You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
"The aftermarket is a big slice of our bread and butter. There will be a crate engine and ECM for that engine. Rejoice!"
"You don't have to take my word for it. I hope that tuner or tuning company has a replacement plan for 2014 LT1. $14,995.00 is a lot of money. Engine is tough however the precision in which it works and has to maintain constantly is not for the lite heart."
I suppose I always knew it will be more than the LS7 crate.
Believe it when I see it. Despite the added bits and new tech(and cost), it'll be shared across a butt ton of vehicles/motors. The injectors and fuel rail might be used on 4 vehicles by model year 2015. The ls7 has tons of ls7 specific parts and possibly just as important, more hp odds are. Ls1's sell for less then ls2's, yet they theoretically cost the exact same to make.
It makes sense. The LS7 is far simpler in design. The VVT, DI, and AFM area all extra. About the only thing the LS7 has that this one doesn't is the fancy rods. The LS7 sells for $12,000, it's about right.
Secretly I was hoping it would be around $10,000 but the parts satisfy the $15,000 tag.
12k for an LS7? Most of them I've seen are 14-15k.
Brand new LS7 crate motor is around $11,500.00 at a place I just looked at. Wouldn't the LS3 be the comparison most appropriate? It is the price of base C7 vs base C6 some are concerned about.
You're forgetting ls7 specific everything in the heads(including heads), pistons, crank, blah blah blah. I have no clue but let's just say there are 50,000 z06's out there. So that's 50,000 cars that need a potential replacement motor, and all replacement parts, and all individual crate motors. Even if I'm over generous and say there are 150,000 ls7's available(or equivalent in parts), JUST the c7 should hit that number in 5 years. That's not including the other cars that will have the Lt1, replacement motors, crates, blah blah blah. Cost wise it should come in at ls3+cost of new tech+premium over ls3, which should come to way less then the ls7's msrp of $12,999. That msrp I saw AT LEAST 3 years ago so it's gotta be a tad more now.
Would you say the heads on the LT1 are closer in design to previous LS? It's a design from scratch.
The big cost is "cost of new tech". Just the DI parts alone are $$$. The casting material of block and head, the crank, the caps, the pistons, all of these are a lot more expensive too. Definitely LS7 block like in material cost but with extra goodies that cost $$$.
