Catch Can recommendations
Thought I would come to the Guru's... I have a 2014, Z51 that I installed a Edlebrock, E-Force (stage 1) supercharger on. What brand would your recommendation be, on a quality catch can that's plug and play. Even with the SC? Thanks
Received 1,762 Likes
ttt
MMS is a great catch can only need the wild if you have a blower on the car, Dont see a lot of 650 rwhp that is N/A motors in here.. Robert
A cyclonic separator (like the Mann & Hummel ProVent) will significantly outperform any traditional catch can. You can order them online from many sources, but you need to put together your own mounting and hoses.
ttt
So do you run one of these on your car & more so do you let all the this oil crap go back into your oil case are into your intake.. How good does this work on your car. Robert
I run them on every forced induction build I do now. I typically plumb their oil drain into the turbo/supercharger drain line (along with a check valve) so that any oil collected automatically returns to the pan where it belongs. The cyclonic separator (along with the internal coalescing filter) does a great job of making sure no liquid oil makes it to the lines going back to the intake or compressor inlets. I usually run a split return with check valves on each leg so that either the factory PCV fitting on the intake or the compressor inlet can draw vapors under vacuum or boost respectively, without allowing a air leak around the MAF.
