[Z06] To upgrade T56 or not? 1200rwhp...
Supremacy 1 car at a time
New bullet will be a touch over 1200 at the wheels. No 1/4 mile abuse intended but can expect the occasional spirited street runs. Not a DD either....just weekends.
Current T56 has only 27k on the clock but would I be running on borrowed time? Swapping out to TR6060 I feel the trans is going to be the weak link. Thoughts? Help and guidance is appreciated!
Best,
Mubarak.
Best,
Mubarak.
Best,
Mubarak.
Best,
Mubarak.
I'm sure not everyone will agree with me, but my question is this, do you have a lot of money to burn? If so, go for it and have the peace of mind. If not, run that b*tch until it breaks. I'm sure it is an if not when type of ordeal on a stock t56. An upgraded tr6060 from RPM or the like would be the best option. I know in your other thread you didn't want to spend the extra scratch on changing to an A&A procharger bracket if you could help it, so I'm just offering my honest opinion.
It's all in the goals. Iron block weight isn't really going to be that big of a deal at those power levels. The RHS block is a stout piece, though. It does require some different pieces from a standard LS7/LSX. I'd run a 427 LSX if I were building a car with your goals, imo. It will probably save you a few thousand, as well. Another option is the ERL 6 bolt superdeck setup, which keeps aluminum and is a stout setup as well.
If there is one thing I've learned with my build is, take the time you THINK it will take, and double it. Take the cost you think it will be, and add 30% (on the conservative side). You always end up upgrading more stuff while the car is down, and you run into things you forget about adding up (Fuel fittings, lines, etc). With your power level if you have not already, I'd consider a rps triple at the least and a quad wouldn't be a bad idea.
Whichever route you go, I'll be excited to see the outcome. Good luck with the build.
thanks for the great words I'll keep them in mind and also everything will be shown here don't worry just lets wait until the 2nd of Aug.
thanks again
back to topic those who runs TR6060 lvl V - Vi not more than that what are the positive and negative points about the RPM Transmission.
Which PC 10 rib kit are you going to run? Dallas? Cartek? ECS?
I'm still stock t56, no issues so far. I got a built 6060 in the garage but since it is such a pain to swap I'm waiting for the t56 to pop, but so far so good. Several cars have gone deep 8s on the stock t56.
It all comes down to money. If you are pulling the drive train and you have the money to do it then you should do the full RPM driveline. Built 6060, torque tube upgrades with shaft, couplers, bearings, RPM quaffie rear, DSS axles. Those parts will be more than the motor.
thanks again
thanks again
If you really want to USE your hp and have something that'll live, you need to go with a 4L80.
Cheers, Paul.
100% agree with that. 1000+ and a manual is just a headache. Take the money, do an auto.
My 2nd gear linkage became sticky on my t56 so went rpm 6060. I'd drive it till u need to take it out. Either break it or if it needed a new clutch
Figured I'd dig this up instead of starting a new thread.
I am currently running a RPM Level V T56 with an RPS Carbon Twin Clutch for my ~800whp setup. I am looking to be making a bit more here pretty soon (~1000whp) and I've been considering an RPM Level VII TR6060 and an RPS BC3. Future goals for the car will be north of 1400whp, so I'm not sure if I should bother changing anything else now if I'm not having any issues currently, or just upgrading them now for the reasons that I will eventually need these upgrades anyways. The car is an RHS 447, ProEFI, setup currently with traction control...not sure if that will help or hurt my cause at keeping all my drivetrain in tact. Mostly just a street car, with an occasional trip to the track just for fun...not looking to set records at the track or anything.
one of my friends here is running the T56 lvl V on his 1500hp Z06 and everything is great with the RPS III so keep it until you need to change it. that's my point.
it's back to you brother.
