C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Brake Pad replacement time.
Old 11-03-2013, 02:05 PM
ghoust
ghoust's Avatar
Default Brake Pad replacement time.
Hi guys,
its time to replace my pads. I am wondering what the popular replacements are among the Z06 crowd. Please share your favorite pads with part numbers and what style of driving your Z06 sees.
Old 11-03-2013, 03:43 PM
darr3239
darr3239's Avatar
I've been following the brake stuff for a while. It appears the consensus, for other than those heavily involved in track days, is to stick with the stock pads and calipers. They appear to work just great, even if you do a track day every now and then.
So much of this depends on how the car is driven. Probably most folks, on a track days, aren't pushing their cars anywhere near the limit.
Old 11-03-2013, 06:19 PM
rabrooks
rabrooks's Avatar
Talk to KNS. they can tell you what pads are good for street with less dust. My experience with them has been good. I track my car so Other than that, I can't help.
Old 11-03-2013, 06:38 PM
pkincy
pkincy's Avatar
The previous owner of my very low mileage 08 said he put on Hawk Ceramic pads. I can't verify that is what is on there without pulling them but I will say I have been very pleased with the lack of dusting and noise.
My M3 used stock pads and they completely covered the wheels in black brake dust daily.
Perry
Old 11-03-2013, 09:26 PM
Oleman
Oleman's Avatar
Just replaced mine and went with Carbotechs, pleased with them over OEM.
Old 11-03-2013, 09:30 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
very happy with the Posi Quiets I installed over 2 years ago...virtually dust free
Old 11-04-2013, 07:29 AM
m.whitmell
m.whitmell's Avatar
Just put these on my car...less than $70 for all 4 wheels...Ebay
Old 11-04-2013, 09:39 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Are you doing any track days?
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 11-04-2013, 10:50 AM
spra4u
spra4u's Avatar
Posi quiet ceramic single piece pads here as well. Have had them on for 3 or 4 months and have been very happy with them. Very low dust and very quiet. I don't track my Z but i do a spirited run from time to time.
Old 11-04-2013, 10:56 AM
ghoust
ghoust's Avatar
I go to the drag strip and half mile roll race events about 5 times a year.
Old 11-04-2013, 11:25 AM
chrisfromalbany
chrisfromalbany's Avatar
how does there stopping power compare to the OEM ones?
Old 11-04-2013, 12:49 PM
spra4u
spra4u's Avatar
For the kind of driving I do, they are fine. As far as how they compare to oem, I don't feel that go cart brake feeling. Oem are better brake pads but I wanted less brake dust and that's what I bought. You can tell that after braking hard after a few spirited runs they tend to fade a bit. But then again I don't drive like that all the time.
Old 11-04-2013, 12:56 PM
Supporting Vendor
Take a look at the Carbotech 1521 compound. We make a 1 piece pad witch I prefer over the multi piece pucks. The 1 piece gives you 15% more pad surface and even pad wear as, the pucks all wear at a different rate. The 1521 can be used for the events you are doing with no problem. If interested give me a call at 216-780-8825 and I will be happy to place an order for you. I also offer 5% discount for forum members.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Single Backing Plate-Front F: CT1185-S
$290
Single Backing Plate-Rear R: CT1185R-S
$246
12 Individual Backing Plates-Front F: CT1185
$270
8 Individual Backing Plates-Rear R: CT1185R
$233
To Brake Pad replacement time.
Quick Reply: [Z06] Brake Pad replacement time.
