[Z06] talk about stupid luck!!
had someone help today and with 2 people i can get the door open but have to be careful with the cables that are flopping around on the sides. so when these guys come on wednesday i will have the guy help me get the car out first then i will let him work.
Over 27 years experience in the garage door business.
Been running my own enterprise since 1998.
http://www.foothilldoors.com/
http://www.garagedooropeners.us/
http://www.bearcatco.com/
Most garage doors are installed with 10,000 to 12,000 cycles springs.
Torsion springs with a higher cycle rating i.e. 20,000 to 100,000 cycles are available. 20,000 is a cost effective upgrade which will greatly extend your spring life.
I installed 100,000 cycle springs on my own garage door because I never want to worry about a broken torsion spring again.
What are your thoughts on a DIY install for these 20K cycles springs?
20K cycles are a great idea. They shouldn't cost that much more than a set of standard cycle springs.
Also go for the older oil tempered springs as opposed to the newer silver galvanized torsion springs.
A couple of years ago the center bearing (similar to by bearcats) on one of my double garage doors froze up and actually cut the horizontal bar in half (like a tubing cutter). It was a challenge getting the pulleys off, the end bearings, the double springs, the center bearing and bar off, then reinstalling everything with a new bar. It's not really that hard if you can visualize how the door operates. You just have to use common sense and caution and not rush the job. I'm not bragging, but I was able to do this with no help.
Seriously
I had a spring let go. I thought something exploded. So, I agree, let someone with training and experience handle it.
I can't remember exactly what happened. It did have a center bearing and plate. I think maybe somehow the bearing slipped out of the plate and the plate cut the shaft right in the middle.
change of plans. i ordered the spring and doing it myself now. i can't get over how unprofessional garage door people are in my area! and this was a BBB A+ company. told him to go screw.
Bearcat recommended using winding bars (whatever those are) for turning the spring ends. I'm sure he is right. I used a pair of long 3/8" extensions which bent pretty good near the end of the spring winding process. Makes sure you use a good brand, Snap-on, Craftsman, etc. Definitely don't use cheap offshore extensions. As you have found out by now, the springs are color coded. I was able to match the size and color at a local large hardware store. Good luck.
#33
#34
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
i was able to order the proper spring from an online source that also sold the winding bars for $9 pair. just steel bars that have the proper size pin on the end for the holes in the cones. found out a buddy of mine did it and had no real issues. i'll get him to give me a hand with it.
If I recall the springs are to be wound 7 revolutions as a baseline. They ultimately should be wound to give the door a neutral balance.
Good luck!
#35
The winding bars have the correct diameter to fit in the winding holes, which are larger than a 3/8" extension . They also have a rough exterior finish which helps to keep them from slipping out of the holes. Using them you'll be fine. Just take your time and ensure that the winding bars are bottomed out in the hole EVERY time.
Good luck!
Good luck!
#36
that is exactly what they say in the vid and told me on the phone. start at 7 full turns (28, 1/4 turns)and then check balance of door at half way point. if it falls 1/4 turn tighter and if it raises 1/4 turn looser. up to 1/2 turn +/- is just fine from the 7 turn starting point. after that if there is a correction needed it may require different spring. but considering i ordered the exact spring that was on the door i should be fine.
#37
that was one of the easiest things i have ever replaced! i can't believe i was worried about it. i just finished up and have to run out and get some 3 in one oil for the spring. all i have to do is lube it up and should be good to go for 10k cycles. lol
