Corvette Forum
Go Back   Corvette Forum > C7 Corvette > C7 General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette News & Rumors, Concept Art, Drive Train and Design Speculation for the future C7 Corvette Sponsored by
Kerbeck Corvettes
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-26-2008, 08:18 AM   #1
I Bin Therbefor
CF Senior Member
Default C7 Engineering Challenge
Assumptions, if the statements coming from GM about the C7 being exciting to drive by maintaining or bettering the current power to weight ratio are true, it's fairly straight forward to do some basic calculations on the power and weight of the C7. I've taken as a starting point the new 5.5lt high tech V-5 being developed for ALMS GT2 racing in 2010. My numbers for the current C6 came from the DEC08 issue of Car and Driver. The task is to maintain a weight to power ratio of 7.5lbs/hp while keeping the economics under control..
The first pass results in a C7 of 387hp at 2904 lbs from a 5.5lt V-8 engine. A weight loss of 370lbs. Not an easy challenge. The most obvious approach would be to build all Corvettes on an aluminum chassis that was optimized for aluminum, not the current compromise design which is required because both aluminum and steel chassis are built on the same line. Such an optimized design can accomodate a Targa roof and still drop roughly 100 lbs. We're still left with 270lbs which must be eliminated. The next step would be to look for other weight saving use of aluminum, other light alloys and possibly high strength steel. I don't have the least idea how much this can help but I do know that GM is looking at friction welding to joint light alloys with steel, so there is the potential for using the proper alloys for weight loss and still not breaking the assembly budget. There would also be some weight loss from eliminating the more complex methods of joining the materials presently in use.
If the 5.5lt high tech V8 is to use DFI, we can raise the power output to 400 and actually get better economy over a non DFI engine, that would let us build a 3000lb car which would leave us with 170lbs to eliminate. Still not an easy task.
So it seems that a combination of engine technologies and some weight loss would enable the C7 to maintain the prsent day excitement and still improve the gas milage. The easiest approach seems to be to utilize some of the already developed engine technologies that GM has demonistrated on the experimental push rod V8s in the slightly smaller displacement of 5.5lts. Specifically DFI and VVT. Accompanied by some materials substitutions to reduce weight. This approach would apply to the entire GM line of vehicles, so some of ther engineering costs would be spread across the entire line. Lest I forget, there are gains to be had from improvements in the transmissions also.
I Bin Therbefor is offline   Reply With Quote
Old 10-26-2008, 06:03 PM   #2
Shrike6
CF Senior Member
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Support Corvetteforum!
Shrike6's Avatar
Downsizing can reduce weight, too.
GM
Shrike6 is online now   Reply With Quote
Old 10-26-2008, 07:25 PM   #3
Gearhead Jim
CF Senior Member
Problem is, all of this development work takes money, and GM ain't got any.
They can muddle along with the current C6 or a slightly warmed over version they could call a C6.5, for maybe another 10 years. After that, the CAFE requirements are gonna start killing them unless everybody WANTS to buy Cobalts.
GM needs to start making money before any serious work starts on the C7, and that's not going to happen very soon.
Gearhead Jim is online now   Reply With Quote
Old 10-26-2008, 10:37 PM   #4
jvp
jvp's Avatar
Send a message via AIM to jvp
Quote:
You might be surprised at how little money it can take to redesign the Corvette. The C5 was designed with as a little as $250M, total. That may seem like a lot to you and me, but it's chump change to GM, even in their current hurting situation.
Weight can be lost by the use of Al for the chassis, carbon fiber for the body, etc. But the costs are the concern. Another thing they can (and will) focus on in order to cut fuel consumption is aero. The C6 is currently pretty slippery at a .28 Cd. If they could drop that by a hundredth, it could help fuel economy significantly.
jas
jvp is online now   Reply With Quote
Old 10-27-2008, 01:42 AM   #5
proexpert
CF Senior Member
proexpert's Avatar
Maybe they spent $250 million on design, but does that including all the tooling and plant configuration costs?
proexpert is offline   Reply With Quote
Old 10-27-2008, 08:45 AM   #6
jvp
jvp's Avatar
Quote:
I'm pretty sure it did. Check All Corvettes are Red for confirmation of that (it's been a long time since I've read it). The Corvette has pretty much always been designed/built on a relatively shoe-string budget. That's what makes the thing so damned wonderful.
jas
Old 10-27-2008, 08:56 AM   #7
-vet
CF Senior Member
Default higher
DFI also contributes in another way. Because the air/fuel mixture is cooler the compression ratio could be raised to 12.5 to 1 which makes more power. Bucket seats are another area that could be engineered to reduce weight.
-vet is offline   Reply With Quote
Old 02-13-2009, 12:02 PM   #8
christopher04z06
CF Senior Member
christopher04z06's Avatar
Personally, I think GM should stop investing in so many rebadged Trucks, SUVs, and CUVs, and show commitment to world class cars and technology. How about "Professional Grade" cars.
Yes GM has some made improvements (like the Malibu, 2L-Turbo, CobaltSS, Solstice/Sky, Magnetic shocks, Supercharged LS9) but the competition is relentless. Advanced AWD, Twin Turbos, DSG Transmissions, true Hybrid "cars" on 2nd/3rd gen, rev-matching, and much more.
Honestly, the Corvette is already falling behind technologically compared to the Germans and Japanese its just that the chassis, weight, and powerplant are so good it still continues to perform (amazing platform). Great car! But come on GM, invest in core technologies and competencies and build great "cars". ..and market them properly and build brand equity. Be persistent. The best thing GM has going for it is the Corvette!
christopher04z06 is offline   Reply With Quote
Old 02-18-2009, 11:56 PM   #9
lt4obsesses
CF Senior Member
lt4obsesses's Avatar
The key phrase here is "by maintaining the current horsepower to weight ratio". This statement, if directly from GM is dead give away. First, stop thinking V8. Start thinking V6 and forced induction. The Solstice, as it sits, is what 2900 lbs? GM cutting Pontiac and Saturn? The Solstice and Sky already being built in Bowling Green? I think I have an idea what the C7 is going to be like.
lt4obsesses is offline   Reply With Quote
Reload this Page C7 Engineering Challenge
Tags
c7, engineering
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
