C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Fluid dripping onto right header
Old 07-23-2014, 12:04 AM
anth115
anth115's Avatar
Default Fluid dripping onto right header
Hey everyone,
Since I've bought my Z06 (just over a year ago), just about every time I get the engine hot after a spirited (or just long) drive, once the car is off and parked I can hear a small amount of fluid dripping onto what appears to be the passenger side header (can hear the sizzling sound) and then see it hit the ground below.
This only happens for a few minutes after shut down. It hasn't gotten any worse over time, all gauges and fluid levels remain normal, and the AC being used does not seem to impact this one way or the other.
I've had a look at the fluid on the floor and it is clear and odourless so I assume it is water. My garage floor is not stained at all from this.
Any thoughts on what it could be?
My only guess would have been related to the AC condenser, but this happens even when I don't use AC (although I do use the fan - maybe the AC runs anyway?).
I was also concerned about a water pump issue but that is located at the front of the engine while this is on the passenger side back near the firewall.
Anthony
Old 07-23-2014, 01:00 AM
phipp85
phipp85's Avatar
It's just condensation that builds up on the A/C line that runs behind the engine near the top of the firewall about the same height as the intake manifold. Look closely next time you hear it and you'll see where it drips from. Mine hits the header so it never makes it to the floor.
Old 07-23-2014, 07:28 AM
DaOtherOne
DaOtherOne's Avatar
Old 07-23-2014, 08:17 AM
Mark2009
Mark2009's Avatar
Yup, just plain ol' water. When in doubt, taste it -- coolant is very sweet.
Old 07-23-2014, 09:19 AM
Michael_D
Michael_D's Avatar
This is exactly what it is. I chased this the first time I noticed it, which coincidently just happened to occur after I did a head swap...
Old 07-23-2014, 09:33 AM
anth115
anth115's Avatar
Thanks guys - this is what I was hoping for. Just wanted to double check with you all on the forum and I'm glad I did.
Old 07-24-2014, 09:33 AM
z06clif
z06clif's Avatar
its condensation off the A/C line . worrisome at first but then relieved when the cause is determined
Clif
To Fluid dripping onto right header
Quick Reply: [Z06] Fluid dripping onto right header
