C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
View Poll Results: My car is running fine (only vote if your LS7 is Ok)
Had valves inspected and there Ok
14.38%
Never inspected but my car is Ok
85.63%
Voters: 160. You may not vote on this poll
[Z06] How many are NOT having Valve issues ?
Old 12-20-2013, 07:51 PM
Matt Cyber Z06
Matt Cyber Z06's Avatar
Default How many are NOT having Valve issues ?
We see how many Are having issues--
But let's compare to how many are Not !
Please Vote and share your Year and Mileage
Old 12-20-2013, 08:18 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Good idea for a thread.
2006 23,000 miles, WCCH heads, solid stemmed SS valves bronze valve guides,
No valve issues.
Old 12-20-2013, 08:21 PM
Matt Cyber Z06
No valve issues.
I guess I did not make it clear enough
(Engines that are Not having issues *stock)
Old 12-20-2013, 08:25 PM
'06 Quicksilver Z06
Oh. OK. You didn't say "stock".
Well then you might want to have the moderators close this thread and start another one.
If not, well then people like myself will probably vote in it and make the results look better than they actually are.
Good luck.
Old 12-20-2013, 08:29 PM
Matt Cyber Z06
If the Mods would like to take the Idea of this Thread and turn it into
more User friendly wording and Info, That would be Great!
Old 12-20-2013, 11:14 PM
2019 ZR1
Support Corvetteforum!
2019 ZR1's Avatar
I would like to think everyone would have enough sense to know you meant a stock Z06. But god forbid I say anything else because I might get banned. Mine is a 2013 with 7800 miles. It runs great!!! I'm having a really hard time deciding if I should put a Edelbrock supercharger on.. WHAT DO YOU GUYS THINK..
Old 12-20-2013, 11:24 PM
RFZ
RFZ's Avatar
stil running stock heads at 41k. runs great
Old 12-20-2013, 11:54 PM
PatriotZ
PatriotZ's Avatar
Location: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Matt good idea and I also would like to think people know exactly what you are talking about.....08 stock 35,000+ miles....so far so good
Old 12-21-2013, 12:10 AM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
I was almost afraid to vote. Mine seems OK right now. Not making any untoward noises.
Early '09 model year that I bought in mid '10 new. Almost 70,000 mi. (I'm too lazy to go look, but close). Stock, except B&B Bullets (which, I'm sure you weren't even addressing this kind of mod)
lisa
Old 12-21-2013, 12:35 AM
propain
propain's Avatar
St. Jude Donor '14
2008 14K miles. Inspected. No issues yet.
Funny how someone tried to sneak in and tally 23K miles on SS valves with no issues when in reality its more like "1500 miles no issues yet on the SS valve modification"
Old 12-21-2013, 12:45 AM
bigcat29
Cruising
bigcat29's Avatar
Mine has 10k miles on it. She leaks down between 1 to 3 percent ice cold with 100psi applied. My engine guy tells me a lot of LS7 valve failures are a result of valve float. Upgrade the valve springs and rockers to avoid problems.
Old 12-21-2013, 02:25 AM
BadboyZ06
BadboyZ06's Avatar
2006, 27,722. Completely stock engine only the tires were changed. No wiggle test has been performed and this car has no valve train noise like I have seen posted by some on the forum. It runs as strong as it did the day I took delivery. Its not a daily driver and I have multiple cars like many forum members, but so far so good no issues not even a single fluid leak.
Old 12-21-2013, 06:20 AM
Oleman
Oleman's Avatar
09 42k miles all okay so far. I am still in warranty but have already talked to dealer about checking and will do after holidays..........
Old 12-21-2013, 06:37 AM
two-piece
two-piece's Avatar
08 16,500 not checked but running great.
Old 12-21-2013, 06:48 AM
cruzr6
cruzr6's Avatar
06 w/31k miles, 2nd owner, purchased @ 8.1k miles. basically stock except corsas. production # near the end of 06 run. had stems (top, middle, and bottom) measured and guides ... very little wear and nobody out more than 15%. chevy service rep was real interested in test ... watched as sr mech performed tests, and another tech watched. bill: $350 which included new plugs. i'm a happy camper.
merry christmas everyone.
Old 12-21-2013, 07:10 AM
zcarbon
zcarbon's Avatar
Saturday, I C the Fix vendors are already in $$
Sorry Matt
Old 12-21-2013, 07:32 AM
olddragger
olddragger's Avatar
I have an 08, 45k miles. It's stock and no problems. It is a Daily driver
To How many are NOT having Valve issues ?
Old 12-21-2013, 09:06 AM
phipp85
phipp85's Avatar
2011 with 27K miles. All stock. Will be checking after Christmas.
Old 12-21-2013, 11:16 AM
dovervold
dovervold's Avatar
07, 20K miles, Torquer 110 cam, LT's, ect... Hasn't skipped a beat. This Spring will be doing WCCH stage II ported and shaved heads, will report on valve specs when we pull th heads. Cheers,
Old 12-21-2013, 11:26 AM
ioutrun
ioutrun's Avatar
Got WCCH heads at 38xxx miles (2008 C6Z)..all valve guides were within spec before head porting/milling!
Quick Reply: [Z06] How many are NOT having Valve issues ?
