Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 04-25-2014, 03:12 PM   #1
fendersceptre
CF Member
Default Who's running Ferrea hollow stemmed exhaust valves? F2042P
Who is running the hollow stemmed valves from Ferrea? If so how's your experience been with them?
Thanks!
Joshua
Edit: If you are, please leave info about your setup:
Guides
Cam
Springs
Red line limit?
Valves
Other mods
Thanks!
fendersceptre is online now
Old 04-25-2014, 04:34 PM   #2
spra4u
CF Senior Member
spra4u's Avatar
spra4u is offline
Old 04-25-2014, 04:43 PM   #3
vertC6
CF Senior Member
Support Corvetteforum!
vertC6's Avatar
Does anyone have the part number?
vertC6 is online now
Old 04-25-2014, 04:44 PM   #4
vertC6
CF Senior Member
vertC6's Avatar
I will be installing it later this year
Old 04-25-2014, 04:52 PM   #5
fendersceptre
CF Member
F2042P. Thats the one I've been looking at.
-Joshua
Old 04-25-2014, 05:00 PM   #6
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
Evil427 runs it. As does NavyAirTraffic.
A few others on the Registry listing run it as well.
You might try contacting them.
The people at American Heritage may be able to give you some more information on it as well, they offer it in one of their head packages.
'06 Quicksilver Z06 is offline
Old 04-25-2014, 05:32 PM   #7
American Heritage
Supporting Vendor
We stock boxes of them. Use them in almost every LS7 head we do. 84-86 grams (cant remember which it is off the top of my head). The F2042P is very good alternative to the stock LS7 exh. valve and is significantly lighter than most SS valves (96-110grams depending on manufacture of solid SS valve).
American Heritage is offline
Old 04-25-2014, 05:34 PM   #8
fendersceptre
CF Member
Thanks for the info!
Can you confirm that they are one piece?
Also what springs are you running with them? I was thinking Katech torquer cam with the PSI Springs that came with the cam.
Thanks!
Joshua
Old 04-25-2014, 06:14 PM   #9
meanjoe
CF Senior Member
meanjoe's Avatar
Kitchen and Bath Builders
Quote:
F2042P
A set can be had for around $275.00 shipped
Sorry, didn't see that post just above mine.
meanjoe is offline
Old 04-25-2014, 06:50 PM   #10
jconnors316
CF Member
jconnors316's Avatar
Just picked my heads up an hour ago. Put ferrera hollow stems in them, install tomorrow.
jconnors316 is offline
Old 04-25-2014, 06:54 PM   #11
double06
CF Senior Member
Default I have them in mine
I have had them in the car about 6-7 months. About 85 grams.
double06 is offline
Old 04-25-2014, 07:17 PM   #12
Mark2009
2009 Corvette Z06
Mark2009's Avatar
Quote:
Originally Posted by fendersceptre View Post
Thanks for the info! Can you confirm that they are one piece? [...]
I believe they are, but the whole two-piece/welded deal is just a fear factor technique (the OEM valves are actually two different alloys, the main reason for their two piece design... it's a high tech feature designed to deal with the heat and the demands of the engine, not a detriment).
I think that most experts would agree with your thinking. If I were starting from scratch that is what I would run (spring-wise). There is, however, an old-school contingent that can't let go of those old dual springs (I suppose they also run carburetors and distributor ignitions ).
Mark2009 is offline
Old 04-25-2014, 08:10 PM   #13
NavyAirTraffic
CF Senior Member
NavyAirTraffic's Avatar
Like Quick stated, I run them. Best thing to do is contact Kohle at American Heritage, very knowledgable and generous with his time.
However the real reason I chose the F2042P's is because of what Richard (WCCH) said about the sodium valves on a different forum. Good luck!
Quote:
We have definitely seen excessive wear in some LS7 exhaust guides. Mostly coming from engines with over 30k on the clock. We have seen some heads show inconsistent wear requiring only one or two guides needing replacement. It appears that the sodium exhaut valves are transmitting an excessive amount of heat from the stem to the guide. In some cases the oil is BBQ'd in the guide and the lack of lubrication and cooling from the oil causes the excessive wear (mostly in the lower half of the exhaut guide). We've measured some guides as having over .004" of wear in the lower 1" of exhaust guide length. Porsche 911's suffer the same type of related guide wear on the exhaust side.
The next item to note regarding the sodium exhaust valves relates to the wall thickness of the sodium exhaust valve stem. It's only .040" thick and makes for a fragile exhaust valve. GM uses a good quality steel material but the design spec. renders the valves brittle at the neck. Hence the reason we choose the replace the factory units with stainless or inconel. The exhaust valves we use are manufactured with a .001" oversized stem size which allows us to hone the exhaust guides and remove most or all of the taper in the bore. In cases with excessive wear we replace the guides with bronze.
NavyAirTraffic is offline
Old 04-25-2014, 09:42 PM   #14
fendersceptre
CF Member
Hi Navy,
Thanks for the info! Are you limiting your red line at all? Also what springs and cam are you running?
Thanks!
Joshua
Old 04-26-2014, 01:25 AM   #15
sublime1996525
CF Senior Member
sublime1996525's Avatar
FrankieDangrboy
sublime1996525 is online now
Old 04-26-2014, 11:53 AM   #16
ramairws6
CF Senior Member
ramairws6's Avatar
Man, i don't know how much better some people on here need it explained to them!?
ramairws6 is offline
Old 04-26-2014, 01:56 PM   #17
forg0tmypen
CF Senior Member
forg0tmypen's Avatar
Send a message via AIM to forg0tmypen
I'd like to see these valves on the spintron machine:
Torquer cam/psi beehive springs/ferrea hollow SS valves. My guess, they would show stability up to 7,100. But I'd like to see the test run
forg0tmypen is offline
Old 04-26-2014, 02:01 PM   #18
Blackonblacksls
CF Senior Member
Yeah that made a lot or sense till people started realizing that it valve guide issues aren't isolated to just exhuast sides.
I think now the consensus is it's a valve seat machining error and there aren't really any issues with the valves.
That being said, a two piece valve won't stay together after abuse or machining errors as well as a once piece..
Blackonblacksls is online now
Old 04-26-2014, 07:11 PM   #19
Mark2009
2009 Corvette Z06
Mark2009's Avatar
Quote:
Originally Posted by ramairws6 View Post
[...] It appears that the sodium exhaut valves are transmitting an excessive amount of heat from the stem to the guide. [...]
To the contrary. Once the guides are worn out, the stems are unable to transfer the heat to the guide, which cooks the oil on the stem.
Since you clearly haven't gotten it yet, you tell us
By the way, folks, ramair's post was plagiarized, verbatim, from a four-year-old post by someone else on another forum: http://ls1tech.com/forums/13450863-post12.html .
Mark2009 is offline
Old 04-26-2014, 08:04 PM   #20
Wass
CF Senior Member
St. Jude Donor '09-'11
Wass's Avatar
I wouldn't have known because he's on my ignore list.
Wass is offline
Reload this Page Who's running Ferrea hollow stemmed exhaust valves? F2042P
Closed Thread
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FERREA HOLLOW STEM SS exhaust valve part #?? spra4u C6 Z06 Discussion 1 04-25-2014 09:32 AM
exhaust valves jconnors316 C6 Z06 Discussion 80 01-13-2014 10:48 AM
valve springs for ferrea hollow stem valves jconnors316 C6 Z06 Discussion 8 12-04-2013 11:40 PM
Ferrea Competition Hollow Stem Valves. Thoughts? forg0tmypen C6 Z06 Discussion 98 11-23-2013 12:15 AM
Ferrea Hollow stem atljar C6 Z06 Discussion 35 04-02-2013 02:17 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
