[Z06] [B]2008 Z06 Blown Motor[/B]
Well I guess I am the latest casualty as my Z06 engine seized on the way home from work Thursday night with 20k miles. As I was shifting from fourth to fifth gear, heard a bang, rattle and engine seized. No smoke, no oil, and no hole in the block as I can tell. Will pull heads to see how screwed I am. Bought an 08 with 9k mi a year ago and had the wiggle test performed at 15K mi when I had Katech Torquer 116 cam installed with Brian Tooley valve springs, Comp Cans Trunion upgrade, Comp Cams adjustable push rods, C5-R timing chain. Running with Callaway Honker intake and Pfadt headers/mid pipe with Akropivic mufflers at the rear. Setup was making around 620hp at the crank. Just sick to my stomach now...
And sorry to have to say, that neither Tums, Kaopectate, Maalox nor Pepto-Bismol is going to do anything toward helping your stomach right now.
Only thing you can do now, is just accept the fact that your engine just took a giant crap, let that tear come to your eye, and your nose is probably going to run too, and understand that it is going to cost you $10-$15K. Then get get back on your feet and move on toward a new one.
Good luck, and I hope your stomach feels better soon.
Update
Found hole in rear right side of block next to starter. Now looking for engines with warranty. I don't know of I can go back to stock 505hp but I cannot and will not put/pay myself into another ticking time bomb. I did not track or race the car but used all 620hp under the hood regularly. I don't have the wiggle test data but was told by the installer and read the the brass guides were not the ultimate answer as WCCH heads with brass guides had failed as well.
http://forums.corvetteforum.com/c6-z...cker-arms.html
Haven't taken off valve covers bet I'm betting a dropped the stock exhaust valve due to guide wear. More to come...
At any rate, sorry to hear of your misfortune.
I know that you may not have the exact numbers, but if you had a wiggle test, were the guides in spec or out of spec when it was done?
But you should call Richard. He has had no reported failures of his SS/Bronze guide/dual spring setups.
Sorry that you are joining many of us who have also lost stock motors
DH
Well, that's not quite true. There has been at least one report of a SS valve tip failing. It was reported here. Then that report was disappeared by the OP. Funny how that works . . . . .
You are free to think what ever you like. I will stand by my statement as it was told to me in person by Richard at WCCH more than once.
And I wish you would be a gentleman and stop addressing my posts just as you requested me to stop addressing yours.
DH
#33
St. Jude Donor '12
I can't blame ya for not wanting to go back to the 505 hp engine. Seems like the LS 376 should have beefed up parts to make 525 hp...?? It's listed Chevy performance website;
http://www.chevrolet.com/performance...ls376-525.html
525 hp @ 6300 rpm they claim. Twenty five more (stock) than the LS7 and several thousand LESS....
Sorry for your drama and the hole in your pocket. Good luck.
Error: LS 372 (525)= twenty more hp vs. LS7
#35
Sounds to me like he replaced the cam on stock heads. Sorry but there's no way - you should have known better
#36
stock heads
I followed the advice of the shop doing the work by not doing any valve work if I was only looking for and extra 80-100hp. I had to argue for the shop to install the KATECH Torquer 116 cam (very mild IMHO) instead of their own custom cam which had an aggressive lift and I did't want to beat the valve train apart or lose low speed driveablilty. I was VERY happy with the cam choice. I dynoed at 560hp at rear wheals with stock valves and head but new rocker arm bearings, valves springs, adj lifters. I wanted and asked about titanium exhaust valves and was told it was over kill. Trust me people - I wish I had spent the money on the BRODIX BR7 heads I wanted so badly which I was told was unnecessary. By the way people, I spoke to half the vendors on here and have the emails to prove it but only 2 out of the many suggested valves jobs. I will respectfully reframe from naming vendors but I called everybody recommended on this forum and others and discussed my options until I was blue in the face or that wouldn't return my calls! HATERS GONNA HATE, I'm fine with that...
#37
Does anybody know about the LS7s built for the Z28 and if the valvetrain issues are fixed? If I ordered an GM crate LS7 would it come off the same engine assembly line of LS7s going into the new Z28s. One option is to have GM install a GM LS7 short block @ $15k (they don't like cores with holes -weird) and get a 3 year 100k mile warranty.. to what maybe drop a valve? Since my heads are probrably shot I am also looking at having a short block built and throwing some Brodix heads on and staying with my cam choice which might make 620-650 at the crank...
#38
I followed the advice of the shop doing the work by not doing any valve work if I was only looking for and extra 80-100hp. I had to argue for the shop to install the KATECH Torquer 116 cam (very mild IMHO) instead of their own custom cam which had an aggressive lift and I did't want to beat the valve train apart or lose low speed driveablilty. I was VERY happy with the cam choice. I dynoed at 560hp at rear wheals with stock valves and head but new rocker arm bearings, valves springs, adj lifters. I wanted and asked about titanium exhaust valves and was told it was over kill. Trust me people - I wish I had spent the money on the BRODIX BR7 heads I wanted so badly which I was told was necessary. By the way people, I spoke to half the vendors on here and have the emails to prove it but only 2 out of the many suggested valves jobs. I will respectfully reframe from naming vendors but I called everybody recommended on this forum and others and discussed my options until I was blue in the face or that wouldn't return my calls! HATERS GONNA HATE, I'm fine with that...
Any reputable shop would tell you to do heads and valves. As a matter of fact I USED to think that this whole LS7 thing was a shop inspired fairy tale - because each shop I contacted told me to do this (back in 2010). And then when two of my friends had their valves drop and my warranty expired, Speed Inc did my heads and valves.
Sorry it happened to you, but please name the shops that told you not to do heads and valves. We all need to know who the idiots are so we don't send our future vettes to these places.
#39
DH
#40
St. Jude Donor '12
