"Automobile" magazine has posted new spy photos
That much is obvious. I'm just saying the devil is in the detail, and I doubt Jalopnik got them all correct. Honestly, the quality of that rendering is **** poor compared to what other can do, it is very rough. Compared the the Trinity rendering this thing is hardly realistic, and even the Trinity (no offense, it is great work) can be seen as unrealistic compared to other renderings out there. It is a factor of time. ***this isn't to discredit the work done to make any renderings***
I'm just saying it seems a little different is all.
-Jalopnik has gotten a TON of basically free PR for their web site...I mean to equal the word-of-mouth they have gotten would have cost many thousands otherwise.
-The Trinity Animation folks did spend a TON of time doing the animation but they also have a major portfolio piece unlike anyone and their name has been all over the place in major magazines and web sites.
-Omega Tool got major PR that they are working with GM but otherwise it isn't good news about their security.
I see quite a few differences. Looking at the spy shot, I see that the grille opening is narrower(width) and does not have the arrow pointed ends. Also the top of the grille opening on the Jalopnik drawing shows about an ich of surface up to the beltline crease, whereas the shy shot shows the top of the grille opening at the beltline crease. To my eye, I don't think the front fascia is as pointed in the spy shot as with the Jalopnik drawing. Could just be because of the different angles of the front between the photos.
The hood opening on the spy shot is quite a bit smaller, width and length with the front of the hood placed much further back(compare the headlights to where the camo straps are achored to the body at the corners of the hood opening.
The hood on the spy shot seems to be covered with the mesh and close to the front of the hood you can see two dark slits that appear to be heat extraction slots(spaced around 6-8" apart).
The front fender opening at the leading edge appears to have Gurney flaps as part of the fender panel as soes the rear fenders. What is funny(to my eye) is the rocker panels. Behind the door, it appears to be taperted in quite a bit and then the rocker panel flares outward significantly to provide a large Gurney flap in front of the rear wheels. Take a look at a 1980 C3 for the same styling.
It appears that there is no any padding on top of the hood at the rear, so I'm guessing not much of a power bulge( I realize that the Jalopnik drawing is showing a significant ZR1??? power bulge).
The horizonal crease on the door mirrors reflect the overall theme of the car; that of being more edger then the C6.
Looking at the square on side shot, I easily see an additonal 6-8 inches added on to the overall length because of greater front and rear overhangs. Don't really see that they would add any real weight, as its only plastic front and rear fasica's I'm talking about
You have to remember that each entity is getting what they want out of all this...
I'm pretty sure Jalopnik wouldn't have done it if it didn't mean a ton of PR but to get that PR, it was important for it to be accurate. SO the real answer is BOTH! They will ride this PR wave for a long time...because it is so accurate!
St. Jude Donor '13
The Omega leaked bumper makes it look like they could be round, but the red lights in the picture are clearly semi-circular ... like the camaro lights.
The Consigliere
Received 5,443 Likes
I have a hard time "seeing" what that thing looks like under all that camo. Others are much better at that than me.
There's something about the length of the car when viewed in the broadside. The proportions are different, even a bit odd.
They don't have the time to worry about building camo ZR1's to run around the planet at this time. Good chance the suppliers haven't even started work on any production tooing for the ZR1??? They are working on finalizing the base C7's tooling etc, plus doing some work on preproduction parts for engineering to mock up the ZR1????
What is sad to me is I might prefer the shape of the taillights on the black camouflage covering the back of the car more than the real taillights. I hope I am wrong about that but a round shape taillight struck inside a plastic rectangular shape insert sounds cheap n ugly.
#33
It appears to my eye, that 3-4 inches added to the front and 2-3 inches added to the rear. The front is easy to see as they can't add any padding to the grille opening(blocks the air flow), but they can add padding to the rear to throw off the lines of the car
#34
The Consigliere
Additional overhang would not be an improvement.
#35
GM has allready said no ZR1, etc for 2014. While GM most likely has designed/engineered and has some suppliers working on ZR1? items, GM is concerned about getting the base C7 to market. After that, then they will move the engineers over to getting the ZR1??? ready for the later "new and improved" version of the C7. GM only has so much talent to spread around, so they dole out the work load as needed. After they get the base C7 to market, those engineers, etc will switch over to getting the ZR1? ready to release in a year or two down the line. Like the C5 and then the C6, I suspect we will see the coupe released first, then 6 months later the convertible. They get the coupe up and running, working out the last minute production details, then they go to work on the convertible, get it to market and then they go to work on the ZR1???.
#36
Now I know there could be padding in there adding lenght, but I don't think so, especially comparing it to the jalopy renderings.
#39
I gotta tell ya, even though they said the C7 was supposed to be smaller in some way, that car looks as big or even a little bigger than the C6.
#40
CI 3-5-6-7-8 Veteran
IMO someone has effed up and Jalopnik saw the car. They've got the main body line curves dead on. Look at the quarter panel line and then how high the fender line is creating an overly high belt-line; seems to be the norm in modern design (see the new Camaro).
Trinity rendering based off of Jalopnik
Latest spy photo.... other side, but you can really see the quarter panel/fender creases match exactly.
Just my $0.02, but I think we've basically seen the car. Overall I do like it, but if given the choice I'd go buy the new Viper in a heartbeat. Far sexier/dynamic design.
