[Z06] Valve Guide Issue Concern - 2007
I am going to look at a 2007 Z06 with 17,800 miles.
After reading ~20+ pages on the stickied issue of the valve problem, I am starting to second guess myself.
Does anyone have a solid running Z06? What percentage of the engines see issues?
Any information would be helpful!
Received 8,930 Likes
As for a solid running Z06 mine is as solid as it can be. The engine was replaced in Sept. 2011 with an engine produced in May of 2011. Since then it has accumulated 13K miles. There usually is no warning when a valve will drop. No excessive oil consumption, no reduction in performance, no noticeable increase in engine noise. My original engine went 24K miles and ran strong right up to the time the valve head broke off and dropped into the cylinder. Then everything got very quiet.
Bill
Currently about 87% of those tested for valve guide clearance have come back out of GM service specifications, which means if your car was under warranty then GM would replace the heads. It is likely that excessive guide wear is the cause of valve breakage, which will destroy your motor.
We can't predict at this time under exactly what circumstances or guide clearances a valve will break and drop, but the best thing you can do is have the guide clearances measured, and if out of spec then have the head reworked by a competent machine shop. It is then generally recommended to check the guide clearances again down the road to make sure the new guides are not wearing.
In shopping for a Z06, consider those with reworked heads more valuable than those with stock heads assuming a reputable shop did the work, and if you're looking at one with untouched stock heads, budget $150-$300 for a wiggle test and potentially $2k-$3k to have the heads redone if out of spec.
No need to fear these cars, just educate yourself and take the necessary steps to protect it.
The vast majority of people have solid running cars here, at least from the outside. There is little to no indication of any problems before a valve drops and destroys a motor.
My 06 had 45k miles on it with no problems and no ticking noise at all. Ran perfect. I just replaced my heads just for peace of mind. I did not have the wiggle test done and have no idea if my heads were out of spec or not. I did ask the shop that did the work to check, but they never did. I guess it was too much trouble.
I would say if the price is right, go for it. You may want to look into having the heads done at a later date. Good luck.
Either get a warranty or plan on checking the heads on regular internals and replace guides when they are out of spec. It is as simple as that. I pretty much consider them a wear item on an ls7 that needs to be checked and replaced when needed. Just like bushings, clutch, ball joints, tires, brake pads, etc. It is just something to monitor and deal with. Keep $2-4k around in case repairs need to be made.
Ugh. My mechanic just called and told me that two of my valve guides are so bad that they have to be bored and sleeved. 36K miles. Luckily I decided to have them worked on before a dropped valve. Oh well. Still love my Z.
You can pay for an extended warranty or you can pay to have the issue addressed. Both are probably close in price. If you plan on keeping the car only for the term of the warranty then I say warranty. If not address the issue if its a problem with your car.
One thing I will warn you about is if you are going to get the extended warranty make sure the car is not or has never been tuned. They will deny the claim if it had.
Just had the wiggle test done on my 06 with 16K miles on it. Cost me $280. All valves were in spec .0012 - .0025 #7 exhaust being the .0025. 2006 Z has 16k miles on it now and he said that he'd like to come back at 30k and check just the one bank again. Like a friend said, at the rate I'm going I'll see him again in about 8 more years.
Another advantage of addressing the heads over a warranty is it gives you the freedom to do mods. These cars are boring stock IMO. Atleast do a intake/headers/tune and get a solid 40-50rwhp and work on suspension/brakes/etc.
It isn't just replace heads for the fun of it, get them checked and if they are worn excessively then fix them. Just like you don't replace brake pads every 10k miles but if they are worn and about to be backing plate on rotor it would make sense to replace them.
EDIT: For now..
