[Z06] how many miles on your WCCH
#41
I drive my Z about 2K miles a year. Every time I start it it sees 6K RPM, but rarely more than 7K RPM. There are about 3K miles on my WCCH Stage II heads and I did a TORQUER 110 at the same time. All at around 10K miles. (560/511) I already headers, intake and a tune. Those three mods were done at around 5K miles, if I remember correctly. I will never measure my guides. IMO it is fixed. Even it is isn't, the joy/thrill that car provides me is PRICELE$$.
#42
Curious, did they test the guide on the OD or the ID? May not make any difference, but ....
.... I've often wondered about PM guides, and this is probably a question for a metallurgist, but in the past I have run across sintered-iron parts in non-automotive applications and the conventional wisdom is to not machine or file on the outside of those parts since the 'hardness' is on the outside, not the inside. Supposedly.
Now a PM guide may be made with a different process, but I always wondered if machining the ID of the guide would not remove some of the hardness inherent in the unmolested external finish of the final product.
Alternatively, assuming the part in question was not treated with a surface hardening process (as those other parts I mention may well have been), and assuming the part was sufficiently heated to completely bond all the metal powder, then I suppose the hardness would be the same throughout.
Sure would be interesting to see that hardness test on the outside and the 'inside' (sectioned portion) of an OEM PM guide.
#44
In fact, all the broken springs we've seen on this forum over the past several months are duals.
.... living in the past
#45
#46
I got the sister head to that one ,I can somewhat laugh now. I'm not a wealthy vette owner,it really hurt me financially for a year. I still love the Z06 I don't want get this going AGAIN but I can't believe GM left us hanging out to dry ? Please I'm in no mood to fight
#47
Clearly it is an opinion. No one would be foolish enough to claim that as a fact, or to interpret it as a fact. However, as an opinion it is based on fact (widespread use of dual springs when beehives have clearly been shown to be superior).
Already asked, and already answered. And don't try to rehabilitate your argument post hoc by adding a "high horsepower" caveat -- this is the LS7 forum, not the alcohol dragster forum.
No, they have not. Man, you sure veered from taking me to task for stating 'facts' not in evidence
I doubt anybody on this forum has ever heard of a PSI beehive spring breaking. To claim that is not a great record is simply preposterous. It sounds like you are ....
When a beehive/lighter spring can control the valve, use that. When you need more spring pressure than a single beehive can provide, start looking at duals.
#48
So the guides needed to be replaced because of the porting but all the valves, springs etc were reused. They now have an additional 3k miles and 6 track days.
DH
#49
I make good money and I am insane. my wcch will be here in 2 weeks. she goes in for surgery in 4 weeks. if I can make it another month I'm golden ( fingers crossed)
#50
#51
I will agree with your statement of the obvious. However, in the stock or mildly modified LS7 realm which we are discussing here a single beehive provides all the pressure that is needed. Unless perhaps you've employed a Rosie O'Donnell exhaust valve . . . .
#53
I will be happy to link you to the post where you requested that I in no way address you or respond to your posts.
I don't understand why you are unable to do the same for me and infact now ask me to address you.
As I'm sure you have advised other: The search function Is Your Friend !!!
DH
DH
#54
#55
Your lack of worries may be misplaced. One of the tech writers on this forum got new 2013 warranty replacement heads that from the factory had the valve concentricity with the seats in excess of the GM concentricity limit. If you still have the warranty, then don't worry, just get the heads checked before the warranty/extension is up.
My 09 with 47K miles had all exhaust valve guides and 6 of 8 intake valve guides beyond spec.
#56
1100 miles on WCCH Stage 4 heads, P&P, K501 cam, Katech TiMo intake and new OEM exhaust valves. I will have the guides wiggle tested and probably replace the PSI 1511 beehive springs at 20K miles.
#57
https://www.corvetteforum.com/forums...l-is-good.html Mark2009 I see your still here ruining good threads
#59
