[Z06] Clutch pedal sticking at high RPM/heat
I got one run in the other day at the track and then the pedal started sticking. Is this the best fix? 350 is the Vette tax for sure but is this the best option?
http://www.tickperformance.com/tick-...rvette-c6-z06/
Thanks, David
Video of the 1st run with the new setup-
Thanks, David
Stock Clutch? Have you cleaned out your fluid etc? Need more info of your setup. I don't have any issues with stock master cylinder even with WOT no lift shifts.
Clutch
Great run !
I just got my stock Z06 aside intake about a month ago. I did notice my pedal was stuck on the floor during a shift at the drags last time. Then it was fine rest of my runs.
Good to see another member in WA state. I am stuck at 12.0 119-121mph
So are you just shifting into 4th at the end?
Former Vendor
Looks like its time for a clutch and a speed bleeder! Hit us up when you are ready to pull the trigger as we have some good deals going on. Keep up the good work!
www.raceprovenperformance.com
18884277249
18884277249
