[Z06] Adding compression and meth, how much more compression :D
Alright guys Ill be running on 93 octane and meth.. n/a setup. making 611rwhp/565rwtq with stock compression..
Question is, should I go with 12:1 or 12.3:1, those seem like the most common used.. Ive seen higher, but I do plan to eventually road course the car and dont want to be too risky..
Whats your take, and your guess what itll now make with the added compression and meth?
Thanks!!
Thanks!!
St. Jude Donor '10-'11-'12
What kind of mods got you 611/565 on stock CR ? That seems high for not bumping up the CR.
BTW I assume your tuner will program the tune to pull timing in case of a meth pump failure (as do most FI set ups). If so I'd go 12.3:1 ...meth will give you the octane for that CR.
thanks for the posts guys.
My current power mods are:
wcch st2 heads stock compression with all the goodies
ported fast102 setup, nw102tb
halltech102 superbee
kookslongtubes 1 7/8" with offroad midpipe and npp catback
iw 10% underdrive dampner
lg x4 cam
mantic 9000 twin disc setup
all supporting mods and bs
lg x4 cam
You're not going to get 30+ out of a point bump in static CR and meth on an NA setup. You can gain some, but 30+ is a different cam kind of number. A bigger bump stick with the added compression and meth would do it though.
Oh really, i thought 25-30rwhp would be achievable with 1.3pts and meth. my cam is a decent size already, not sure if I want to go with a bigger one. what do you think is realist for the 1.3 and meth?
thx for the post
thx for the post
If you raise your static CR, a cam with more overlap will be soaked up by the added Compression. You have a stong LS7 combo right now, another 30 is going to be a struggle. It can happen, check out John B's setup; but it'll take a combo of the right parts to get there. Your Static compression and Dynamaic compression will both need to be taken into account. Your Static around 12-12.3 would be nice, with a Dynamic compression ratio right around 8.8-9. With that combo I believe you'd be at 640 wheel.
I got 17rwhp out of timing and n/a meth and even more torque..Your mods and g7xx giant cam would put you at 638 if I remember right..add cr and meth maybe another 25rwhp? Id like to know also as I will be taken out my g7x4 cam for g7xx giant,,Whats the install price on a cam only around?
