C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Blew the engine!!! :-(
Old 10-05-2013, 09:46 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Default Blew the engine!!! :-(
I posted about it in the AutoX/Roadrace section:
http://forums.corvetteforum.com/auto...post1585100985
Bob
Old 10-05-2013, 10:00 PM
FSTFRC
FSTFRC's Avatar
That sucks! What are your plans to replace the engine?
Old 10-05-2013, 10:12 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Bob
What a tough break Bob.
Glad to know that you are safe, and good luck getting it back together.
Old 10-05-2013, 10:15 PM
tail_lights
tail_lights's Avatar
Old 10-05-2013, 10:18 PM
Gary '09 C6
Gary '09 C6's Avatar
glad no one got hurt...very tough break !
Old 10-05-2013, 10:22 PM
tim414
tim414's Avatar
St. Jude Donor '12
Sorry Bob. Are you planning to put it back together....?
Old 10-05-2013, 10:31 PM
Turbooo2u
Turbooo2u's Avatar
The LS7, a "racing engine" not meant for racing.
Old 10-05-2013, 10:46 PM
Dirty Howie
Dirty Howie's Avatar
Sorry to see you join our club. How many track days do you think you had on her? Mine went with 87K and 30+ track days.
What oil?
Do you short shift or let her wind out to 7K
DH
Old 10-05-2013, 11:05 PM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
Glad you're ok Bob. Could have gotten out of control real quick. Whew...
Old 10-05-2013, 11:26 PM
Z.06
Z.06's Avatar
Default Engine Blew at HDPE
Do you know that a valve has dropped yet? The reason I ask is that this looks like the kind of track that can cause momentary loss of oil pressure in an unmodified pre 2009 Z06, and I think that either dropping a valve or loss of oil pressure could result in a hole in your engine block.
Old 10-05-2013, 11:27 PM
Minkster
Minkster's Avatar
Posted in your other thread, but if you are still running the stock oil tank, looks like you were in the oil starvation prime zone as you were in a sustained left hand turn for 20 or so seconds. Keep us informed of what you find out. Sorry for the bad luck....
Old 10-05-2013, 11:44 PM
'06 Quicksilver Z06
What oil?
DH
http://forums.corvetteforum.com/c6-z...post1583834969
http://forums.corvetteforum.com/c6-z...post1584286966
http://forums.corvetteforum.com/c6-z...idnt-blow.html
Mine is stock 2006 (except for a Killer Bee intake and a Halltech tune), and I dangerously ran up to 6,500 to 6,800 RPM regularly, and bumped off the rev-limiter once (after getting slowed down a little bit by another car, I was real close to the brake zone for the Bus Stop, and I just kept my foot in it and ran it up in 4th gear to 160 mph and an instant before braking it bounced off the rev-limiter).
Sometimes I'll shift into 5th early (around 6,000 RPM), but most of the time I would run 3rd and 4th up to in excess of 6,500.
This was really an ironic thread in that two years ago, almost to the day, he had posted up that last thread, and the title of it.
"My Engine Didn't Blow!?!?!?!?!?!?".
Two years later, he's posting this one up.
and it was also the first thing I thought when I looked at his video, at that 1:16 point and on that he makes mention of in his other thread.
I had seen where he had run this track in the past and you can get an idea even looking at his avatar that he tracks the car and has made long left handed sweeping turns in it.
Previously he had posted up this with regard to the oiling issue:
I have a 2006 Z06. The early Z06 came with a 7.5 quart dry sump tank.
If you didn't get a "Low Oil Pressure" message in the DIC then I don't think you have anything to worry about.
I run my Z06 with about 7 quarts on the track - anything more than that and it starts to blow it into the intake and can cause problems.
The early 7.5 qt system could have problems when running a track with a high speed left hand sweeper where you generate more than 1 lateral G for in excess of 4 seconds.
There aren't many tracks where that occurs, and my car has many laps around the left hand turns on the Daytona banking, but the lateral G load bounces around from 0.5 to 1.0, so because of the banking I'm not sustaining >1G and have never had a problem at Daytona or other tracks I've been running.
But it could be that the repeated instances, finally caught up to him.
It will be interesting to see what his report on what his heads look like when he removes them
Old 10-06-2013, 06:51 AM
VCUFAN
VCUFAN's Avatar
At least you still have the ZR1 and good luck putting the Z06 back together.
Old 10-06-2013, 08:02 AM
KLLRVET
KLLRVET's Avatar
It's hard to be sympathetic to guys who mocked those of us who are part of the sky is falling crew
Old 10-06-2013, 08:52 AM
ltdodge
ltdodge's Avatar
your so classless...hope you blow your engine...
Old 10-06-2013, 09:00 AM
forg0tmypen
forg0tmypen's Avatar
Both of these posts are not only immature for grown men to say (or women) but just plain wrong. Never wish bad things on people. Guy lost his motor I'm sure he realizes any past gestures he made were wrong and he was wrong for making them. That can be assumed.
Old 10-06-2013, 09:02 AM
forg0tmypen
What typically fails when the engine is starved for oil on those long left hand turns? This was part of the reason I upgraded to the larger tank OEM, but a little more piece of mind.
To Blew the engine!!! :-(
wolf8218
wolf8218's Avatar
Sometimes this forum is just horrid.
Old 10-06-2013, 09:03 AM
'06 Quicksilver Z06
Main bearing failure.
http://www.bobistheoilguy.com/bearin...aranalysis.htm
http://www.camarohomepage.com/ls7/
Old 10-06-2013, 09:16 AM
ltdodge
ltdodge's Avatar
i understand but Bob is a friend of mine and putting salt on the wound is uncalled for. not only did he post it once but in another other thread. him digging up a thread from 2 years ago to laugh at him is uncalled for and i don't regret with my previous statement.
Quick Reply: [Z06] Blew the engine!!! :-(
