C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LS7 with an A&A kit reliable to what HP?
Old 10-16-2013, 01:01 AM
LS9Drew
LS9Drew's Avatar
Default LS7 with an A&A kit reliable to what HP?
To what WHP is around the most the LS7 can take with an A&A kit and the normal bolt ons headers/ported intake/TB, heads, no cam on 91. I'd like to be around 580-620whp and not have to worry about my motor blowing.
I like this option since I can remove my headers if I wanted and not have to deal with BS smog stuff since the A&A is carb legal. I want more power whether that comes with installing the cam I have with a fast 102, selling my Z for a ZR1, or doing the S/C. Car is paid off so obviously modding this car would be the cheapest route lol.
I have a good tuner so I'm not worried about the whole "if the tunes good situation". So I'm more curious if the LS7 can hold 580-650whp boosted reliably
Old 10-16-2013, 01:38 AM
TT32VGT
TT32VGT's Avatar
I think you're fine.. they have guys running around at over 700rwhp on stock blocks.. not sure how long they last but I would feel fine at 600rwhp on a stock block for sure..
Ive contemplated the same, with selling the z for a zr1.. I ended up doing HCI but might do a supercharger and maybe even lsx down the road... I decided to keep the z
edit: why not add a meth kit just for safety?
Old 10-16-2013, 01:43 AM
lilredvette05
lilredvette05's Avatar
Well I have not had mine long at all so I can't really say how reliable yet... But I'm at 660whp tuned on conservative on 91 but I have H/C with a FAST 102.
There are several several other cars here on forum that have over 700whp that have had zero issues some have meth some don't.
If your tune is spot on 580-650 I don't think should be a problem
Old 10-16-2013, 11:14 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
580-600 would be easy. In fact it maybe hard to turn the boost down and timing low enough to only make 600. My car on <6psi and 11 degrees of timing made 705rwhp on a stock bottom end ls7.
Old 10-16-2013, 11:28 AM
Brandon619
Support Corvetteforum!
Brandon619's Avatar
with Unreal you can easily run 6 to 7 psi on the LS7 with meth and spot on tune.
Old 10-16-2013, 11:51 AM
Unreal
Unreal's Avatar
That was without meth, just 91.
Old 10-16-2013, 12:01 PM
Brandon619
Brandon619's Avatar
Nice, what are your mods?
Old 10-16-2013, 12:26 PM
Unreal
Unreal's Avatar
Mods at the time were A&A kit, PRC 285cc heads, 228/234 blower cam, LG headers, fast 102.
Old 10-16-2013, 03:56 PM
ZedNought6
ZedNought6's Avatar
How does a 700 Hp car drive? Can you put that on the pavement and enjoy it? Or is it crazy squirrely?
Old 10-16-2013, 04:29 PM
ralphsmithiii
ralphsmithiii's Avatar
I'm curious to see the responses to this as well
Old 10-16-2013, 04:33 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I assume you have normal function of your right foot. The rest is up to you. It can go either way.
Old 10-16-2013, 04:47 PM
Too-Fast
Too-Fast's Avatar
Most of the literature I have read discusses 700-800Hp as the "safe limit" for an aluminum block, so you should be fine.
Old 10-16-2013, 04:53 PM
croatbob
croatbob's Avatar
my cars been at mid 700s for 2 yrs now no problem. no meth. 91 tune.
Old 10-16-2013, 04:57 PM
ZedNought6
ZedNought6's Avatar
HA HA! I like to use the full throw of my gas pedal... I am aware of the need for pedal modulation, and my foot can do just fine with that. But, I am also aware that some folks like to build for numbers, (dyno queens) while other build for purpose (drag racing and road racing). So I shall restate my question:
Can ALL of those 600-700 horses be harnessed to deliver a definite advantage for a purpose build car for street and road courses, or are they superfluous and unusable due to traction loss? At what point are you just wasting your money on power you can't use?
Old 10-16-2013, 05:33 PM
croatbob
croatbob's Avatar
Street radials n it's very fun n useable.
Raider7967 (03-19-2024)
Old 10-16-2013, 07:03 PM
Unreal
Unreal's Avatar
On a good tire 2nd gear up hooks just fine on a good day. ****** tires you spin all over at any speed.
Old 10-16-2013, 07:20 PM
3 Z06ZR1
3 Z06ZR1's Avatar
My 2008 Z06 with A&A kit and ARH 1 7/8's headers w cats
tuned to 12 degree's and 8 psi did 585 and 541 (mustang dyno) on 91 octane.
V-3si blower.
FULLY HEAT SOAKED AT 225 DEGREE'S !
So in cool air who know's (guess 625) plus
I swapped blower heads to an 1500sl Paxton.
People don't realize that the boost takes the Ls-7 to 450 plus
rwtq at around 2200 this more than the N/A makes at 5000.
So the low end is not lacking and the top end is well!
Smoking!
Seems to pull harder up top with the same feel on the bottom.
On the change from V-3si to 1500 Paxton (same as V-3 T trim)
Been driving around for 25k with the kit and headers.
It lifts up and goes never use wide open but it eats on the road everything easy!
Love those 750 BMW's thinking there going to hang!
I had the same kit on the base car but the Z platform is faster with the same power. The lighter frame and bigger tires pushes easier.
To LS7 with an A&A kit reliable to what HP?
Old 10-16-2013, 09:54 PM
ZedNought6
ZedNought6's Avatar
mentioned SC to my builder (getting some work done in a few weeks) and the first thing out of his mouth was "forged pistons" we didn't even go into how much boost. My guess is it really depends on how much stress you plan on putting the car through on a regular basis, and how healthy your bottom end is is.
I think if I ever went this rout I'd go forged.
Old 10-16-2013, 10:28 PM
Adam_W
Adam_W's Avatar
I really appreciate this thread.
Been thinking about having A&A supercharge my '08 Z06 at some point.
Good to hear from people who have had it done for a while and haven't had any problems, it inspires confidence.
Old 10-17-2013, 12:43 AM
ghoust
ghoust's Avatar
I am in a Z06 today because of this scenario. I had a 680rwhp Dodge Viper and although it dynoed with the best of them, it was useless on the streets. I could never completely use the power and it negated the car's fun factor. Enough to the point that I decided to part ways with her and move to a milder Z06 550whp currently. I don't plan to add more power to my current car as I feel I am at the threshold of fully utilizing the power on the streets.
Quick Reply: [Z06] LS7 with an A&A kit reliable to what HP?
