tank the better.
Old 12-30-2012, 07:56 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
Looks to me that
2 = oil fill
8 = oil dip stick
9 = brake booster
10 = clutch
11 = washer fluid
5 = according to that corvetteonline article says is the airbox
I'm curious about 1,3,4,.... the 3 appears to be the fuse box, but what is 4?
1 is WAYYY up there.
14 more days.....
Old 12-30-2012, 09:16 AM
c54u
c54u's Avatar
Originally Posted by AverageVetteNut
Looks to me that
2 = oil fill
8 = oil dip stick
9 = brake booster
10 = clutch
11 = washer fluid
14 more days.....
1 = access to cabin air filter
Old 12-30-2012, 10:44 AM
AverageVetteNut
ohhhhhh , ok... that makes sense
Old 12-30-2012, 11:34 AM
BlueOx
BlueOx's Avatar
The battery will go under the back seat, like the old VW Beetles!
OK, yeah I am guessing it's a rear-mounted battery.
Old 12-30-2012, 11:43 AM
BlueOx
BlueOx's Avatar
Edit:
This.
1-Cabin filter
2-Coolant filler cap
3-?
4-Fuse box
5-Air filter
6-Hood vent 'funnel'
7-Oil filler cap
8-Dipstick
9-Brake fluid
10-Clutch fluid
11-Washer fluid
I have to say this air filter box (if that is what it is) seems like a real convoluted air path.
Old 12-30-2012, 12:25 PM
AverageVetteNut
I saw 7 there and took a few looks to see that it was a cap. At first it just looked like a black rectangle.
Interesting.
Old 12-30-2012, 01:17 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Originally Posted by BlueOx
This.
1-Cabin filter
3-?
4-Fuse box
5-Air filter
7-Oil filler cap
8-Dipstick
9-Brake fluid
10-Clutch fluid
11-Washer fluid
If you look at the air filter housing, you can see that it is a true "cold" air system as it appears to get it's air from outside the engine compartment.
Old 12-30-2012, 01:21 PM
tome
tome's Avatar
Old 12-30-2012, 01:28 PM
Z_Rocks
Z_Rocks's Avatar
C7 runs without battery.
To add more fun... It will be behind the "back seat"
To Is the battery going to be in the rear?
Old 12-30-2012, 02:42 PM
JoesC5
JoesC5's Avatar
The engine compartment looks to be pretty full. I wonder where the dry sump oil reservoir is going to be located?
Old 12-30-2012, 02:47 PM
Larry/car
Larry/car's Avatar
You plug in external power to start the engine, no need for a battery tender.
Old 12-30-2012, 02:51 PM
burtonbl103
burtonbl103's Avatar
St. Jude Donor '06-'07-'08 & '12-'13
Solar panels on rear hatch..
this place id funny.
Quick Reply: Is the battery going to be in the rear?
