What do you think the weight of the C7 will be?
Old 12-21-2012, 02:06 AM
  #41
JLinCA
JLinCA's Avatar
Originally Posted by 1320vetteran
I think it will be 3,030-3,040.
What do you think? Make it official and post it.
I am guessing about the weight of the current Z06.
Old 12-21-2012, 06:37 AM
  #42
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Current Z06 weighs 3175 pounds. How much do you think that the weight of the current Z06 would be reduced if you removed the dry sump(15 pounds), replaced the large brake rotors with the smaller rotors found on the base C6 and replaced the heavier wide wheels/tires with the lighter wheels/tires from the base C6? 88 pounds?
Then subtract the weight saved by replacing the heavier hood, roof panel, roof halo, rear quarters, door skins, rocker panels and rear hatch on the current Z06 with lighter carbon fiber parts. 75 pounds? Then replace the Z06's aluminum rear crossmember with a lighter Mg crossmember. 10 pounds? Replace the steel mufflers and over the axle exhaust with a lighter titanum exhaust. 20 pounds?
I see some 208 pounds of fat right there, that can be removed off the current Z06. I bet there are some other weight savings with the new C7 design such as a lighter hatch because of a much smaller rear glass. 10 pounds?
Old 12-21-2012, 07:28 AM
  #43
ryoder
ryoder's Avatar
Good pt about the titanium exhaust. I hope they bring that back on the Z06 and its too quiet so everybody sells them to people like me for $300. That was an awesome upgrade on the C5 if you don't mind a quiet exhaust.
Old 12-21-2012, 11:51 PM
  #44
BSheppard
BSheppard's Avatar
I'll say 3113lbs
Old 12-25-2012, 03:35 AM
  #45
85scott
85scott's Avatar
Since I assume all guesses are based on the less comparable curb weight/full tank method, put my money on 3127 lbs.
Making it around 3015 without fuel, or about 135 lbs less than a 2013.
All automakers tend to overestimate how much they can actually cut. So I'd be truly amazed if the base C7 came in under 3,000 lbs, since that was probably GM's shipping weight target to begin with.
Old 12-25-2012, 01:28 PM
  #46
BigKitty
BigKitty's Avatar
Lose the sunroof!
Old 12-25-2012, 01:41 PM
  #47
SanDiegoBert
SanDiegoBert's Avatar
Originally Posted by BigKitty
Lose the sunroof!
Sunroof??
Old 12-25-2012, 02:03 PM
  #48
NSC5
Support Corvetteforum!
NSC5's Avatar
Received 1,100 Likes on 742 Posts
It is interesting how much modern creature comforts and safety equipment have added to vehicle weight. I came across the specs for a 1963 IH Scout SUV which was a small vehicle but not designed to be especially light. Although the engine is an I-4 of 152 CID this was made using the larger 304 CID V-8 with one bank truncated and these engines were of cast iron and definitely not built to be light. So this 1963 low tech SUV had a base weight of 2,800 pounds with all fluids in place. Even with this low base weight there wasn't much capacity left before it hit its rated 3,200 pound GVW
Old 12-25-2012, 02:05 PM
  #49
CPhelps
CPhelps's Avatar
Plus the fact that the C7 will likely have an all new aluminum frame designed from the ground up to be aluminum, in an overall smaller car, it wouldn't surprise me if the C7 aluminum frame is lighter than the C6 Z06/ZR1 frame.
Lose the sunroof!
Done!
Old 12-25-2012, 02:12 PM
  #50
k wright
k wright's Avatar
3000 pounds.
Old 01-07-2013, 11:54 AM
  #51
BeaZt
BeaZt's Avatar
St. Jude Donor '14
A few more days and we will know
Old 01-07-2013, 12:01 PM
  #52
Jet Streaming
Jet Streaming's Avatar
They should be able to knock at least 100 lbs off of the C6 weight maybe more depends how much aluminum is in the new frame.
Old 01-07-2013, 12:28 PM
  #53
Rapid Fred
Rapid Fred's Avatar
Received 1,314 Likes on 754 Posts
2,9XX is would be a magic number for marketing purposes and surely was the target. Something that begins with a "29" would provide huge bragging rights.
What with aluminum, magnesium and CF substitutions, the C7 team will have tried every trick in the book to get to that point. My prediction is somehow they announce this thing with a weight of 2,9XX lbs (but read the fine print ).
Old 01-07-2013, 12:30 PM
  #54
Dudeurgettnavette
Dudeurgettnavette's Avatar
I'm guessing 4020 with the new awd system
Old 01-07-2013, 12:36 PM
  #55
BeaZt
BeaZt's Avatar
St. Jude Donor '14
29XX, that is a game changer!
Old 01-07-2013, 12:48 PM
  #56
69L79
69L79's Avatar
Location: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
No idea. But, if GM can come thru with a 3,000 lb base Vette, that would be special.
Old 01-07-2013, 12:49 PM
  #57
BlueOx
BlueOx's Avatar
Nah, still lighter than the C6 GS coupe.
To What do you think the weight of the C7 will be?
Old 01-07-2013, 01:42 PM
  #58
B-Myster
B-Myster's Avatar
3013 lbs on 1/13/13
Old 01-07-2013, 01:44 PM
  #59
Bill17601
AIR FORCE VETERAN
Bill17601's Avatar
3050 lbs
I was wrong...but not to far off
Old 01-07-2013, 01:54 PM
  #60
BlueOx
BlueOx's Avatar
Like many, I can only hope it will start with a 2.
That would blow my mind!
Quick Reply: What do you think the weight of the C7 will be?
