[Z06] Comp cam 227-239 for LS7 smog legal , Ca. .
Comp cam 227-239 for LS7 smog legal , Ca.???
Been considering cam swap to a Comp cams 227-239 for the 2007 Z. Would be doing the springs, retainers, exhaust valves, rocker arms and combustion chambers clean up along with some intake to port matching. My question is directed to my fellow Z owners that have installed this cam in the Peoples Republic of California that have had to smog their Z cars with this cam. Any problems getting their cars to smog. Realize the exhaust gas sniffer test is now history, but the OBD-2 system is very smart about detecting changes. Any one have had any problems? No other external changes on my Z. Total stock from the outside and I will meet it that way. Do not need any red flags from the visual. Just causes the smog tech to start dig deeper. No CAIB stickers or part numbers you are screwed. Like to keep the externals looking factory as much as possible. Any one with any smog history with this cam set up? Cheers, John.
Former Vendor
no sniffer, obd only.........should pass without issues as long as nothing has been disabled thru the ecm.
We've changed here too to obdii and my tuner has done several now with many cam combo's, all passed. had the sniffer stayed - no way !!
I am not at all certain that we have moved away from the exhaust gas sniffer on the dyno.
I know it was scheduled for early this year, but I don't think this happened yet.
However if it has then a good tuner can solve your problems with a much larger cam than that.
