C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LS7 Engine pulled. Time to rebuild and add MODS!
Old 01-26-2014, 05:59 PM
smooth1990
smooth1990's Avatar
Default LS7 Engine pulled. Time to rebuild and add MODS!
Ok so over the last 2 days I have successfully pulled the engine out of my JSB 08 Z. The car was mostly stock before the rebuild. I am planning a full build over the next 30 days. Spring is coming and I want it done in time. I am going to list the things I plan on doing now and I have a 10k limit to stick to. ( all my labor is free! ) So if you have some constructive recommendations I am all
I had low compression on Number 1 cylinder so that is the reason for all this. After I pulled the engine I did a leak down again and could hear air weeping past my exhaust valves so I will be sending the heads off to be rebuilt at WCCH. I have heard good things about them. Does anyone know of any other places that are comparable in quality?
So here is my list of to Do's!
pistons...forged or not is the question...also what manufacturer?
Rings.
bearings.
timing set...Cloyes Gear 9-3667TX3 - Cloyes Race Billet True Roller
cam...either the widow-r or the lingenfelter gt19?
Heads...WCCH stage 2 port with Manley 221435 Dual spring kit
intake? Should I change it? is it worth it?
LG 1 3/4 LT headers and borla exhaust
Callaway Honker CAi
Mcleod RST Street twin clutch? worth it? better for the money?
I plan on using my stock rockers,push rods and lifters. They have 90k on them but look good.
I would appreciate thoughts on everything. I havent decided between cams yet. The gt19 is alot more steetable than the widow R but the widow R makes some impressive numbers and sounds wicked. I also would like thoughts on the intake. Is it worth swapping out or not? How about the TB?
Old 01-26-2014, 06:08 PM
Navy Raptor
Navy Raptor's Avatar
Looks like car **** to me.
Old 01-26-2014, 06:21 PM
LT5 John
LT5 John's Avatar
Looking good...I would NOT use the same lifters with 90k on them, no matter how good they look...You are doing a whole new build, do not skimp on new lifters, new push rods, and rocker upgrade. Either comp or CHE...
Old 01-26-2014, 06:38 PM
smooth1990
smooth1990's Avatar
Yea thanks! I was just thinking about that. I want 600 or so WHP so No skimping is a great idea lol...
I have a procharged 383 LT4 in my 92 that I just finished. That car is a monster! haha and ofcourse I didnt skimp...
Teaser video? More car ****? HAHA
I hope my Z is faster! lol
Old 01-26-2014, 07:19 PM
RedC5Z
RedC5Z's Avatar
You won't be able to use stock pushrods with those wcch heads as decking is part of it. Plus with a rather high lift cam like the one you listed, it's a must to check p2v clearance.
Also I've heard mixed things on mcleod clutches. I chose a ram dyad for my car, but also drove my buddies c6z with a act twin and was actually very impressed with the act clutch over my dyad
Old 01-26-2014, 07:43 PM
smooth1990
smooth1990's Avatar
Piston to valve clearance is a must to check. Do you have another cam recommendation?
Old 01-26-2014, 07:57 PM
Mark2009
Mark2009's Avatar
CAM: With a 7000 RPM redline, I would recommend what is called a 'gentle' lobe. This will probably not be found on high lift stuff, which you may or may not even need/use. Others have more experience with the lobe issue so I will leave it to them to chime in. Or talk to a vendor that understands what a gentle lobe is. IMHO you don't want to buy a cam on power specs (or sound), you want to buy a cam that won't beat your valvetrain (including cam and lifters) to an early death.
ROCKERS: Since there may be a wear pattern on your existing rockers, particularly the exhausts (if the guides are loose), I'd recommend a very close inspection and replacement if any type of wear pattern is observed. You may need some magnification to really see the extent. Trunnion upgrades, IMHO, are a waste of money and just another potential problem (witness the occasional broken circlip).
PUSHRODS: If you're going to 'heavy up' the valvetrain (solid valves) and spend time up near redline, I'd use stiffer pushrods. I assume that a chrome moly version, still in .080 thickness, would be stiffer than the OEM units (4130 steel vs 1010, IIRC). Otherwise, you don't have to have the heads milled unless you want more compression.
PTV is not an issue... the OEM setup has a quarter inch clearance. But if it were me I'd say away from the high lift (over .650) super duration stuff just on principle, unless you want a high RPM drag car with poor bottom end.
LIFTERS: With a new cam you might want new lifters... depends on how the old ones look (wheel). I've always been somewhat fascinated by the units forum vendor Brian Tooley sells, you might take a look at those. Otherwise, if I were buying, I'd probably get the Caddy lifters (supposed to be a tad better at high RPM, but not necessarily made better -- it's GM, after all.... ). The other aftermarket stuff is probably no better than stock, unless perhaps when you get into the real high dollar stuff ($500+) which is probably overkill for the average modded LS7.
Old 01-26-2014, 08:05 PM
Dirty Howie
Dirty Howie's Avatar
Rings.
bearings.
Callaway Honker CAi
Well you certainly can't go wrong letting Richard do your heads as you plan. He usually uses the Brian Tooley spring kit. Why would you be going with the Manley?
Good luck on your build, sounds awesome
Old 01-26-2014, 08:14 PM
smooth1990
smooth1990's Avatar
Thanks and manley is what was offered as options on his site? I will call and talk to him tomorrow.
Thanks! This is the stuff I love to hear! Knowledgable people with great advice!
This is my first LS7 build. Actually this is my first LS build. Its going to be challenging and I want it spot on before she goes together.
The widow R cam is pretty agressive. What are some more streetable options guys? This is a street car, not a race car!
Although, naturally, I want alot more power out of it! lol
Old 01-26-2014, 08:19 PM
Turbo2L
Turbo2L's Avatar
Cam technology has came a long way since the Widow cams. I'd humbly suggest Marting@Tick.
Old 01-26-2014, 08:21 PM
Mark2009
Mark2009's Avatar
[...] He usually uses the Brian Tooley spring kit. Why would you be going with the Manley? [...]
Perhaps because the Manley is a better spring (in fact, I suspect they are made by PAC). Popularity is a poor criteria for an engineering decision.
Old 01-26-2014, 08:24 PM
Mark2009
Mark2009's Avatar
I was thinking of Martin when I made my post; if I were in the market for a cam, I would definitely be talking to him. Forum vendor too
Old 01-26-2014, 08:29 PM
smooth1990
smooth1990's Avatar
Marting@tick?
Who is he and how do I contact him? lol
Old 01-26-2014, 08:38 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Do lifters and new trays while it is apart. They are too cheap not to do.
Run the RXT, no reason unless budget calls for it to run RST.
Old 01-26-2014, 08:44 PM
Mark2009
Mark2009's Avatar
Marting@tick?
Keeping in mind, in all fairness, that this is only one vendor out of several here....
Originally Posted by Martin@Tick on 9-19-2013
Tick is back on CF!
Some of you may know who and what Tick Performance is and the services we offer the Corvette Community.
Some of you may not though. For those that don't here is our website and a Google search will show that we've been in business for over 10 years going on 11 now and make very high performance and high quality parts for late model GM vehicles.
I will be the only person from Tick that posts on CF as it's the only active account we have here so please forward all questions to me if you have one.
Glad to be back guys!
Also of interest: http://ls1tech.com/forums/dynamomete...ver-stock.html
Old 01-26-2014, 08:58 PM
smooth1990
smooth1990's Avatar
Thanks! I will call him too!
Old 01-26-2014, 09:03 PM
RedC5Z
RedC5Z's Avatar
I don't, I'm running a custom ground cam from HKE. 243/259 .667/.670 113+2. It made the numbers 556hp/506trq but driveability is not good. Lot of bucking around town. I don't mind cause I drive it 5-6 times a month. It's mostly a fun car. I did daily it for a short time with that cam and a monster 3, man what a peice of crap clutch.
Mods were fast102/102, kooks 1-7/8, haltech
To LS7 Engine pulled. Time to rebuild and add MODS!
Old 01-26-2014, 10:44 PM
Z.06
Z.06's Avatar
Default Calloway CAI
My experience is that the Calloway CAI can cause severe surge in 2008 Z06 MAFs, making it difficult to find a tune that will be acceptable. This surge appeared at highway speeds and low throttle settings. As a result of my issues, Calloway provided their inlet modification plate, which makes their CAI less of a cold air inlet than advertised. Yes, it still makes good power, but is not truly a CAI any more, as the cold air is blocked off. Do not expect any help from Calloway in solving your problems as they will not even reply.
After spending $550 for a retune with a forum-recommended tuner and a xxxx tech inlet I still have less horsepower and torque than I had with the previous tune and the Calloway Honker CAI.
Rings.
bearings.
Callaway Honker CAi
Old 01-26-2014, 10:56 PM
Mark2009
Mark2009's Avatar
Generally speaking, and IMHO, CAI's are snake oil for the Z06. At road speed it will get outside air from the little nose hood scoop. For around-town driving (or drag racing) the Halltech beehive will probably solve a lot (but not all) of the heat issues.
Otherwise, on most or many aftermarket air intakes, fooling the MAF is what gets the advertised horsepower increase (leans out the air/fuel ratio). You can get about 90% of that with the stock air intake and a tune. Any so-called ram air effect, well, if you can really get it without causing other problems (overheating from a loss in radiator airflow, or surging due to MAF turbulence), then I'm sure it will help. At high speed.
Old 01-27-2014, 12:37 AM
Dirty Howie
I wasn't referring to popularity. I was referring to what the EXPERT at the shop the OP is using has been recommending and was curious as to why the deviation.
DH
Quick Reply: [Z06] LS7 Engine pulled. Time to rebuild and add MODS!
