2014's on the road
Just a guess but it might be shorter (48") by 1". The width is harder to guess as the padding of the camo messes with the apparent width.
Since they went back and used the LT1 engine designation is it possible they are also going back and using a C4 style tail light shape?Not round,not half like the Camaro,but a little of both....
What do think the width of the C7 will be?
I've never really thought about width as the camo/padding just makes it too hard to tell. The only reason I thought about the height was because it looked short next to other cars in spy shots. That is the one place where camo has no effect.
Ignore the camo and make a guesstimate from the rear view mirrors, you can almost see where they connect to the body at the base
#33
I think it's easier to look at the width over the "B" pillers and then judge the distance the rear fenders stick out. I doubt if there will be any change in the width over the "B" pillers(C6 vs C7) as that would change the size of the passenger compartment, which I doubt will become smaller on the C7.
#34
Your estimate seems correct. The ones in the pic do look good given the quality of the photo. Tail lights, however, are a different story.
#35
#37
This image from one of the teaser videos has had a few of us thinking that they threw us a hit on the subject.
#39
Definitely larger then those shown in some of the spy shots. I'm guessing the car closest to the camera is a Hi-Po version as it appears to also have a full width spoiler. In the earlier spy shots, the cars with the smaller exhaust tips appeared to have a small spoiler about the same size as the base C6.
