[Z06] Meth kits on h/c guys come in please..
Results
Anybody have some dyno results or what kind of timing degrees that can be added say to a 12 to 1 motor etc.? Like we were doing 580 rwhp and when put kit on we added 5 degrees of timing and picked up 20 hp...
No results here, but right now im at 611/565 HCI c6z06 with stock compression and in a month Im going with 12.3:1 with meth.. will update results.. will be cool to see difference bc the 611/565 was made in the same month last year and same dyno..
you have the same cam as me..I think I will be getting the g7 xx as big as they can give me..Cheap 500 for another 30 rwhp plus install(which I don't know how much that will be) Up the compression requires what? money wise? and hp gain est? I picked up 17rwhp with n/a meth kit and advanced timing, was at 560rwhp ...But I think you get more torque ..My torque is about 565rw. Install is easy once you know how to do it. I can assist you with info,
Which kit is better and has no issues....
I use a bunch of pieces from different kits for my meth kit... Ditched all the plastic lines for braided because I'm running 100% meth in my tank... This is the tank I use... http://forums.corvetteforum.com/c6-f...meth-kits.html
