AFM-Used by other GM engines?
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Has GM used the LT1 version of AFM in any of their other engines? Recently? My basic question is: Is this a brand new design or has it been field tested/used elsewhere in the GM line?
Yes it is in the auto Camaro, Tahoe, Truck line. They have the bugs worked out, and I like it in my Tahoe. Do a search on the Camaro Forums and you will hear guys bitch about it, but they just put in new lifters with a big cam and tune it out if they don't like it. If you are a guy that mods your motor you will get rid of it. If you drive it around town/out to dinner you will like the added mpg. I think it is a win win.
Jimmy
The LT1 is the first GM engine to be designed from the beginning with afm in mind.
The various items such as reversed intake and exhaust valves. The 2 degree angle. The new throttle body. The new box manifold. The direct injection. The new EGR design.
This truly is a new engine design with AFM as an integral part of the design.
Previous v8 and even v6 designs of AFM were nowhere near as integrated or as complete.
Strong rumors that automatic transmission equipped vehicles better absorb power pulse differentiation (sp) so the manual version might not receive afm.
The one kicker will be aftermarket exhausts so popular will be more challenging with AFM to achieve pleasant sounds in both modes.
I look forward to the eventual efforts by aftermarket companies. I believe thecamaro automatic with AFM s were an initial challenge.
Of course the L99 was no where near as advanced as the new LT1 nor were any previous v6.
And then of course there is the voided warrenty issue.
My bet: Manual transmission C7s will have AFM.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Some good responses but maybe my concern wasn't stated well in the OP. Since the LT1 is a new design, as pointed out, maybe AFM won't work well, or has some unknown wrinkle that we haven't seen yet that will make the engine ultimately a time bomb. Kind of like what is happening with the LS7 valve scenario?
And yes, AFM has been discussed but my searches didn't result in any kind of discussion that addressed what I am asking.
I have a few thoughts here:
1) If this is still an issue, then this would stand to reason why a DCT would not happen along side AFM.
2) I would imagine that this isn't an issue anymore. From the videos I've seen, there's no pulse at all anymore. The change between modes is seamless.
That being said, since GM has been working on DCT technology, I would imagine that they have this AFM thing down to a science now. They won't be able to introduce a DCT without it. And since this motor is built from the ground up with AFM in mind, it would make sense to me that the AFM kicks on and off gradually, faster or slower, depending on the driver's request for speed changes (up and down).
I am vette less at the moment and trying to decide if I should wait for the new C7, buy a used C6, or buy a used C6 once the C7 is out and folks start trading in.
You will see a forced induction system in Later iterations and the engine will again come with GM s flawless execution and 100 thousand mile warranty.
I can't say how the engine will react to early adopters to aftermarket mods though...ie cam/heads/headers or superchargers..
Might be better to buy the factory higher performance versions early on if you are after greater performance levels.
As time marches on I am confident aftermarket tuners will find reliable ways to increase hp of base models etc....
By with confidence
Is there an elegant (i.e., non-kludge) way to "get rid of it"? Certainly you are left with those four risers cast into the block that no longer have any purpose. If you just replace the lifters, do you leave all the solenoids, valves, etc., under the valley cover there so the ECM continues to signal the solenoids to activate and turn lifter oil flow on and off, which doesn't affect the new non-AFM lifters? Or do you reprogram the ECM and hope for no unintended consequences?
AFM problems (450 hp, 0.500-inch-lift cams, or high rpm): Half the lifters and their corresponding cam lobes are unique. Comp and LPE offer AFM-style cams, but they're limited to 0.500-lift because the special lifters don't work with a reduced base circle. If you raise the rev limiter beyond the L99's 6,200-rpm limit and then run up against it, Jannetty Racing says the AFM lifters will fail. Best option: Reprogram the ECU to delete AFM, then install a conventional cam and lifters.
VCT phaser woes: Valve-to-piston contact can occur with bigger cams from too much advance. Comp Cams has a phaser limit kit that allows aggressive cam profiles with up to 220 degrees duration at 0.050. Above this, either: increase intake centerline 2 degrees for every 4-degree duration increase, change pistons, or delete VCT; the latter requires installing a LS3 front cover and a conventional timing set.
Valve float: L99s don't have the LS3's hollow-stem intake valves. When switching to high-lift cams, LPE recommends installing lighter LS3 intake valves.
Read more: http://www.hotrod.com/techarticles/g...#ixzz2CcCzFVwN
Received 8,930 Likes
The first time I saw AFM or Displacement on Demand was at the 2002 Detroit Autoshow. GM had an LS truck engine on an engine dyno and was demonstrating how they used the dyno to test various aspects of the engine operation including shutting off some of the cylinders and turning them back on while the engine was operating. That thing ran for a lot of hours every day of the couple week long show, saw it again at the next show I went to in 04 and then in 05. They got enough test hours just running that thing through several years of shows. They would troop 20 or 30 people at a time into the booth run the engine for 5 minutes or so and then troop in another 20 or 30 people and do it all over again.
Bill
Bill
Bill
Bill
VETERAN
Already stated by CF members that no AFM on Manuals
If you go back to the post on SEMA, (just two weeks ago), two different people shared that Corvette Reps stated that the new C7 would not have AFM on the manual tranny. Do a search and read the post. Obviously that doesn't mean that this is accurate however.
Keeks, what say you dude????
Premium Supporting Vendor
With the main parts and the system design being carried over from the tried and true systems already in use, likely the only real issue with deleting the AFM on the new engine will be tuning to eliminate it from the PCM. On the current setups it's a simple enable/disable dropdown, let's hope for the same.
__________________
800-456-0211 / PM /E-mail Facebook AIM or Yahoo: JSSDPC
SDPC since 1929 thanks to you guys! WHIPPLE Superchargers, Procharger, Magnuson,
Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, Yella Terra, HPTuners, 7.400" pushrod set (other lengths available)
