[Z06] DBA Pkg Deals! Now served with new T-slot rotors from DBA
C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
How do the DBA T3 4000 Series rotors compare to the stock setup? Can you give a comparison of the two?
DBA has what is called "Kangaroo Paw" - Increases the surface area on the inside of the rotor which in turn increases heat dissipation, helps to minimizes brake fade and will increase the braking effectiveness.
Features XG150 High Carbon Alloyed Iron - Increased alloys in the iron changes the thermal capacities of the iron allowing it to handle higher temperatures.
Post production heat treating - strengthens the rotors, and prolongs the service life of the rotor.
-Nick
Reason: spelling
