C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 possible problems
Old 12-20-2013, 03:26 PM
Kennyscott
Kennyscott's Avatar
Default Z06 possible problems
I have a 2006 Z06 with 22,000 mi and am thinking of purchasing both the B&B Fusion exhaust and the Halltech Super Bee air intake.. What possible problems can I expect if any with these two mods. My car is completely stock and factory tuned. Any advice and suggestions would be appreciated.
Old 12-20-2013, 03:34 PM
tim414
tim414's Avatar
St. Jude Donor '12
IMO nothing more than what you face now.
Old 12-20-2013, 03:48 PM
lonnyh
lonnyh's Avatar
The haltech CAI could throw lean codes if not installed properly. Also, you may want to consider getting it retuned to get maximum HP gains.
Old 12-20-2013, 06:17 PM
NHRA95
NHRA95's Avatar
That is not true!. No lean code issues, or any other problems with a Halltech air intake. The MF103 is one of the best air intakes out there. How can you install it improperly?
Old 12-20-2013, 06:38 PM
Pb82 Ronin
Pb82 Ronin's Avatar
I think he meant he should get a tune after a CAI swap in order to be a "proper" install. I'm not familiar with the MF103. But usually, a change in MAF housing diameters will require a small tweak in the MAF transfer curve to avoid codes and changes in fueling conditions. However, if the MAF housing diameter is the same as stock (and no new bends in front of the MAF element are introduced), then tuning is not needed.
Old 12-20-2013, 09:36 PM
surfinva27
surfinva27's Avatar
i have the MF103, no tune. and no codes. and yes I'm aware i will get more out of a tune, just haven't got around to it. but OP, the hall tech shouldn't give you any problems. and an axle back shouldn't throw codes either.
Old 12-20-2013, 10:11 PM
patch68
patch68's Avatar
Shouldn't have any problems except a constant smile on ur face after ur done. I would consider headers with the b&b and a tune and really wake that thing up..
Old 12-21-2013, 07:03 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,911 Likes on 5,325 Posts
Actually it is true. Your intake may have been installed correctly but you don't know if every one will be installed correctly. Even the stock intake can be installed incorrectly and result in codes.
Bill
Old 12-21-2013, 07:33 AM
lonnyh
lonnyh's Avatar
Thanks bill, I should have been more specific. Any cai (not just Haltech) or stock intake can throw codes if it has an air leak. I was trying to tell the OP to make sure both of the 4 inch hose clamps and filter housing is tightened properly.
To Z06 possible problems
Quick Reply: [Z06] Z06 possible problems
