[Z06] YYCZ06's Modification Thread
Okay, I was just at the Home Depot and stumbled across these rubber grommets. I opened up the hole to 5/16" and added one of these. It really finishes it off in my opinion.
Installed my Elite Engineering catch can this afternoon. I've had one of these on my Jeep since day one and its performed well. I've pulled at least a quart of oil from my system over the years and my intake manifold is absolutely spotless. Great product.
Great Thread!
Subscribed
Subscribed
Installed an Elite Engineering pedal today.
Some say you can install without removing the entire assembly but I found that difficult. I removed the plastic shield which allowed me to remove the two bolts without issue. The shield is held in place with three push type fasteners.
You'll need to remove two 13mm bolts and disconnect the wiring to remove the assembly.
New pedal installed and ready to go back in.
Should've come from the factory like this.
Location: Hailing From The Mean Streets Of Irvine, California
Received 4,153 Likes
Excellent Thread!
Thank you for posting
Save The Wave,
Corvette_Nut
Save The Wave,
Corvette_Nut
Went after my clutch fluid today. Used Ranger's video below as a guide. Took almost a full quart of fluid to clear it up initially.
Before:
After:
Before:
After:
#33
