LTR has arrived...
The following 5 users liked this post by 17WhiteGS:
Blockburner (08-01-2023),
Jims Z06 (12-25-2023),
Lux (07-14-2023),
MeanRay1 (07-16-2023),
Thomasmoto (07-21-2023)
That's gonna be a serious set-up. 🔥 🔥
17WhiteGS (07-11-2023)
I want to touch it lol
Did your other setup ever run????
ya for a little bit a whopping 10 miles lol, Vengeance sold me a beat motor and by the time my motec and blower and everything came in 7 months went by and they thought i messed with it.... lol, and basically told me to kick rocks lol
it was a customers car though that they took it out of and they sent me the leak down test numbers and "said" they checked the oil. But when I finally went on the dyno after a 2 month dyno time wait, the pil pressure was dropping some and there was a ton of metal in the oil..
It got ripped out and sent to TKM, and TKM told me these things. 1. The rod bolts were hitting the windage tray, the #8 piston was jlhitting the reluctor wheel, and it also had a spare bolt floating around in the water pump.... haha
There is no way they didn't see metal in the oil, and they basically said you can sue us or him..
So F those guys, a bunch of work I've seen them do had issues plus a buddy of mine had one done by them and they didn't even put nuts in the motor mounts haha.
Needless to say I lost thousands. Yippie lol
Sorry to read about the bad luck from vengeance. You'd think since the report shows something wasn't Spec correct they would help you. Their advertising talks about Vetern ownership blah blah blah. A veteran stands behind their work. My brother got a dyno session there and never got the graph emailed.
How much power will this new engine make and what's going to be the power adders?
I've also got an LME custom stroker engine and love it.
Whats the difference between a LTR block and an LT4?
