New leak on jalopnik!
Old 12-17-2012, 03:42 PM
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Support Corvetteforum!
Scissors's Avatar
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Looks almost exactly like the original Jalopnik rendering. The splitter is about the only difference.
It appears crow will, indeed, be eaten by some.
Old 12-17-2012, 03:45 PM
Chicago1
Chicago1's Avatar
Jalopnik got it right awhile back then the cad drawings then the Keeks thing yet people are in denial
Jawnathin
Jawnathin's Avatar
Nothing new here, but solid confirmation from GM that the leaks were indeed the car.
Old 12-17-2012, 03:46 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
It doesn't to me. On this illustration the vents are lower, the lights are bigger and there is a more of a "curve" in the hood.
Old 12-17-2012, 03:48 PM
RUN4CVR
RUN4CVR's Avatar
I agree. Definitely bulkier and sexier than the renderings.
Old 12-17-2012, 03:49 PM
evowake
evowake's Avatar
Subtle details here in this service man. sketch that make it even better!
Old 12-17-2012, 03:58 PM
John T
John T's Avatar
Originally Posted by Process Black
AND the license plate mounting location.
I would like to polish those fenders
Old 12-17-2012, 04:02 PM
You_Vette_Your_Ass
You_Vette_Your_Ass's Avatar
The side gill/gash-thing is too gaudy... What purpose does it serve? I hope it looks better when the rest of the car is visible.
Old 12-17-2012, 04:09 PM
rcallen484
rcallen484's Avatar
Don't we see a front license plate holder right in the middle of that "grille"? Hopefully it can be removed seamlessly if unnecessary.
Old 12-17-2012, 04:19 PM
CandyRed77
CandyRed77's Avatar
A year and a half ago I talked to Tadge Juechter about the lack of a decent place to mount a front plate on a C6 and he mentioned they came up with a good sollution for the C7 that would both look good and still allow for the huge air intake opening they wanted for the race cars (they didn't want the split opening as the C5 has). I think what we are looking at in this drawing is a removable part mounted in the opening. So if you need it for a plate, leave it in, otherwise, take it out
Sonny
Old 12-17-2012, 04:23 PM
BlueOx
BlueOx's Avatar
Hmmm, this view hints that the hood vent may be on all of the models.
I wish they had an illustration of the air diverter up through the engine compartment and to the hood vent.
rcallen484
rcallen484's Avatar
Sonny
Looking at it again, and with the info you have provided, it DOES look like something that could just slide into place and have some simple retainer on the inside edge. THANKS.
Old 12-17-2012, 04:24 PM
  #33
CaryBob
CaryBob's Avatar
Sonny
I agree. That is also consistent with all the renderings...
Old 12-17-2012, 04:27 PM
  #34
Hemi Dave
Hemi Dave's Avatar
+1
Old 12-17-2012, 04:29 PM
  #35
mitchydkid
mitchydkid's Avatar
This drawing seems to show the crease that runs along the top of the fenders, along the inside edge of the headlights, and then to the leading edge of the nose. None of the renders got that as well as I thought they should according to the Omega leak.
Also, I like the nose having a bit of an "overbite" where the top of the nose is looks to hang out a bit over the bottom... ala C3.
-D
Old 12-17-2012, 04:33 PM
  #36
JoesC5
JoesC5's Avatar
Received 1,700 Likes on 1,214 Posts
Lot of small differences from the "renderings" that gives it a much better appearance. Looks similar but isn't. BTW, that's an air dam/deflector(C6 ZR1 also had them) shown in the illustration that is bolted to the lower A-Arm, not a splitter that is bolted under the chin.
Old 12-17-2012, 04:36 PM
  #37
458it
458it's Avatar
Originally Posted by Gobot
Cool. Looks like a Ferrari 599gto
its not cool when a 2013 car looks like a ferrari that was produced 8 years ago or smth.. so i hope in person it does not look like 8years old ferrari. Do u understand that u **********?
To New leak on jalopnik!
Old 12-17-2012, 04:43 PM
  #38
Nitrous Oxide
Nitrous Oxide's Avatar
They will say that a crease here and there is off by half an inch, and therefore Jalopnik was total fiction.
Old 12-17-2012, 04:48 PM
  #39
NW94Z
NW94Z's Avatar
Do the rotors appear to be two piece units to anyone else? Looks like that disc bolts up to the hat to me.
  #40
DREAMERAK
DREAMERAK's Avatar
St. Jude Donor '12-'13-'14, '16
I think it's called CYA.
Quick Reply: New leak on jalopnik!
