Help! Anyone know Borla X-pipe bolt size?
Old 03-09-2019, 10:12 AM
Rickmd
Rickmd's Avatar
Default Help! Anyone know Borla X-pipe bolt size?
Acquired used Borla x-pipe 60547 without front flange bolts. Anyone happen to know size and length required?
Old 03-09-2019, 01:22 PM
Corvette farmer
Corvette farmer's Avatar
Most just reuse the factory bolts when you swap them out.
Old 03-09-2019, 02:58 PM
Rickmd
Rickmd's Avatar
The factory bolts are studs that thread into the x-pipe flange. The Borla x-pipe is not threaded to receive the factory studs which are 10MM. The Borla instructions say to use the bolts provided. None were provided . If they were, they would have to be 8mm to pass thru the Borla flange holes. This seems way to weak. I am trying to drill Borla's flange holes larger to allow use of 10mm bolts. The flanges are work hardened from welding. I've used up 5 drill bits so far and I off to try to find solid carbide bits ( on Saturday?). Good luck to me. By the way, the bolt length required is 3 inches.
Correction: 3" too long. Could not tighten. Ran in threads and had to add washers. 2.5" will work better.
To Help! Anyone know Borla X-pipe bolt size?
Quick Reply: Help! Anyone know Borla X-pipe bolt size?
