TVS2650 on an LT1
TVS2650 on an LT1
Any shop(s) installing the larger TVS 2650 SZupercharger on an LT1 Stingray?
Really would like to try this combo but probably necessitates a new/taller hood.
They (Magnuson/Speed Engineering) had it under a Stingray hood @ SEMA. The Edelbrock unit looks slimmer, at least in pictures.
Now you might need to lower the engine cradle to get the hood to clear but this is nothing major.
You are going to need to beef up your bottom end and fuel system on a LT1 to take full advantage of this one though.
They had the Camarofest this past weekend and had it out running on several cars. My buddy was running 9.7 at 143mph running about 12psi. He will be bumping his up to 18-20psi.
i thought he said the Corvette was out there running low 9’s.
The Maggie 2650 fits completely under the hood.
It it sounds like they are getting a ton of interest and orders for the 2650...
He was just tuning the car on low boost this past weekend. He also had a learning experience because his cats were clogged and it caused him to run 10.8’s at 130 or so...once they fixed the cats it was back on.
Here was one of his passes. He will be upping the boost now. This was 9.8 at 142mph in a car weighing over 4000lbs. I thought he said the Vette was almost 10mph faster...
https://m.facebook.com/story.php?sto...d.php&refid=52
If this is true, it doesn’t make any sense to release that blower to the public. The whole point of that size blower is to play in the HP neighborhood that would need to add port injection...?
Of course it will fit under the hood, right? Seems to be a really easy path to 900whp or so. I guess I am thinking more about the comparisons between the 2300 and the 2650 and basically you see the 2650 is just more efficient.
I figure it it will be good enough to put cars into the low 9’s or high 8’a pretty easily. Makes me wonder how much of the objections are based on theory vs reality?
Yes there solutions aren't cheap! But they can be done.
then there is meth that people have been happy with to provide fuel for years and years. Wonder how many 1000rwhp C7’s there are that have meth compared to port injection? Bet it favours the meth!!!
hogurt (07-17-2019)
There are DI fuel solutions out there already. There the FIC larger injectors and the LPE uprated pump or even the Katech secondary DI pump for people wanting really big power.
My buddy will have his 2650 to the dyno this week or next, but he’s waiting for smaller pulleys so he can up the boost. He will run ally injection so we will see where he goes...should be a good indication.
Most people aren’t keen on scrapping a $10K long block when a $100 meth pump dies. Relying on that for fueling is living dangerously... lol
Port injection is a no-brainer add-on. It’s dead reliable, cleans the intake valves, and nearly infinitely scalable. I guess that will be an advantage for the Edelbrock 2650, Whipple, etc. Nice move by GM to include it on the ZR1.
well someone has already pushed the 2650 to over 1000rwhp with the stock pump and meth on e85! Go have a look in the Z06 section! He dose plan on using the LPE pump once he can get hold of one.
Your joking right? I would say 90% of c7s over 800rwhp will be running meth for fuel!
i agree it’s the best way! But if you want a 2650 but don’t want a new hood / the supercharger sticking through I’m sorry but your fresh out of luck!
Disagree, meth for cooling, sure. But no way 90% of C7’s over 800 WHP are using meth for fueling. Where did that number come from?!?
Yep, you’re probably right on the hood deal.
Again, relying on meth for fueling is substantially less reliable than port. Not even debatable. Just because someone does it doesn’t mean it’s the best way to go.
The DI solutions are expensive! What would be great if someone could package the full on DI solution for a reasonable price. But as Katech are the only ones with a secondary pump on the market at the moment it’s their market! So no competition means prices stay high.
i mean the ultimate tvs2650 will be a ported LT5 if only for the boost control and port injection! Just need someone to mock it up on a C7 and see what it looks like poking through the hood / with a cowl.
I’m not saying Using meth is the best solution at all! I’m just saying that many many many people do! And a lot are pretty much relying on it for either octane, fuel or both! Just look at all the big ish builds on here and the see the number using port injection. I can only think of a handful (earlH, C5, one guy with a tvs2300 using the CPR stock SC kit, one shop using a LT5 blower, there has to be more). Now look at all the people using meth. Again I’m not saying it right, but it’s another option!
I think new guys kind of look at things in the what can I get for $10 or 15K and they go with guys that can slap stuff on your car for the lowest price or source their parts from guys that can save you $5 but can't really help you spec out a setup that will perform as expected. Was that guy when I started in this hobby way back when...Been there, done that, learned from it....cars made good hp but weren't all that fast and were full on headaches. You've seen the many "going another direction" car ads from guys that fit in this category...lol.
The guys out there building cars that run fast "reliably" are worth their weight in gold and are few and far between. Their ability and their skill is worth something and with their time/$$ investment to develop parts that work, you begin to see why. While prices may come down some, it really amounts to the old pay-to-play addage.
In looking at all the individual components from a wholesale angle, there isn't a ton of margin in some of that stuff, so if prices start to get depressed, it might be tough to attract the innovators and truly skilled guys because there are more lucrative endeavors for those that are truly talented.
Joshinator99 (07-20-2019)
