C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Need advice! Scared of blowing my LS7!!
Old 12-09-2013, 02:21 PM
Mark2009
Mark2009's Avatar
I think you're overthinking it
Again... "The exhaust valves wiggled 25 thousandths!". Pretty much speaks for itself despite the additional commentary, but we can wait to hear it from the source soon enough, I'd imagine. I just wanted to jump in since it seemed that the commentary was going off track based on a non-literal read (OMG, .025 guide clearance, worst ever, new record, the end is near!!! ).
And then keep in mind we don't know (yet) how this particular wiggle test was done... I've seen people stick the valve in upside down and wiggle the valve face, some 3" above the guide (getting wiggle that is probably 4x the actual guide clearance).
Old 12-09-2013, 02:55 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Originally Posted by ctsv510
If he was referring to the wiggle measurements overall then "tight" would actually be .002 - .005, or 2 - 5 thousandths. That's why I was asking for more clarification since it is unclear why he would compare actual clearance measurements to wiggle measurements (which need to be converted.)
When people talk about wiggle, I look for .008 or less on their description to get an idea of how good or bad their actual clearances might be, if the test was done accurately.
He described .025" of "wiggle". About 3 times the maximum you'd want to see.
Dividing that by 2 and subtracting .0005" would give a stem to guide clearance of .0120". (.0125-.0005).
The production spec for stem to guide clearance is .001"-0026" on the exhaust side. Service limit is .0037".
The breakdown can be seen in this previously posted link by Despicable Z http://www.bakesonline.com/images/Me...epairSpecs.pdf
So if he's at .0120" of actual clearance, that's a little over 3 times the maximum allowed before being out of spec. and up to 10 times the production spec.
You see someone at .0060-.0090 of stem to guide clearance, that's bad considering that .0037" is the limit.
.0120" of stem to guide clearance is severely out of spec.
Old 12-09-2013, 04:43 PM
Dirty Howie
Dirty Howie's Avatar
Originally Posted by '06 Quicksilver Z06
if that's what they were, then that would probably be a "record" in here.
And good that he had the more durable SS valves !!!
And I also agree that the OP should call LG. Surely they could look up his VIN and see what was done. And thanks to LG for sponsoring the Corvette Challenge
DH
Old 12-09-2013, 09:26 PM
JCox23
JCox23's Avatar
Sorry for the wait. Hopefully the first one works if you click on the pic. If not there is a link to click on. Here it is:
http://s27.photobucket.com/user/coxt...9282c.mp4.html
Also, I looked at the receipt and the stock two peice exhaust valves were replaced with Ferrea LS7 exhaust valves. And it was done in May of 2010. Regardless the miles were still accurate as to when the work was done. The shop said they had not known about the issue otherwise they would have replaced it right then and there when they replaced the valves and ported the heads, etc.
Old 12-09-2013, 09:52 PM
'06 Quicksilver Z06
What valves and guides are you running currently?
Old 12-09-2013, 09:59 PM
JCox23
JCox23's Avatar
Same Ferrea exhaust valves, stock intake valves, and the new guides are Ferrea also.
Old 12-09-2013, 10:06 PM
'06 Quicksilver Z06
Bronze?
Old 12-09-2013, 10:24 PM
JCox23
JCox23's Avatar
Bronze?
I believe so, yes.
And to the OP, sorry to high jack your thread. I was just wanting to show you that these things are definitely worth checking because even as bad as mine were, there were no signs of them going out and yet these look like they could've dropped a valve at any minute. Call LG and see if they have record of doing your guides, they should. If not, pull them immediately and send them to a reputable shop and have them replaced! Or a more expensive option is just replacing the heads altogether. Good luck!
Old 12-10-2013, 12:19 AM
matt3310
Support St Jude!!
Support Corvetteforum!
matt3310's Avatar
2016 C7 of the Year Finalist
2015 C6 of the Year Finalist
Cruise-In X Veteran
St. Jude Donor '09-'10
1st St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19
Called LG and they can't tell me anything without the original owners name. They don't keep records with the Vin.
Also called 4 Chevy dealers and they all thought I was crazy when asking about the wiggle test. I explained it to them and they all said it wasn't something they could do there. I am not mechanically inclined enough to even think about doing it myself.
Old 12-10-2013, 12:30 AM
JCox23
JCox23's Avatar
Luckily the shop new my car from the previous owners name. But it's worth it to find a reputable shop and have your car checked out. Cheap insurance compared to a $10K engine! I have to drive 3-6 hours depending on the shop and what I want done. It's not easy living out in the middle of nowhere trust me haha.
Old 12-10-2013, 12:31 AM
pkincy
pkincy's Avatar
It is friggin unbelievable how incompetent most GM dealers are. You would think their primary product was 1980 Yugos.
Old 12-10-2013, 01:31 AM
meanjoe
meanjoe's Avatar
Originally Posted by Turbooo2u
Both my local dealers look at me strangely when I say "wiggle test" and what it is.
At this point being out of warranty and with all the mod's your car has I'm thinking that taking it to a dealer is a waste of time. Your best bet now should be to take it to a qualified Corvette specialist shop where they're familiar with this issue and won't look at you like your from some other planet. They will be able to address your issue with some knowledge of what's going on.
I fixed mine at 3500 miles, or so.
Good luck.
Old 12-10-2013, 03:39 PM
  #33
matt3310
Support St Jude!!
matt3310's Avatar
Cruise-In X Veteran
Well, I talked to a guy at LG today that was super helpful. He remembered my car and the prevoius owner! He told me all about the car. Unfortuatly the heads were never done because they didn't know about the problem back then. So it will need something done soon to insure nothing goes boom!
He also recommended using Redline 0w40 oil instead of the mobile one. He said that the mobile one doensn't have the same lubricant that it had originally. Mobile One have changed there oil contents. And they feel thats a major reason why the LS7 has had the problems its had.
Old 12-10-2013, 03:49 PM
  #34
Les
Les's Avatar
Well, at least you have the info you need to move forward. Interesting comment about the oil. I'm sure that will open up a whole new can of worms around these parts. Since I changed to Amsoil after my heads were replaced under warranty, I'm hoping there's some truth to that theory. Best of luck.
Old 12-10-2013, 04:23 PM
  #35
Mdm23
Mdm23's Avatar
GM is the reason the LS7 has problems.
Old 12-10-2013, 04:26 PM
  #36
JCox23
JCox23's Avatar
Oh I've already seen that can of worms opened lol. I read a pretty lengthy thread about it over Thanksgiving that ultimately ended up being shut down because people were arguing too much. I think it was pretty much agreed on that because of the oil cooler on our cars the oil never gets up to the proper temperature unless you're just beating the hell out of it at a track so that's why we need to switch to a 0w 30 or 0w 40 weight. It's even been suggested to cover up the oil dealer or delete it.
Personally I am going to try temporarily covering the oil cooler up and switching to Amsoil 0W 30 and see if that helps.
Old 12-10-2013, 06:17 PM
  #37
Les
Les's Avatar
People in the C6 Z06 forum arguing?!?!?!? When the hell did that start happening??? I just took delivery today of the Unbalanced Engineering oil cooler/reservoir "blanket" kit. It looks pretty well made. Once our recent snowfall is fully melted I'll get out and see how well it works. During winter time here it can be a challenge to reach 160 degrees of indicated oil temp. The kit may come back off during the summer since it's typically well over 90. If you're interested I'll post my winter results- or I can give you the temp chart info provided with the kit.
To Need advice! Scared of blowing my LS7!!
Old 12-10-2013, 08:04 PM
  #38
Mark2009
Mark2009's Avatar
Reposted by permission. See: http://wronghands1.wordpress.com/about/
Old 12-10-2013, 08:24 PM
  #39
Les
Les's Avatar
Old 12-10-2013, 08:48 PM
  #40
GMuffley
GMuffley's Avatar
What he said.
Quick Reply: [Z06] Need advice! Scared of blowing my LS7!!
