[Z06] raising car on stock bolts
Back in 07 I lowered my car using the stock bolts. Just installed my 19/20 set of 360 forged multies with new Michelin SS. These tires are bigger than others of same size Ive had on the car. Hitting a dip the rears rubbed at wheel wells, not good!!! We tried to raise back and found stock bolts frozen, we managed to get an impact on bolt head and no budge. Has anybody ran into this situation? What was the fix?Thanks
Late Model Domestics
Soak Them with PB Blaster or a similar lubricant. Car should be unloaded before turning these bolts and I would never use an impact wrench on them.
We had the car on a drive on hoist, used a tranny jack and an exhaust jack to unload. Has to be some serious corrosion. Will try all tips next go around. This car has lived its life in MW Montana, the thawing chemicals they use on our roads is hell on metals.
Thanks for input!
Thanks for input!
