[Z06] Which tires for 2008 Z06
I found Michelins at rims4less.com for $300 per tire. Haven't called yet to see why they are so much cheaper but it's way cheaper than anywhere around.
I have used Michelin PS in the past and these are great tires. Much better than the stock run flats. I now have the Michelin Cup tires in 295/30-18 on front and 345/30-19 on the rear. All on stock wheel offsets. Forge Line wheels. After about 5-6 heat cycles these tires are the best one's I've ever had. True Performance tires in every way. People here have said that they don't do too well in wet weather but that has not been my experience. They do come with a AA wet weather traction rating. The only issue I have is with the 80 tread wear rating. Not the kind of tire you could drive cross country. That's why I have another set of Pilot sports here for long trips. Just swap them out till I get back. Good luck with your tire selection.
I just put a set of Michelin PSSs on 285/345 from America's tire (discount tire) for $1500 installed.
