[Z06] Wiggle test results
Wiggle test results
If you're not familiar with my story (from my now closed thread), I decided to get my cylinder heads done without checking them (2007 Z, 19,100 miles). However, I asked the shop doing the R&R on my heads: "how much more to check the valve guides before you ship them off". He responded "nothing" (F'N great right!)
So I told him to check one valve guide, if that first guide was out of spec (told him about the .0037" limit) just put the rocker back on, continue removing the heads and ship them off. However, if the first valve was good, continue checking the guides and call me. Well he called me.... and not because the guides were within spec.
He called and said: "I only checked the drivers side valve guides and I didn't even put a gauge on them. The clearances were so bad that there must have been at least .02" of play on some of the guides. There was no need for a gauge, I could feel significant movement with just my hands." He was shocked... I wasn't. This is the same shop that the owner has a C6 Z06 and tried to talk me out of getting the test done.
My heads will be shipped off today. I'm going to keep my Z completely stock, drive it like I stole it (no track, just spirited road), and check the guides again within 10,000 miles to see how they look and I will report back then.
I feel like I dodged a HUGE bullet here and I want to thank the forum members for bringing the valve guide issue to my attention, providing me with the information I asked for, and your support. A special thanks to a member who gave me a wealth of info via PM.
Good deal. You will get your heads fixed, re-installed and be fine for thousands of miles more.
Sucks we have to do it but way to be proactive! My passenger side was loose enough for me to pull my heads off without checking the driver side.
But boy when i got my driver side off... wow. Hot dog in in a hallway! it was more than 7x out of spec
Sucks bro! I went thru a similar ordeal on mine and got them done for the piece of mind!
Good luck w the Fix!
Well I planned on getting the heads done without even checking them. With these results I can rest assured knowing I'm doing the right thing.
I said in my other thread: I've never seen a "got my guides checked, they are within spec" thread/post/anything. I now fall into the long line of guides being grossly out of spec.
My car has a checkered past, coming from a exotic rental car dealership and all. I fully assumed my guides would be bad.... just not this bad for a 19,000 mile car.
If there is no personal info involved would you mind copy and pasting that info into a PM to me? I figure that's the easiest way for me to learn without having someone take all the time to explain it.
Excellent! just got my heads done too...Nice not driving around a dud grenade, ya never know when it will go off! I must say I'm enjoying all the other performance goodies goodies too.
Okay, so I should check the forums more often,... What the heck are ya'll talking about? Wiggle test? Valve guides? Sounds menacing at best, costly at worst. Kind of afraid to ask what happens when whatever it is that happens happens. Blown engine? I have an original 06 Z06 that I purchased new. Drive it a bit and quite hard at times (cuz that's the way I figured it likes to be driven - I know I sure like it that way!). I've got about 41,000 miles on my Z and just ordered the Fusion cat-backs because my stock mufflers have a terrible rattle that I have read is likely the stock mufflers falling apart. Are there any noticeable signs to having bad valve guides? Mine seems to run hard and idle like the day I bought her. Thanks in advance for any advice or insight.
-Aftermarket powdered metal valve guides
-Ferrea super alloy hollow F2042p exhaust valves
-Comp cams trunions upgrade (correct needle bearing issues with the early model 07's)
-Upgrade valve springs to dual valve spring with titanium retainers
Yuuup. Exactly what he said. I read and read and obsessed over this topic for 2 weeks. You'll find viewpoints from both ends of the spectrum from: "it's a major epidemic" to "it only concerns a small batch of heads, don't worry". You'll have to make your own peace with it, and come to your own conclusions.
I have decided to send them to American Heritage Performance. I contacted them after I saw their thread here on CF. I spoke with Richard at WCCH and Kohle at AHP. Through my research and my personal reasons, I decided to go with American Heritage. Work that's being done:
I am sorry for all of us that this is necessary, but you did the right thing and immediately decided what you felt was best to do and than went and did it.
Now you can spend some time enjoying the car. And that check in 10,000 miles will give you a lot of piece of mind going forward.
My 08 hasn't hit 8,000 miles yet, but I am running up to NCal in 2 weeks and will get them checked at Abel. Just to make me feel better and also to take care of a couple of small warranty matters as well.
