[Z06] 2015 ZO6 Corvette....
01-23-2014, 03:10 PM
Slingshot
In case you have not yet seen the specs on the upcoming 2015 Corvette ZO6, take a look at this.
FWIW
01-23-2014, 03:24 PM
Quote:
Originally Posted by
pmihaltian
FWIW
The new Z will be 1.5 inches wider than the C6Z!
01-23-2014, 04:47 PM
Hopefully with the heat soak it still is more powerful than a C6 Z
01-23-2014, 04:53 PM
Nice! Thanks, OP.
01-23-2014, 05:50 PM
Nice spec list. Did I miss the anticipated weight? Didn't see it anywhere.
01-23-2014, 05:52 PM
Despicable Z
in a Q&A GM said heavier than the base C7.
01-23-2014, 06:37 PM
MudZ06
Really? That's interesting.
My gut said it would be heavier than the C6Z but I was thinking mid 3200s. I guess we'll have to wait and see what comes out. Curious what the final HP numbers will be too, my guess is 640ish.
01-23-2014, 06:54 PM
What if there was a C7 section...... ?
01-23-2014, 07:40 PM
erichg1000
Is the ZR 1 more powerful than the C6Z?
01-23-2014, 07:55 PM
pmihaltian
FWIW
Thanks for posting!
01-23-2014, 08:36 PM
Awesome car but also unfortunately still over designed and busy. A monster for sure but hoping a refresh comes sooner than later.
01-23-2014, 08:56 PM
This option on the C7R should be available on the Z as well.
"short/long arm (SLA) double wishbone,
fabricated steel upper and lower control
arms, coil-over-adjustable shock
absorbers"
01-24-2014, 05:37 AM
ibleedgreen
absorbers"
Seems like overkill for the street to me, unless you anticipate to take speed bumps, pot holes and side walks at 100+ mph.
01-24-2014, 07:30 AM
Hirohawa
I agree! Supervettes body conversion is way way nicer in my opinion.
01-24-2014, 08:17 AM
pmihaltian
FWIW
Z06. Not ZO6.
01-25-2014, 01:06 AM
Z06Ronald
Why would it have to be for the street? Just an option.
Either way these cars work 10 times better with coilovers! Street or track....
01-25-2014, 05:00 AM
ibleedgreen
Specifically I meant the fabricated steel A-arms, but I was a little ambiguous, I have to admit.
I have coil overs myself (Moton).
01-25-2014, 12:54 PM
Z06Ronald
Agreed, I just copied the entire setup.
01-25-2014, 03:19 PM
holding out for the L88. The z06 is weak in my humble opinion.
LOL
01-25-2014, 03:31 PM
'20-'21-'22-'23-'24
Really impressive specs for the car. Have to wonder just how much the hp/torque mbers will change between now and when it hits the market.
