View Poll Results: A Pillar Gauge or Dashlogic to monitor boost/fuel
Voters: 8. You may not vote on this poll
[Z06] A pillar Gauges or Dash logic
A pillar Gauges or Dashlogic to monitor boost/fuel
Been reading quite alot on the dash logic, and it's a neat little device. Which 1 of the 2 would me more accurate? What would you guys prefer? I like the clean look of the dash logic since it uses your DIC, but I wouldn't mind having the gauges on the pillar.
Poll included..
Poll included..
For actual racing the pillar gauges will be better, since you won't have time to be fiddling with the DIC.
However, you will probably need to plumb separate sensors for the pillar gauges, depending on what you want to monitor.
Either will be equally accurate as long as you use quality components. In fact it seems that the ECM/BCM seems to use some weird conversions/scaling for some sensor inputs (oil temp for one, oil pressure for another), so it will again depend on what you want to monitor.
Not sure about accuracy but I love my dashlogic
I am not a fan of everybody being able to see the a pillar gauges, so the dashlogic allows me to change what I see on the HUD and DIC
I agree. Having the ability to see the gauges definitely attracts more attention--good and bad.
I'm pretty sure there is no factory sensor for fuel pressure. You'll need to plumb a separate gauge. There are some sensor adapters for the factory fuel line plumbing, not cheap of course (quick disconnect with an NPT port).
Have to plumb a different sensor for FP.
Dash logic all the way. Put the info up on the hud. Or setup warnings to do whatever you want and the car will beep, flash, or do whatever you set it up for. No need to look at gauges, something goes wrong and it makes the car flip out.
Have it setup to warn for anything you want, it is fully programmable
AFR<11.5 while TPS>90
KR>2 while TPS>90
IAT>140
FP<58
Etc, no need to stare at anything, just let it monitor for you and chime/flash the hud/dash when something is not right.
Plus you can monitor just about anything, measures 0-60, 1/4 mile, etc.
Accuracy is all dependant on the sensors/etc. Dash logic and gauges do nothing but display the data they are given.
KR>2 while TPS>90
IAT>140
FP<58
I dunno, hopefully I'll get better as time goes by, but my first track outing with a C6 Z06 and I pretty much didn't have time to look at anything inside the cockpit. And this wasn't my first rodeo.
I did look at the DIC once when the car got squirrelly on corner exit. It said "Traction Control, Dumbass". I looked at it maybe once every 10 laps otherwise. It said "Oil Temperature Okay" (235F).
Based on past experience (limited) if it's important I want a gauge, and I want it pointing straight up at normal readings. Otherwise I ain't got time to deal with it.
One lap I was low on power. Didn't have any idiot (CEL/MIL) llights. Had it in the wrong damn gear after a f'ed up entry into T2 with a car ahead off the track in the chute between T1 and T2 (5th gear instead of 3rd). Took me half a lap to figure it out, give point byes, etc. F me, get rid of the computers and the fuel injection and give me a four speed Muncie with bias ply tires so I can keep up mentally
KR>2 while TPS>90
IAT>140
FP<58
KR>2 while TPS>90
IAT>140
FP<58
Mark, you need to try a dash logic out, because having everything on the hud and user programable warnings, both visual and audable are 100x better than gauges on the pillar. When the HUD starts flashing a warning and the car starts beeping you pay attention a lot more than a needle moving. There is no comparison to how much better it is to have info on the hud than on a gauge off to the side.
Oh, I've thought about it, but for routine stuff I'd rather have the gauge.
Now for alarms and stuff, that's a different ballgame. A computer can do a much better job of monitoring out-of-range conditions and alerting the driver.
But for keeping an eye on stuff like oil pressure, coolant temp, oil temp, etc, I find a gauge better for that, especially on the track. But even if I do have the gauge then a computer-monitored alert would be a welcome addition. I guess I'm saying both approaches have good points and bad points.
KR>2 while TPS>90
IAT>140
FP<58
KR>2 while TPS>90
IAT>140
FP<58
I totally forgot about the AFR, and the alerts. From the looks of it, theyre about the same price if not more for the gauges. When the gauges and pillars are combined- avg 70 for the pillar and avg of 80 each for the gauges + install. So hypothetically the gauge route is more.
I mess with mine all the time. I actually have both because I have been too lazy to find an a-pillar without the holes in it and rewire the gauges so I use the dashlogic and have the AEM output and and FP sensor wired to it, and the AEM wideband and aeroforce still in the pod even though the aeroforce just plugs the whole most of the time.
One day when I find a new a-pillar I'll take the gauges off as they just get in the way and annoy me. Any important info is on the hud. No need to look over and take eyes off the road.
Supremacy 1 car at a time
KR>2 while TPS>90
IAT>140
FP<58
KR>2 while TPS>90
IAT>140
FP<58
Photos of what? The hud? The dic? Goto palmers site, they have photos/video.
Never even though of the last one. Can have it show meth spraying or not with Dave's Flex time module or display ethanol percent with flex fuel kit.
