[Z06] 2013 Shelby GT500 737whp vs D1SC Z06 608whp both on pump gas
#41
About what I expected, congrats.
FI cars need a lot more power to outrun NA cars. That coupled with the weight of the Z, just makes it a great combo. I run neck and neck with my friends ZR1s, but they all put down 70 hp and 100 ft lb more tq on the same dyno. FI has heat soak, and adds a lot of weight. STill, those shelbys are respectable cars - and look good too.
#42
They don't have the same gear ratios.
Anyways, traction is key.
#43
Supremacy 1 car at a time
Exactly. Different rear gear, different tire height, and different 2nd gear.
#45
#47
Just got call from a 2K13 Shelby GT500 owner and he asked me for a race, not interested anymore in street racing .. since it's been a while and I didn't race in my C6Z only in a legal events so it's not bad to be out of law for a night in a year so ill race that.
shelby moods are:
Jlt 127mm
ford racing 65mmtb
LT
10% lower pulley
2.4 Upper pulley
Idloer
tuned on Pump gas 98 octane.
car made 737whp.
at the same dyno I made 608 and I'll try my luck since it's a friendly race not sure if ill do it so I'll drive the car all the way to the dyno to check if everything is well, all have a chance to test the car before installing the new goodies.
anyone can suggest the results I'll be welcoming..
BTW it's will be high roll race.
shelby moods are:
Jlt 127mm
ford racing 65mmtb
LT
10% lower pulley
2.4 Upper pulley
Idloer
car made 737whp.
#49
I happened to mix this thread up with another that had an NA car. I guess I'll just leave the forum since I made a mistake.
#50
I know, I wasn't butt hurt about it. Was just making a point some of us dabble and don't indulge entirely in every thread. This isn't Jalopnik with a bunch of assclowns running their mouths, 99% great people in here.
#52
That is like saying my wife's Hyundai is a 6 speed with a 1:1 4th so it is geared the same as a z06. If you take out final drive, tire height and a few other gears that don't match it does.
#54
But rear end and tire height multiply all the ratios so that very much matters, and even then the tranny gears aren't even the same so saying they have the same gearing isn't even close to correct.
#55
best,
--Mubarak.
I think I found a video of this race.
Bitch-Slapping a Cobra.The Snake Was Being A bad Boy.Vine Video - YouTube
#56
Received 2,042 Likes
2nd gear difference in trans is minuscule and the taller tires of on the Ford combined with the 3.73 rear gears make the overall gearing almost identical to the C6Z with shorter 3.42 rearend
