Go Back   Corvette Forum > C7 Corvette > C7 General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C7 Corvette Discussion not covered in Tech Sponsored by
Kerbeck Corvettes
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-01-2012, 08:51 PM   #1
ThrottleUp
CF Senior Member
Houston Events Coordinator
Default 2500 lb C7 Corvette possible?
A 2500 pound weight Corvette will go a long way to giving the C7 a phenomenal new lease on life. Many benefits will accrue to a high-powered sports car with weight near that number. Decreasing Lbs per HP is probably the cleanest path to improve overall performance. Side benefits are improved gas consumption improved tire wear, even smaller tires will yield slot-car like traction on curves. And with less weight there may be considerably less stress on most stressed components.
What kind of weight target has been mentioned for the C7. Or do we have to wait for the C8 to get real on weight?
I know there have been thousands of legislated federal rules over the last 40 years which impact weight in all cars, but I can't seem to forget how phenomenally a 1969 Lotus Elan I once owned handled, and that car weighed around 1,750 lbs (less after I removed the seat belts lol). In my mind this would be a goal worthy of our best engineers' best efforts.
ThrottleUp is offline   Reply With Quote
Old 07-01-2012, 08:54 PM   #2
Jinx
CF Senior Member
Jinx's Avatar
No, not possible.
The Mazda Miata barely squeaks under 2500 pounds.
Jinx is offline   Reply With Quote
Old 07-01-2012, 09:09 PM   #3
B Stead
CF Senior Member
Quote:
Originally Posted by Jinx View Post
No, not possible.
The Miata is a unibody car. It's not a car with lightweight technology but just a small car with traditional construction.
The Lotus Elise is about the same size as the Miata and it comes in at about 2000 pounds. It has an aluminum frame in tall cross sections and a fiberglass bodywork.
The Corvette has a hydroformed steel girder frame (in tall cross section) and a fiberglass bodywork.
The Z06 Corvette has a hydroformed aluminum girder frame (in tall cross section) and a fiberglass bodywork.
And so the Corvette will pretty much be okay if it doesn't change its current construction type.
However the Corvette could improve fuel mileage, while keeping the V8, but going to the Northstar engine.
B Stead is offline   Reply With Quote
Old 07-01-2012, 09:24 PM   #4
Jinx
CF Senior Member
Jinx's Avatar
The Lotus Elise also had under 200hp, cost as much as a Corvette, was unrealistic as a daily driver for most people, and IIRC only came to the US with special exemption from 2.5mph bumper standards.
Old 07-01-2012, 09:31 PM   #5
OnPoint
CF Senior Member
Support Corvetteforum!
OnPoint's Avatar
Location: Wichita Kansas - 2011 Callaway GS 606HP & 2010 ZR1 638HP
I don't see the Northstar engine coming back.
And C7 will be doing quite well to hit the ground around 3,100 at its debut.
Perhaps if carbon fiber production techniques continue to push the time and cost of that product down, we'll be able to see more use of it in the Vette down the road, which would help.
OnPoint is offline   Reply With Quote
Old 07-01-2012, 09:55 PM   #6
B Stead
CF Senior Member
If the Corvette weighed less then it could have a smaller engine and transmission while keeping its power-to-weight ratio.
But the only smaller engines with good balance are the inline-six and the boxer-six.
Well, the Lincoln LS had a 32-valve V8 at 3.9L size. The 32-valve Northstar sitting in my garage with 185,000 miles on it is 4.6L size.
Considering the Corvette's very good construction type, one way to lower weight would be the 98" wheelbase that I suggested in another subject.
But Bowling Green is doing a $131 million dollar refitting and we don't yet know what that means for the Corvette.
Old 07-01-2012, 10:04 PM   #7
B Stead
CF Senior Member
Horsepower is not an issue when lightweight vehicle technology is the subject. Only power-to-weight ratio should be considered.
But the Corvette does have a better power-to-weight ratio than the Elise. However, the Elise can do quarter mile times in the 13's.
A relative of the Elise, the 2-Eleven, makes 1477 pounds weight in road trim. So the Elise is not really that sparten even though it weighs 500 pounds less than a MX-5.
Old 07-01-2012, 10:07 PM   #8
jackhall99
CF Senior Member
St. Jude Donor '11-'12-'13-'14
jackhall99's Avatar
You nailed it Jinx. The heck with its size and weight; it is not livable in daily use.
The OP has too much time on his hands and is just stirring the pot. He knows, as we all do, that anything even at 3,000 pounds is unrealistic or unlikely, let alone 2,500 pounds.
jackhall99 is offline   Reply With Quote
Old 07-01-2012, 10:10 PM   #9
jackhall99
CF Senior Member
jackhall99's Avatar
Quote:
Originally Posted by B Stead View Post
.... A relative of the Elise, the 2-Eleven, makes 1477 pounds weight in road trim. So the Elise is not really that sparten even though it weighs 500 pounds less than a MX-5.
Have you EVER driven one, let alone lived with one of these flyweight cars? I think not.
After you live with one in daily use for a while, come on back and tell us all about it.
Old 07-01-2012, 10:14 PM   #10
B Stead
CF Senior Member
The Corvette is a flyweight car in a 400 horsepower category. Go compare it to a Camaro.
I want a 3000 pound Corvette with 98" wheelbase and a 32-valve Northstar engine. Also, a 47.7" roof height.
Old 07-01-2012, 10:29 PM   #11
jackhall99
CF Senior Member
jackhall99's Avatar
To your first point, I know that! You don't have to tell me anything about a Camaro or any other car.
As to your latter point; don't hold your breath.
Old 07-01-2012, 10:35 PM   #12
BlueOx
CF Senior Member
BlueOx's Avatar
Ladies and Gentlemen....announcing the new 700 hp 572 ci COMPLETELY CARBON FIBER MOTOR in the new C7 Corvette!!! Weighing in at a measly 150 lbs, this new motor is showcased in Jay Leno's new C7 AWD, 4 seater, weighing in at a total 2743 lbs! MSRP $498,000
BlueOx is offline   Reply With Quote
Old 07-01-2012, 10:45 PM   #13
jackhall99
CF Senior Member
jackhall99's Avatar
Quote:
Thanks for that.
Old 07-01-2012, 10:45 PM   #14
ThrottleUp
CF Senior Member
That's rich! literally at $498K....
Old 07-01-2012, 10:47 PM   #15
shank0668
CF Senior Member
shank0668's Avatar
The interesting thing I think is that the new Cadillac ATS comes in at 3200 pounds. That is pretty stinken light for a sedan. However, this has nothing to do with a corvette.
shank0668 is offline   Reply With Quote
Old 07-01-2012, 10:50 PM   #16
BlueOx
CF Senior Member
BlueOx's Avatar
Yeah, and a few years from now the GM small block V8 will produce over 800 hp and weight 110 lbs. A few years from now people will also still barf at the idea of a V6 in a Corvette.
Old 07-01-2012, 10:55 PM   #17
z51vett
CF Senior Member
z51vett's Avatar
Send a message via AIM to z51vett
That was the wheel base from 1963 to 1982. 98 inch wheel base down from the old wheel base of 106 if I remember correctly.
z51vett
z51vett is offline   Reply With Quote
Old 07-01-2012, 10:59 PM   #18
z51vett
CF Senior Member
z51vett's Avatar
Whats so great about a northstar is the 32 values or what it's wider and is a packaging problem and its old tech. Oh and my 427 1967 vett weighed in at 3000 pounds give or take.
z51vett
Old 07-01-2012, 11:10 PM   #19
ThrottleUp
CF Senior Member
The new C7 (ok not really): 2,300 lbs and a V-12...sure it's a one-off probably built by a rich man and the design is well.... special, I guess Chevy can't beat this and meet government regs at the same time is what I hear people saying. If you give this thing one more foot in length you can probably have almost as much storage space as in the Vert's trunk (note the space behind the seats in one of the photos).
As to can't live with them and they're "uncivilized" I guess that's up to you. I lived with my Elan for 2 years, drove it all over, made interstate trips and never felt I was lacking space....... maybe because that's what sports cars were back then. I finally let it go when I bashed it into an unmovable object...
http://www.moal.com/04_gallery/11gatto/index.php
http://www.autoblog.com/2010/08/12/m...powered-gatto/
http://www.nytimes.com/2012/02/26/au...pagewanted=all
And Shank has a good point there, I'm anticipating that the ATS will break some old preconceptions about what America can build..... but we'll see. I hope Chevy engineers are as innovative on the C7 as the Caddy ones appear to be.
Old 07-02-2012, 12:46 AM   #20
Racer X
CF Senior Member
Racer X's Avatar
I did. I used it as a daily driver and enjoyed it greatly. I was not exactly svelte at the time at 30 pounds overweight. The Elise was centainly spartan as compared to the Corvette, but it was not a problem for me or my wife.
Perhaps my ownership of the Elise allows me to be a lot more appreciative of the posh current Corvette interior.
Racer X is offline   Reply With Quote
Reload this Page 2500 lb C7 Corvette possible?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
