[Z06] So I need a new BLOCK...!
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
That's a good idea but I don't know what i'm looking at. I wouldn't know if it had spun bearings or missing the main caps.
They do have cores to start on now, I just wouldn't get a stamped 7.0 block. It would be one of the LS3 type blocks. Kinda proud of the 7.0 stamp given its going in a Z06 not just a base C6. SMH...
I have a friend that has a LS7 block to sell me for 1K but then I still have to send it to ERL and pay the $2500 to resleeve it to my specs. I might have to do that IF I can't find a cheaper alternative. That or just take a NON LS7 block with no 7.0 stamp and send in some core I get somewhere (assuming its a good block).
I have a LS7 Block. A ERL Rep has already seen it here in Houston. We are making a deal for them to get it currently.
My new build will be a RHS 427 block built by LME. I should have it back soon.
It seems that the LS7's have a week number 7 cylinder, or just week cylinder walls all together. When I looked at the cost of the ERL rebuilt block, I decided to spen t a little more and get once that will not have the issue a sleeved block can have.
Former Vendor
#7 is typically the cylinder that runs lean. By default that is typically the cylinder that fails. Either cracks a piston and then cracks the walls, or it detonates and cracks a sleeve. The walls in the LS7 have been one of the weak points of the LS7 block.
Former Vendor
It wasn't just isolated to his car either.
Before you purchase an RHS block have an agreement with RHS or whomever you purchase it from that they will take the block back, without a restocking fee, if your engine builder finds that it is not to their published specifications.
I purchased a new RHS block from Flatlander Racing for my 451 build (4.1850" x 4.100"). My engine builder found that the deck height of the first RHS block was not the 9.250" that RHS advertised, nor the 9.240" that is GM's deck height spec, but 9.228". I had spec'd my pistons to be 0.020" out of the hole with a cold engine using a 9.240" deck height. Seeing I already had my Mahle pistons, my Carrillo rods, and my Winberg crank, a good block was the only way to save my build.
It took RHS three blocks to get me one whose deck height was above 9.240". That block exercise caused an 8 week delay in my engine build, and a ton of heartburn.
So, let me see if I have this right... tell me if I'm wrong..
Are you saying the LS7 block is just a WEAK BLOCK from the get go and to stay away from it. Go with the ERL replacement block that is likely the stronger LS3 block with new dry sleeves?
Also, on the RHS block, do you have to send them a core or is that $4,800 the price of the block without having to send them anything?
It was at that point that they pulled the motor and I decided to have it stroked to at 445 per the builder's recommendation, they replaced ONLY sleeve #7.
I don't want an IRON block and throw off my perfect 50/50 weight distribution and kill my track performance.
I hear you on the iron block. Aluminum blocks weigh less and are just cooler. The Z06 does have good weight balance (about 49.7 / 50.3 with a 180 lb driver). That's stock, of course. Mods, different driver weight, and lowering the car will all affect weight distribution.
An LSX block weighs about 125 lbs more than an LS7 block. It will change the weight distribution (slightly) and affect your track performance a bit. It won't kill your track performance... you might not even notice the difference.
Just trying to provide some perspective.
Headers and 2 piece rotors would make up the weight difference.
RHS is stand alone block but like others said, would need more machine work and other custom parts to make it work.
ERL makes their blocks out of cores, can be l2/3/7/9/A or any gen 4 aluminum block.
Destroyed!
Update on CID. The motor has been destroyed! I OVER PAID for junk! Cost me 10K and it was never even spec'ed properly. ANY builder should know that stock sleeves can not accommodate a 4.155 bore! I didn't know and that's what trust bought me.
Not only is the #7 sleeve still cracked but the block is now cracked beyond repair and my BRAND NEW PISTONS ARE DESTROYED. I only drove 1500 low rpm "break-in miles" on that new motor! I've decided to have ERL build be a new short block. The new build will be a aluminum (not iron block) Naturally aspirated 454ci. 4.185 bore x 4.125 stroke
ERL note:
These sleeves are made of ductile iron that is 3 times stronger than cast iron. The ERL sleeves are significantly longer and thicker than stock sleeves, this allows for up to a 4.125” stroke and a 4.185” bore.
ERL note:
#33
I broke a sleeve and had ERL make it a superdeck block I'm hoping to make a 1000 hp (at the crank ) this week ,with a big shot of nitrous, no problems so far ,Ive put 3000 miles on it . I did a lot of research and I thought ERL was the way to go.
#34
That's refreshing to know. I doubt I spray it but at least I know it'll take a 300 shot if I wanted....
#37
Buy an aluminum truck block at a salvage yard for like $400. Have Richard at WCCH sleeve it. You can go up to 454" with this set up.
#38
Yeah I was told the truck's aluminum 5.3 block is the strongest made. That's the core I'm getting from ERL. Its $850. $400 is good price but after all the hassle of finding a good one and transportation back to my place then shipping it to ERL (that's $200 easy), its just easier and less hassle to just pay their core charge.
#39
#40
I had a valve drop 2 days ago. Destroyed my #1 Cylinder. Maybe salvageable after seeing the videos and write up on buildandtune.com. Steve out there is fixing my chamber, no cracks but pretty jacked.
I ordered a brand new 5.3 that is going to be bored out to 4.125 and put darton sleeves. 2700 bucks out the door.
