C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
View Poll Results: My car is running fine (only vote if your LS7 is Ok)
Had valves inspected and there Ok
14.38%
Never inspected but my car is Ok
85.63%
Voters: 160. You may not vote on this poll
[Z06] How many are NOT having Valve issues ?
Old 12-21-2013, 11:37 AM
C6___Z06 LW,FL
C6___Z06 LW,FL's Avatar
06 71562 miles
Old 12-21-2013, 11:48 AM
sublime1996525
sublime1996525's Avatar
2006 w/ 27,000 miles. Stock heads. I do have a tune. Planning on doing heads this winter....if I don't get a C7.
Old 12-21-2013, 11:52 AM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Just because the car is running doesn't mean there isn't an issue. All the people who dropped a valve could say the same thing 1 mile before it happened. I know of 3-4 people locally that were running fine and would have said the same thing but when they pulled their heads they were all 3-5x out of spec. Does that mean they didn't have an issue?
Old 12-21-2013, 11:58 AM
propain
propain's Avatar
St. Jude Donor '14
Does that mean they failed?
Just because the valves have wiggle doesn't mean its going to fail. What is the threshold of wiggle to failure in the LS7? Many have even postulated that there is no proof valve guide wear is the reason for failure due to the lack of post failure inspections.
There have been no inspections of the SS valve modification and they seem to be running fine. Does that mean they don't have the issue? Or do they have guide wear as well and just haven't failed so everything must be ok. You cant have it both ways, even though some want to on this forum.
Old 12-21-2013, 12:02 PM
Vette @ 71
Vette @ 71's Avatar
You are absolutely correct. But what this poll does indicate is the number of trouble free miles some LS7's have been driven w/o a valve drop. Limited value but take it for what it's worth..
Old 12-21-2013, 12:35 PM
z06 driver
z06 driver's Avatar
08 with 10,000 miles, no problems so far. Never checked but always worried about it. Completely stock down to the original tires.
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
The valve stem to guide clearance before failure is imminent was postulated by forum member hoefi some time back.
Originally Posted by hoefi
Yes, service limit is 0.0037". Beyond that, exhaust valve stem will start to have problem getting rid of excess heat if the engine is driven really hard with long duration WOT. By the time clearance gets to around .007", galling will start to take place (as per evidence from my engine tear down inspection). From this point on, the valve stem is like a file and guide wear is really accelerated. My failed valve's corresponding guide clearance was 0.016". No valve will survive that type of clearance in my opionion. #1 exhaust is the broken valve.
Basically, there are three stages which leads up to a dropped valve scenario:
Stage 1 - factory clearance which somehow has abnormal high guide wear. Mine wore to the factory service limit (~.004") within 11,000 miles. Of that, there was only about 80 track miles. Six out of the eight exhaust guides are all sitting at this service limit. Stock engine, multiple oil changes during that period.
Stage 2 - Guide clearance between .004" to 0.007". If guide wear is dectected during this stage, it's only a matter in changing them out. I think so far, most of the excessive guide wear (with no dropped valve) are dectected druing this stage. During this stage, if the owner does not drive his car hard, the valve stem will most likely remain smooth and this stage could last long as the vehicle continues to gain mileage.
Stage 3 - Guide clearance between .007 to .015+". During this stage, any type of hard driving could easily induce material transfer on the valve stem. Once that takes place, stem becomes rough and galled. Accelerated wear will then take place regardless of how easy the owner drives his car afterwards. This stage won't last that long and once the guide clearance gets up to double digit thous, the valve head will eventually falls off.
Stage 2 and 3 are merely the end result of stage 1. The most troubled part is still understanding why stage 1 can happen so fast for some of the cars. For my own car, it could be due to excessive cold oil. Up until my valve dropped, most of the 11,000 miles I logged were short duration trips. The car was insured all year round and a lot of trips during the winter months were done in near freezing temperature (I am in Canada). I remember the oil would take easily 20 minutes to struggle up to 120 degrees. A lot of the trips were only 10 to 15 minutes long and the oil temp never went pass 100. I remember even a lot of the longer trips on the freeway, the oil never went pass 140 degrees. The high mileage LS7s we see on this board no doubt did not logged those miles doing 10 minute short trips. Having the car in warmer southern states don't hurt either. Storing the car for the winter also eliminates the cold short trips. The later ('09+ model) liquid/liquid oil cooler might be GM's way of correcting this issue. They might have reconized a potential problem there.
The trick to prevent a dropped valve is to try to catch the guide clearance during stage 2. Especially for owners who do a lot of short trips in cold regions and then would take their cars to the tracks during the weekends in the summer.
There are possibly thousands of cars out there with thus far undetected "guide wear", both stock and modified.
Even those which reach the end point of "valve failure", may never be confirmed to have had "out of spec valve guides", because a lot of the failed engines are not subsequently checked for guide wear. Indeed we are seeing this now.
Until that is done, and actual valve failure is shown to be consistently accompanied by guide wear, then it will be difficult to say just how much of a role guide wear has had in the broken LS7 valve failures we have seen thus far.
Consider this: There were hundreds of thousands of LS1, LS2, LS3 equipped Corvettes built.
Someone else may have, but I have not seen where very much effort has been made to evaluate guide wear in those cars.
As a result, the tendency seems to be toward a belief that it does not affect, or is not as prominent in those cars as it is in the LS7.
But again, really who has actually "checked" any significant number of those cars to determine whether or not guide wear is or isn't a frequent occurrence?
If it is, well then one would have to ask why it seems to not progress to the end point of valve failure.
If it is not, well then would have to ask; "why not?"
100% Especially in light of the above information by hoefi.
Old 12-21-2013, 12:47 PM
propain
propain's Avatar
St. Jude Donor '14
Postulated but ultimately unsubstantiated based on wear measurements recorded beyond that limit that have not failed.
Guessing and unsubstantiated evidence seems to be the norm on this forum.
We guess there the SS valve modification is fine because it has not failed yet, so it must be fine. Probably the worst offense of guessing to date.
We guess that cars with wear will all fail and that there some magical number that is the breaking point. With evidence to the contrary.
If you shoot in the dark you will eventually hit something, so I guess it could take a long time before we reach the real answers.
Old 12-21-2013, 12:50 PM
GLmajer
Support Corvetteforum!
GLmajer's Avatar
11,500 miles on '08 Z06. No issues and not worried about it either.
Old 12-21-2013, 12:54 PM
'06 Quicksilver Z06
It goes without saying that hoefi's numbers are not necessarily "golden rules" or "absolutes", and that there will inevitably be exceptions which actually ended up with outright valve failure below the point of wear which he indicates, and that there will be instances were valve failure has not yet occurred in cases where wear went beyond that which he refers to as Stage 3.
Old 12-21-2013, 12:59 PM
propain
propain's Avatar
St. Jude Donor '14
That's the point. Unknown variables and anomalies make conclusions impossible.
Old 12-21-2013, 01:05 PM
dmuellenberg
dmuellenberg's Avatar
06 with 88,000+ miles - not inspected yet but no problems (ie failures) yet. Planning on inspecting everything when I hit 100,000 which should be sometime late next year.
Old 12-21-2013, 01:09 PM
  #33
surfinva27
surfinva27's Avatar
08 with 13K, bought with 9K. no wiggle test, running good. but will be addressing heads when i come out of warranty.
Old 12-21-2013, 01:36 PM
  #34
typhoontaz
typhoontaz's Avatar
Default 06
06 with 62,138
no issues...yet
Old 12-21-2013, 01:56 PM
  #35
bearcatt
bearcatt's Avatar
Originally Posted by ioutrun
Got WCCH heads at 38xxx miles (2008 C6Z)..all valve guides were within spec before head porting/milling!
This is almost the perfect reply.
In bold: This is the kind of data we need.
Old 12-21-2013, 01:57 PM
  #36
bearcatt
bearcatt's Avatar
Originally Posted by typhoontaz
06 with 62,138
no issues...yet
Valves guides still in spec ?
Old 12-21-2013, 01:58 PM
  #37
bearcatt
bearcatt's Avatar
To How many are NOT having Valve issues ?
Old 12-21-2013, 06:08 PM
  #38
powerlineman
powerlineman's Avatar
No known problems on 09 with 33K.
Old 12-21-2013, 06:19 PM
  #39
2002magred
2002magred's Avatar
2006 with 22,500 miles and no problems except a leaking oil pan at 18,000 miles.
Old 12-21-2013, 06:36 PM
  #40
fishdoc
fishdoc's Avatar
30,000 on my '07 & no worries....
Quick Reply: [Z06] How many are NOT having Valve issues ?
