[Z06] LS7 Spintron Testing Request and Donation Thread
Official spintron testing donation thread for additional spintron testing done by Katech.
Rules:
Minimum $50 or greater donation to paypal address below
Donations are for spintron testing of combination #1 only at this time
Donations for more tests will be attempted once test #1 goal is reached
Goal to reach for test #1 is $900
Please designate who you are on Corvette forum when sending donation or designate "anonymous"
Testing results will be released only for those who donate
Combo #1 ($900) Reached!!
85g Ferrea SS hollow exhaust valves
torquer cam
PSI 1511 beehive springs/titanium retainers
Stock rockers
Combo #2
85g Ferrea SS hollow exhaust valves,
Stock cam,
Stock beehive springs/stock retainers,
Stock rockers
Combo #3
Stock exhaust valve,
Stock cam,
Stock springs,
HS roller tip rocker (provided by Michael_D)
Combo #4:
Stock rockers,
85g Hollow Ferrea exhaust valves,
Endurance cam (provided by Vert_C6),
Forum members who have contributed:
forg0tmypen- $50
Jasonoff- $100
VertC6- $50
Mark2009- $50
Beast5spdGTA- $100
Vray- $75, $125
MTPZ06- $50
Silvrhand- $100
Undy- $50
Michael_D- $200
LIT- $100
Wjnjr- $50
Pickleseimer- $50
Sled Driver- $50
Somgman3- $50
Bad_AX- $200
383- $50
Vette@71- $50
Coach62- $50
American Heritage- $100
7007vette- $50
RossN- $50
Nator02- $50
Wulverine- $100
Double06- $50
Daveng- $50
erick_e- $50
Mrkris- $75
Cerberus- $50
Total raised so far: $2,275!
Address to send parts for testing:
24324 Sorrentino Court
Clinton Twp., MI 48035
Official email address to send money to Paypal for dontations is:
spintrontestdonations@gmail.com
I have personally tested and sent the first donation of $50 from my personal account to this one. Please be careful typing in the email into paypal, and please, in the note section designate WHO YOU ARE ON CORVETTE FORUM. For example, see this screen shot of my donation:
Rules:
torquer cam
Stock rockers
Combo #2
Stock cam,
Stock rockers
Combo #3
Stock cam,
Stock springs,
Combo #4:
Stock rockers,
forg0tmypen- $50
Jasonoff- $100
VertC6- $50
Mark2009- $50
Beast5spdGTA- $100
Vray- $75, $125
MTPZ06- $50
Silvrhand- $100
Undy- $50
Michael_D- $200
LIT- $100
Wjnjr- $50
Pickleseimer- $50
Sled Driver- $50
Somgman3- $50
Bad_AX- $200
383- $50
Vette@71- $50
Coach62- $50
7007vette- $50
RossN- $50
Nator02- $50
Wulverine- $100
Double06- $50
Daveng- $50
erick_e- $50
Mrkris- $75
Cerberus- $50
Who else would like to see the following tested on the spintron at Katech?:
torquer cam
beehive springs/titanium retainers?
Would think that would be a stable setup to appease those who dont like the stock exh valves and also those who are looking for a little extra piece of mind without sacrificing valve train stability at higher RPMs.
torquer cam
torquer cam
torquer cam
I remember the thrashing very well, it was truly embarrassing.
I would still like to see the fix using all OEM parts as designed. More than anything that is what I would have liked to hear from GM. Even If it took buying a new set of heads from GM, but as we know that's not an option because they are not proven yet as being "fixed" on the latest models. Only time will tell. I have been considering Katech because it appears that they are one to use the OEM parts. I am just trying to bide time to see how any of those jobs they have done work out, especially for the ones being driven hard.
the last thread turned into such a sh*tshow i would be shocked if they ever publish results again
too many armchair mechanics and conspiracy theorists and big egos here at CF to allow for real, deep technical discussion
That all depends on/ how many track runs/ 1/8.1/4 your dump an run/rpm hell i ant TECH, S4IT I cant even type, all i might, think i may no now allways changes, the game was built by gm 4 u 2 take it that much past the Z06 a workin man /gal can pay out .Like they say the ocean is sometimes blue, how much testthing are u willing 2 spend
Fortunately Katech did publish results of the spintron tests. Follow the link in this post: http://forums.corvetteforum.com/1586941710-post50.html
Takes a lot of work and money to set up a LS7 test mule for the spin rig. From a business perspective, there needs to be payback for the testing costs. The payback would need to be in the form of testing something that the business either sells, or to validated a service they provide. Katech is a business, not a charitable organization.
Another option, is to just pay them to test whatever you want. This would probably be the best option, as you could specify exactly what you want tested; but it would not be cheap. One could potentially set up a "project fund", that interested persons could buy into. The interested persons could specify the combination of parts they want to test, and pay their portion of the testing fees, plus supply test components.
I like the second option. If there were others interested in doing something like that, I could take the idea to Katech, to see what it would take to set it up. I would suspect the buy in would be about $500 per person, and there would most likely need to be a minimum of $5000 for Katech to even consider doing something like this.
Premium Supporting Vendor
Similar member who trashed and ridiculed John G's thread on his extensive analysis and testing in determining geometry played a significant role in guide wear. As a result, John essentially quit posting although he has helped some members who have asked him for assistance..
I spoke to John G at some length a couple times, the guy knows what he's talking about and has an amazing amount of experience specifically measuring LS7 heads. Fortunately I have still been able to tap into that knowledge.
Unfortunately for the forum they have lost John's knowledge, experience and contributions, but just think, the forum has an extensive counting of SS valves to compensate
Cheers, Paul.
Pro Mechanic
Pro Mechanic
I don't understand why anyone wants to go to the expense of spin testing the dry, hollow stem, exhaust.
The stocker weighs in the mid 70-gram area. An 85-g valve is going to need more spring pressure or a change in the cam profile to control–maybe not much of a change–but the difference could be enough to push valve motion to the limits of stability at the engine's rev limit.
Another issue I question about hollow-stem valves with no sodium in them. Whether the valve stem is metal, hollow-with-no-sodium or hollow-with-sodium filling, the stem is still the heat path from the valve head to the guide, to the head and then to the coolant.
With an "unfilled" or "dry" hollow stem valve, you replace metal with air which is a very poor conductor of heat compared to metal, so without sodium in the hollow stem, what are you doing to prevent the valve head from overheating?
If you interested Jason I am sure people would be willing to donate to see some others tests get done.
Since the members would be footing the bill I would also hope the thread would be kept as clean as possible by the mods.
Ya, I was figuring about that much (hourly rate for the spin rig). Does that include the set up costs for the LS7 test engine? Maybe you could line out the total costs?
I suspect that there will be numerous combinations of testing that members would want to see. IE: rockers, different valves, with different springs, with different cam shafts. I'm guessing about three days worth of testing different combinations. Maybe more.
I was serious. If there are enough members curious enough to pony up some money to have their stuff tested, I'll coordinate it.
And no, $40 isn't even close to be enough. For that contribution, you MIGHT get to see the data.
