C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Anyone running RHS Pro Elite LS 7 cylinder heads?
Old 12-07-2013, 12:34 PM
troy6166
troy6166's Avatar
Default Anyone running RHS Pro Elite LS 7 cylinder heads?
Anyone?
Old 12-07-2013, 01:38 PM
Pb82 Ronin
Pb82 Ronin's Avatar
In there for details. They're like a mystery head. Not very much info out there on them. Very limited flow data is publicly available, I think that keeps people from pulling the trigger on purchasing them.
Old 12-07-2013, 02:16 PM
8850's Avatar
No flow data and from the web site seem pricy.
Old 12-08-2013, 06:32 PM
98TransAm
98TransAm's Avatar
Originally Posted by troy6166
Anyone?
What are you building
Old 12-08-2013, 06:57 PM
troy6166
troy6166's Avatar
Just trying to resolve the valve guide issue, if i pick up a little power in the process that would be nice as well.
I had the factory heads ported, decked, added solid SS exhaust valves and installed a camshaft with 7K miles on the car. The factory valve guides were perfect at the time of the modifications so we opted to run with the factory guide. The car now has ~15K miles and the guides are shot.
I'm hoping RHS has taken the valve guide issues into consideration when casting their head, they will get back with me tomorrow to discuss further.
Old 12-08-2013, 07:31 PM
98TransAm
98TransAm's Avatar
are you running the stock rockers?
Old 12-08-2013, 07:46 PM
troy6166
troy6166's Avatar
stock GM rockers with the comp trunnion upgrade.
Old 12-08-2013, 08:22 PM
double06
double06's Avatar
Default RHS Heads
Talk to Chris Frank at Frankenstein Heads, I think in Texas. I think they flow 393 / 250 at .600 lift. They have started doing a lot of these.
Old 12-08-2013, 09:22 PM
troy6166
troy6166's Avatar
Appreciate the information, I'll check it out. The flow numbers at .600" are incredible! With those flow numbers and valve guides that hold up for 30-40k miles I may begin to love my Z06 again!
Old 12-08-2013, 09:25 PM
pkincy
pkincy's Avatar
Sorry to hear of the guide problem, but glad that you took the time and trouble to check and avoided greater damage.
Old 12-08-2013, 09:45 PM
Coach62
Coach62's Avatar
St. Jude Donor '12
Solid SS valves are much cheaper than the valves GM uses. If they were best, GM would surely use them.
I opted for the WCCH modification with new GM valves instead of solid SS valves.
My plan is to check the guides for wear in a couple of years, depending on mileage and see how the wear is.
Under no circumstances would I use the stock guides, I believe that is the main problem based on my research.
Old 12-08-2013, 09:51 PM
Pb82 Ronin
Pb82 Ronin's Avatar
That must be an in house head then...the ONLY CFM numbers I've been able to find with the RHS heads are 375/230 @ .650. Even RHS doesn't post flow numbers in their catalog.
If your number are correct, that means that they have the HIGHEST flowing intake runner on an LS7 head available at .600
Old 12-08-2013, 09:52 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
So if I'm counting up your mileage right, you only got 8K miles out of your valve guides after the modifications were done.
That's not a lot of miles at all
Please do let us know what RHS has to say about the guides.
Old 12-08-2013, 10:02 PM
troy6166
troy6166's Avatar
Not sure I'm convinced the guides are the main problem. IMO it's a combination of things that promotes excessive valve guide wear.
Old 12-08-2013, 10:03 PM
troy6166
troy6166's Avatar
I sure will…
Old 12-08-2013, 10:12 PM
'06 Quicksilver Z06
It's been said before that when the stock guides start to wear, that wear accelerates and accelerates quickly once wear begins.
Your case sounds like an example of that.
Sounds like they may have still been in spec when the modifications were done, but wear may have already started, just not to the point to where they were out of spec.
Do you know what the stem to guide clearances were when the work was originally done?
Old 12-08-2013, 10:20 PM
Coach62
Coach62's Avatar
St. Jude Donor '12
And what is the combination of those things? An aftermarket camshaft could certainly be one.
Unfortunately, we won't know for some time yet. I love my car enough to stay on top of the issue.
To Anyone running RHS Pro Elite LS 7 cylinder heads?
Old 12-08-2013, 10:37 PM
troy6166
troy6166's Avatar
Rocker arm geometry , valve guide geometry, valve guide material, lubricants and camshaft (including stock).
The experts will probably add some I have missed.
Old 12-09-2013, 08:10 AM
blackc6z
blackc6z's Avatar
His car and my car where built exactly alike with the same guy doing the work and same camshaft. I have roughly the same milage on my build, had my guides check last week and my guides are worse than troy6166. Mine were also perfect before the build and I had 21000 miles when build was done now have 29000 miles. Really hating the LS7 at this point.
Old 12-09-2013, 08:21 AM
'06 Quicksilver Z06
So you didn't get new guides either?
No other work on the heads, just new valves and springs in old heads?
Quick Reply: [Z06] Anyone running RHS Pro Elite LS 7 cylinder heads?
