4xxhp will not be enough
#121
I prefer my punes simply pitted.
Old guys don't hate horsepower. We're just realistic about what the next Corvette needs in order to be a great sports car that sells well in its first year.
I bet C7's extra inch or so of wheelbase has everything to do with a more favorable CAFE footprint. As for GM's weight problem, it hasn't applied to Corvette since 1997. I bet C7 renews its reputation for lightness.
.Jinx
.Jinx
#122
[QUOTE=LS1LT1;1580990566]That might be all it would take to make the base C7 one seriously fast car.
This is what I'm hoping the base C7 will be, that and a slightly rearward weight bias.
#126
Assuming that the base C7 will even have an aluminum that is of course.
#128
frame ~136 lbs savings
engine cradle ~10 lbs savings
floor boards ~14 lbs savings
Total weight savings ~ 160 lbs.
Of course, the aluminum frame in the C7 could be a little different(so it could be used in the targa and convertible) in design, so the weight savings might be slightly less then 136 lbs.
#129
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
If we kept the same weight but increased power to 450-475, I think people would be plenty happy. The Corvette has never been the de-facto fastest car out there, but it has been the best all-around performance value. I think 475 hp @ 3300 pounds would accomplish that.
#130
But think how great 3050 lbs with 450 HP would be. The lower weight would be the same as an additional 15 HP when accelerating, and the lower weight would give better braking, and better handling in the twisties. Smaller, lighter wheels/tires can accelerate a lighter car better then larger, heavier wheels/tires. Smaller, lighter brakes can stop a lighter car better then larger/heavier brakes can stop a heavy car.
#131
jb_va2001 Most drivers could drop 50 pounds, some even more.
#132
I would think GM would want to make sure their performance numbers for the base c7 are on par with the new GT500. Especially if the zl1 bumps it's hp up. Why would I even by a c7, other than looks, if both my sibling and somewhat rival outperform me?
#133
I hear what you're saying but I would still rather see it closer to 3100/3000 pounds regardless of the power increase.
#134
I would think GM would want to make sure their performance numbers for the base c7 are on par with the new GT500. Especially if the zl1 bumps it's hp up. Why would I even buy a c7, other than looks, if both my sibling and somewhat rival outperform me?
#135
That's why they offer horsepower upgrades if you want more. The Z06 and the ZR1 and the 427 Convertible are the upgrades over the base horsepower.
#137
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Other then the initial years of the emission years, GM has never made the Corvette's base engine's horsepower to match the highest horsepower within it's own ranks, much less any competitor.
That's why base HP becomes such an issue when compared to the Mustang at the same or near price point.
Engine Specifications 1967 Corvette
Displacement, liters/cu inch
5.35/327
5.35/327
7.0/427
7.0/427
7.0/427
7.0/427
Bore × stroke, inches
4.00 x 3.25 4.00 x 3.25 4.25 x 3.76 4.25 x 3.76 4.25 x 3.76 4.25 x 3.76
Fuel Management
1 x 4-bbl. 1 x 4-bbl. 1 x 4-bbl. 3 x 2-bbl. 3 x 2-bbl. 1 x 4-bbl.
Horsepower @ rpm
300 @ 5,000 350 @ 5,800 390 @ 5,400 400 @ 5,400 435 @ 5,800 430 @ 5,200
Torque @ rpm, pound-foot
360 @ 3,200 360 @ 3,600 460 @ 3,600 460 @ 3,600 460 @ 4,000 450 @ 4,400
#139
Remember the Lexus commercial, "It isn't REAL performance unless it's wielded with precision." It's a way of trying to redefine performance that you don't actually have, the less is more argument.
Corvette may only need the perception if people are otherwise wowed. There's probably going to be one big surprise in the offing, a killer must have feature. The Mustang didn't give us its best shot at first either. Once things stabilize and the hoopla calms down, that's when they go back to the tried and true Detroit formulas, bump the hp, the weight goes back up as they pile on equipment, make special editions. The best is saved for last. My $0.02
As JB said!
As JB said!
#140
Also, please see all previous posts in this thread.
.Jinx
