[Z06] Replacing LS7 (and everything else under the hood), suggestions?
The engine on my '07 Z06 blew up causing a small fire under the hood which essentially took out all the internals in front of the firewall and above the suspension. No point in getting into the dramatics of how & why this happened, what's done is done.
We're going to replace the motor with a new crate LS7. Since I'm starting with a clean sheet, and suggestions on what else I might do in this process under the hood. Going forward, I think this will primarily be a track car for DE's, though will still need to drive back and forth. I'm not looking to make major changes for more power, I'll get more from upgrading my skills than I will upgrading the HP.
Also, I'm not really sure how this replacement stuff works - should I expect the new motor to work with the updated oil cooler/dry sump systems Chevy introduced after 2007 or do I need to specify this when ordering?
Thanks!
Thanks!
If my LS7 ever goes out- this will be the route I take. I just had the heads reworked so I hope I never have to take this step but you never know:
http://forums.corvetteforum.com/c6-t...longblock.html
= no more LS7 gremlins
Didn't really answer your questions but thought I'd offer an alternative.
Thanks!
Thanks!
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
Thanks!
Thanks!
DH
